SVS SB-1000 and PB-1000 Subwoofers
SVS just introduced two 300-watt powered subwoofers, each priced at $499. The PB-1000 is the larger-sized of the two and offers a 10-inch driver in a ported enclosure. While the smaller SB-1000 uses a 12-inch driver in a sealed enclosure. SVS says the budget subs will outperform models costing two to three times as much.
The compact SB-1000 is designed for consumers wanting a less intrusive box, while the PB-1000 maximizes performance for the price. Either should produce deep, accurate bass in any size room. Although I would expect the ported PB-1000 model to play louder due to its larger size and design.
SVS SB-1000 - back
The SB-1000 (above) offers a 13”x13”x13” sealed cabinet with a front-firing 12” driver with dual high-grade ferrite magnets and FEA-optimized internal motor technology for high output with extremely low distortion. The lightweight cone material of the long-stroke driver reproduces subtle audio tones with lifelike realism, making the SB-1000 a perfect option for serious music lovers. A unique vented pole piece and efficient high-power voice coil keep the SB-1000 cool without impacting performance or adding noise. Durable rubber surrounds also ensure long-lasting performance, even when the subwoofer is pushed to its performance limits for extended periods of time. Weighing in at an easily movable 27 lbs, the SB-1000 is SVS’s lightest and smallest subwoofer, making its 24Hz to 260Hz (+/- 3dB) frequency response all the more impressive.
SVS PB-1000 - back
Weighing 46 lbs with dimensions of 18.4”x15”x18.4”, the PB-1000 (above) offers a breakthrough value for low frequency performance with a front-firing 10” driver and 3.5” high-flow port with inner/outer port flares. Deep bass extension and output is between 19 Hz and 270Hz (+/- 3dB) thanks to carefully selected components optimized for maximum efficiency and low-frequency punch with almost no distortion.
Driving the SB-1000 and PB-1000 subwoofers is an integrated SVS Sledge STA-300D amplifier with sophisticated DSPs perfectly matched to each unique driver and cabinet configuration, and an equalization curve optimized for enhanced transient response and room gain. Conservatively rated at 300 watts (700 watts peak dynamic), this amp allows precise control of the subwoofer at all levels to allow fine tuning of audio playback and easy set-up and integration into any home theater or stereo system.
Both the SB-1000 and PB-1000 subwoofers feature a stylish premium black ash finish with curved edges and a black cloth grille. For connection options, stereo line-level RCA inputs and 80Hz high pass filtered output connections, as well as speaker level five-way binding post input connections, are available.
Price and Availability
Both subs are available now and include a 45-day in-home trial for worry-free evaluation.
  • SVS SB-1000 300 Watt DSP Controlled, 12″ Ultra Compact Sealed Subwoofer. $499
  • SVS PB-1000 300 Watt DSP Controlled, 10″ Ported Subwoofer. $499
Pro-Ject Audio CD Box RS2 Tube Silver CD Player
CD Players
Pro-Ject’s CD Box RS2 Tube doubles down on Red Book CDs with a balanced tube stage—no SACD, no digital inputs, and a $2,300 price...
Backert Labs Optik Phono 1.1 Backert Labs Optik Phono 1.1
Backert Labs’ $11,500 Optik Phono 1.1 targets DS Audio optical cartridges and five-figure turntables—impressive at shows, uncompromising in design, and firmly not for casual...
2026 Samsung Music Studio Series Speakers 2026 Samsung Music Studio Series Speakers
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
HumminGuru EZ Record Washer Package HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Hisense PX4-PRO UST Projector Hisense PX4-PRO UST Projector
Hisense previews the PX4-PRO UST projector ahead of CES 2026, promising 200-inch images, higher brightness and contrast, built-in Atmos audio, and a flexible alternative...
Hisense XR10 High-end Lifestyle 4K Laser Projector Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
From budget-friendly upgrades to room-shaking reference bass, these subwoofer picks deliver accurate low-end performance, smart features, and real value at every price tier.
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
Cyber Monday 2025 delivers huge savings on Audioengine, Denon, SVS, Samsung and more. The best home audio and TV discounts of the year are...
2025 Black Friday tech deals you won't want to miss on premium hi-fi, headphones, and home theater gear this Holiday Season.
This is the really good stuff for audiophiles, music lovers and home theater enthusiasts that's guaranteed to impress.
