SVS 5000 R|Evolution Subwoofers Let You Feel Movie Night in the Next Zip Code
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
SVS SB-5000 and PB-5000 R|Evolution Subwoofers
SVS today announced two new massive 15-inch powered subwoofers, which feature 2,000 Watts of RMS power and subterranean bass as low as 13Hz. The two models in the new series are the SB-5000 R|Evolution sealed cabinet subwoofer and the PB-5000 R|Evolution ported cabinet subwoofer.
Although they’re a slight step-down (in size and performance) from the flagship SVS 17-inch Ultra R|Evolution Series Subwoofers, the 5000 series takes up less space and shaves $500 off the price of each model, respectively.
Both 5000 series models share the same internals, but are differentiated by their enclosure architecture. Multiple advancements include an all-new 15-inch driver with a dual edge-wound voice coil, dual monoblock amplifier, 295MHz Analog Devices DSP, and a built-in AC line conditioner.
The Drivers
SVS 5000 Series R|Evolution Subwoofer Drivers
For the new 15-inch driver used in both models, SVS has designed the first-ever dual edge-wound voice coil to ensure stable transfer of electromagnetic current from the dual mono-amplifier to the 38lb toroidal ferrite magnet motor. This results in massive output with precise control. Copper-clad aluminum voice coil wiring combines the best properties of both elements, yielding ideal thermal capacity and magnetic field strength within the motor.
5000 R|Evolution subwoofer drivers are built to handle the most demanding low-frequency playback while rendering the subtlest sonic details with refinement at peak and moderate listening levels.
The proprietary SVS design features a long-throw parabolic NBR surround for extreme excursion, sound pressure levels, and longevity. A lightweight and rigid glass fiber laminated dustcap moves massive amounts of air to create tactile sonic energy without sacrificing control.
The Amps
SVS 5000 R|Evolution Subwoofer Amplifier
To optimize the driver’s potential is a first-ever 2,000 Watts Continuous, 5,000+ Watts Peak dual mono-block STA-2000D Class-D amplifier. Each amplifier powers one of the dual voice coils to increase the current into the motor while asserting pinpoint control and increasing output potential. Eight 60-amp 200-volt MOSFETs deliver near-limitless power to ensure peak performance with the most demanding content while maintaining Class D efficiency.
The Power Supply
To further support ultra high power output, SVS has included a power supply that meets the limits of a standard 15-amp AC home circuit. This includes an onboard AC line conditioner with power factor correction that stabilizes the incoming voltage, corrects waveform distortions, and eliminates electromagnetic and radio interference. This continuously optimizes signal quality while ensuring the subwoofers remain impervious to voltage fluctuations.
SVS 5000 R|Evolution Subwoofer Rear Inputs
The DSP
Another innovation included in the 5000 series, SVS has added a sophisticated DSP to optimize all aspects of performance and usability. The 295MHz Analog Devices DSP orchestrates every function of the amplifier to shape in-room response and stabilize AC voltage delivery while managing a multi-point thermal and current monitoring system for optimal performance and efficiency. Advanced digital audio processing and DACs (Digital-to-Analog Converters) with 120 dB Signal-to-Noise Ratio provide greater headroom, lower noise, and acoustic linearity.
Smartphone Control App
Calibration of the 5000 R|Evolution series is managed via the SVS subwoofer via the available smartphone app (iOS, Android). The app includes controls for volume, low-pass filter, phase, polarity, six parametric equalizers, room gain compensation, port tuning (PB-5000 R|Evolution only), power management settings, and more. There are also three memory presets for fast and easy system adjustments to match your listening preferences.
SVS iPhone App
From Gary Yacoubian, SVS President: “SVS has always been about bringing reference experiences to broader audiences. While other manufacturers are still chasing benchmarks we established with the flagship 17-Ultra R|Evolution Series, we raised the bar and redefined what is possible at even lower prices with the 5000 R|Evolution Series,…From the performance specs to the advanced tuning and control and user experience, 5000 R|Evolution defines its class. The finest subwoofer technology available is now accessible to more audiophiles and home theater fans than ever.
5000 Series Comparison
SVS SB-5000 (left) and PB-5000 (right) R|Evolution Subwoofers
SB-5000 R|EvolutionPB-5000 R|Evolution
Product TypeSealed Subwoofer Ported Subwoofer
Price/Finish$1,999.99 – Premium Black Ash
$2,099.99 – Piano Gloss Black
$2,599.99 – Premium Black Ash
$2,699.99 – Piano Gloss Black
Driver Size15-inches (Front Firiing)15-inches (Front Firiing)
Amplifier TypeClass DClass D
Amplifier Power Output2,000 watts RMS (over 5,000 watts peak)2,000 watts RMS (over 5,000 watts peak)
Frequency Response  (+/-3dB)17Hz to 280Hz15Hz to 180Hz (standard mode – all ports open)
13Hz to 180Hz (extended mode – 2 ports open)
16Hz to 270Hz (sealed mode – all ports sealed)
Signal-to-Noise Ratio (SNR)120dB120dB
Inputs1 x RCA Unbalanced
1 x RCA LFE
1 x XLR Balanced
1 x RCA Unbalanced
1 x RCA LFE
1 x XLR Balanced
Outputs1 x RCA Unbalanced
1 x XLR Balanced
1 x RCA Unbalanced
1 x XLR Balanced
Dimensions (HWD w/ grille)18.3  x 17.8 x 19.5-inches
465 x 453 x 495 mm
23.4  x  20.5 x 28.7-inches
595 x  520 x  727mm
Weight153.9 lbs (69.8kg)102.1 lbs (46.3kg)
Included AccessoriesProtective non-resonant extra-thick ABS grille frame with fabric mesh cover
Iso-elastomer feet
3 Foam port tuning plugs
Extra heavy-duty, high current 6’ power cord
 Quick Start Guide
Protective non-resonant extra-thick ABS grille frame with fabric mesh cover·Iso-elastomer feet
 Quick Start Guide
SVS SB-5000 Subwoofer Driver Parts Exploded
SVS SB-5000
SVS PB-5000 Subwoofer Driver Parts Exploded
SVS PB-5000
More to Come….
As much as the 5000 R|Evolution subwoofers offer, a forthcoming update will include Auto EQ Subwoofer Room Correction. Using the SVS app and the built-in microphone on a smartphone, the app will be able to implement equalization filters that capitalize on available room gain and optimize in-room frequency response at main listening positions for optimal in-room performance. Auto EQ Subwoofer Room Correction will be available via an over-the-air app and firmware update coming soon.
The Bottom Line
SVS appears to be refreshing its subwoofer line-up from the top-down. That should mean good news for home theater shoppers, as trickle-down technology makes its way down the line at lower price points.
However, with a $500 difference separating the 5000 Series from the flagship 17-Ultra, consumers may have a tough choice deciding.
Pricing & Availability
The new SVS 5000 Series subwoofers will make their debut at AXPONA (Audio Expo North America) in demo suites 1442 and 1444 from April 11 through 13, 2025. Pricing is expected as follows:
SVS SB-5000 (sealed) Subwoofer
  • $1,999.99 (Premium Black Ash Finish)
  • $2,099.99 (Piano Black Finish)
SVS PB-5000 (ported) Subwoofer
  • $2,599.99 (Premium Black Ash Finish)
  • $2,699.99 (Piano Black Finish)
All SVS products are available at www.svsound.com and are backed by a five-year unconditional warranty, 45-day in-home trial, fast and free shipping, expert lifetime support, SoundPoints loyalty program, and all the guarantees of the SVS Customer Bill of Rights.
2 Comments
2 Comments
  1. Antonio Gaspari
    April 9, 2025 at 2:06 pm
    Love this company. Value and performance.
    High-end audio needs more like this.
    Impressive technical capabilities to say the least.
    • Ian White
      April 9, 2025 at 2:21 pm
      Antonio,
      SVS is a really solid company. They know what they are doing. Value and performance. These subwoofers will get some review time soon. Our next podcast is with SVS and it’s well worth listening to.
      IW
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Explore Craft Recordings' Record Store Day 2025 preview featuring exclusive releases from Carla Thomas, Thelonious Monk with Gerry Mulligan, and the Jazz Dispensary Night...
HDTV 4K & 8K TV
HDTV 4K & 8K TV
