SVS Announces 3000 Micro Subwoofer
The smallest subwoofer from SVS combines dual 8-inch drivers with 800-watts of power in a micro sized enclosure for $799.
SVS 3000 Micro Subwoofer Compared to SVS PB-16 Ultra Subwoofer
SVS have announced an exciting new addition to their lineup of affordable home theater subwoofers. The new SVS 3000 Micro subwoofer features fully active dual opposing 8-inch SVS drivers in a compact cabinet that’s less than a foot tall. The $800 subwoofer boasts 800-watt RMS of Class D power with bass output rated down to 23Hz.
SVS 3000 Micro Subwoofer Driver Angle
This announcement comes fresh on the heels of updates to the SVS 1000 Pro Series subwoofer line which are larger and more affordably priced at $499/$599. However, if diminutive size is of most importance, the Micro 3000 seems like a bargain compared to the KEF KC62 subwoofer. Although the KEF is even smaller, it’s also nearly double the price of the Micro 3000.
In regards to pricing, subwoofer shoppers should also note the SVS SB-2000 Pro subwoofer retails for the same $800 price as the Micro 3000. Although the 2000 Pro is larger and will play deeper, you’ll need the extra space for it.
SVS 3000 Micro Subwoofer Lifestyle
SVS Prime Wireless Powered Speakers ($599.99) on desktop with Micro 3000 Subwoofer.
SVS says that engineering a subwoofer capable of output you can feel at the lowest frequencies, while maintaining effective thermal and energy management in a micro-sized enclosure, has always been the challenge for manufacturers. The category has been burdened with weak output, distortion, a disappointing user experience, and uncontrolled movement of the cabinet. Micro subwoofers have even been known to “dance” across a room.
3000 Micro answers the challenge with a potent set of innovations packed into a compact 10-inch cabinet. Starting with the drive units; fully active dual opposing 8-inch SVS drivers unleash heart-pounding low end with pinpoint control. By firing in opposite directions in unison, the mechanical energy transferred to the cabinet is effectively canceled out. This creates a sonically inert enclosure and solves the curse of micro subwoofers moving around a room.
SVS 3000 Micro Subwoofer Exploded
“Home theater and HiFi lovers have been waiting for a lifestyle-friendly subwoofer that can fit anywhere and actually deliver a reference listening experience. I’m so proud of what our engineering team accomplished, a micro subwoofer worthy of the name SVS.”Gary Yacoubian, SVS President
The active dual drivers are connected in parallel to a single power amplifier. Both drivers receive the exact same amount of current ensuring precise, accurate bass, without distortion. A progressive inverted surround allows for maximum excursion and is critical to moving massive amounts of air and generating sound pressure levels you can feel at the deepest frequencies from such a small enclosure.
Drivers are only potential, of course, and require an equally capable amplifier. SVS engineers applied groundbreaking innovations from the reference SVS 16-Ultra subwoofers to create the Sledge STA-800D2 amplifier with discrete MOSFET output that combines the high current output of MOSFET transistors with Class D efficiency. Boasting an impressive 800 watts RMS and 2,500+ watts peak power and vanishingly low distortion, the unique design unleashes nearly limitless on-demand current to the active dual driver array, while maintaining pinpoint control. 3000 Micro handles demanding bass content effortlessly, while always remaining accurate in frequency response.
Harnessing the massive power of the Sledge amplifier is a 50 MHz Analog Devices Audio DSP with 56-bit filtering, claiming to be the most sophisticated DSP engine available in a home audio subwoofer. The abundant processing power maintains pristine sound quality that’s faithful to the source material through advanced in-room tuning, optimized frequency response curves, powerful DSP controls and more. This level of processing power is an anomaly at this price range and plays a key role in maximizing the 3000 Micro subwoofer’s real-world potential.
SVS 3000 Micro Subwoofer White with phone app
3000 Micro also features convenient control and custom presets via the SVS subwoofer DSP smartphone app for Apple, Android and Amazon devices. The SVS subwoofer app is the most convenient way to control volume, access multiple DSP functions and program custom presets for one-touch tuning optimized for music, movies, gaming, and more. Uses can also adjust crossover frequencies, a three-band parametric EQ, polarity, room gain and more, all from their favorite seat.
The SVS subwoofer app allows naming of subwoofers in the case of duals, and custom presets for easy switching between listening modes. Users can also place in standby mode and reset to factory settings. Bluetooth connectivity allows full control, even when the subwoofer is out of sight and bi-directional feedback shows adjustments in real time on both the app and rear panel subwoofer interface.
Subwoofers capable of such extreme performance levels require equally formidable cabinet designs so the 3000 Micro features extra thick MDF side baffles and rigid internal bracing to support the active dual driver assembly and to ensure an acoustically inert environment. The highly reinforced internal design eliminates any chance of coloration or resonance from the cabinet, even when the deepest low frequencies are played at high volume. SVS opted against using a passive radiator dual driver design deployed in many micro subwoofers because of their reputation for bloated, one-note bass.
SVS 3000 Micro Subwoofer in Black and White
“For too long, micro subwoofers have been imposters in the category with disappointing output, compromised sound quality, flawed engineering, and other performance issues. In the world of subwoofers, the 3000 Micro is like a magic trick. Its massive output, impressive extension, and pinpoint accuracy from such a small enclosure is unprecedented and further cements SVS’ legacy of setting the performance bar with every new product.”Gary Yacoubian, SVS President
Price & Availability
The SVS 3000 Micro subwoofer is available now for $799.99 at svsound.com in Piano Gloss Black or Piano Gloss White finish.
SVS 3000 Micro Quick Specs:
  • Frequency Response:
    • 23Hz to 240Hz +/-3 dB
  • Dimensions (including grilles and feet):
    • 10.9” (H) 11.7” (W) 10.7” (D)
SVS 3000 Micro Subwoofer Rear
About SVS
Headquartered in Youngstown, Ohio, SVS high performance subwoofers, speakers and audio accessories deliver thrilling and immersive audio experiences and unmatched performance for the price. SVS engages customers worldwide through direct and retail sales channels and offers Sound Experts technical support seven days a week via phone, web, social media, chat, email, in forums and wherever people want to connect.
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
SVS will showcase their flagship Ultra Evolution home theater speaker system for T.H.E. Film Festival movie screenings.
All under $1200, three new Q SUB subwoofers get the most out of Q Acoustics stereo and surround sound speaker systems.
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
Ask an Expert
The ultimate guide to choosing a SVS subwoofer for home theater or high fidelity music listening? All 16 models compared!
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
With a 5,000-lumen light output the Optoma UHZ68LV home theater projector can work with screens up to 300-inches.
