SVS Introduces Three 2000 Pro Series Subwoofers
One step above the SVS entry-level models, the 2000 Pro Series subwoofers feature an all-new 12-inch driver and app control for easy setup.
SVS 2000 Pro Subwoofer Series
SVS today introduced three new 2000 Pro Series subwoofers. Each boasts an all-new 12-inch high-excursion SVS driver and a potent 550 watts RMS, 1,500+ watts peak power Sledge STA-550D amplifier with discrete MOSFET output for effortless, room-energizing bass with pinpoint control and accuracy.
Comprised of the SB-2000 Pro sealed cabinet, PB-2000 Pro ported cabinet, and PC-2000 Pro ported cylinder cabinet models, each new SVS subwoofer features advancements to the driver, amplifier, cabinet and overall user experience that outpace anything available in the industry. SVS says the result is deep and thunderous low frequency output below the threshold of human hearing, with accuracy in frequency response and crisp speed in transients, at a breakthrough price.
Tip: The new 2000 Pro Series replace the 2000 Series (non-pro) models from 2014, which include the SB-2000, PB-2000, and PC-2000.
SVS SB-2000 Pro Subwoofer Amplifier Rear
Powering the 2000 Pro Series is a commanding and sophisticated Sledge STA-550D amplifier that combines the high current output of discrete MOSFETs with Class D efficiency. Boasting an impressive 550 watts RMS and 1,500+ watts peak power and vanishingly low distortion, the unique design unleashes nearly limitless on-demand power while maintaining precise driver control, so the 2000 Pro Series can play effortlessly at reference levels and still achieve accurate frequency response.
Harnessing the massive power of the Sledge amplifier is a 50 MHz Analog Devices Audio DSP with 56-bit filtering, the most sophisticated DSP engine ever used in a home subwoofer. The abundant processing power maintains pristine sound quality that’s true to the source material through advanced in-room tuning, optimized frequency response curves, powerful DSP controls and more.
SVS 2000 Pro Subwoofer Driver Detail
New 12-inch driver.
Drivers in the SVS 2000 Pro subwoofers are completely new designs and built for serious output as well as finesse and accuracy. The proprietary SVS design features a dual ferrite magnet motor assembly with long-throw parabolic surround for extreme excursion with room-pressurizing SPLs. A lightweight and rigid aluminum vented cone with composite fiber dustcap moves immense amounts of air to create tactile sonic energy without losing control. The result is accurate response, even at the most intense listening levels.
Launched originally with the flagship SVS 16-Ultra subwoofers, the 2000 Pro also features convenient control and custom presets via the SVS subwoofer DSP smartphone app for Apple, Android and Amazon devices. The SVS app is the most convenient way to control volume, access multiple DSP functions and program custom presets for one-touch tuning optimized for music, movies, gaming, and more. Uses can also adjust crossover frequencies, a three-band parametric EQ, polarity, room gain and more, all from their favorite seat.
The SVS subwoofer app also allows advanced customization so you can name your subwoofer for easy preset switching, choose the subwoofer standby mode and reset the subwoofer to factory settings. Bluetooth connectivity allows full control, even when the subwoofer is out of sight and bi-directional feedback shows adjustments in real time on both the app and rear panel subwoofer interface.
Subwoofers capable of such extreme performance levels require equally formidable cabinet designs so the 2000 Pro Series are built with an extra thick MDF front baffle and rigid internal bracing to support the drive unit and to ensure an acoustically inert environment. The highly reinforced internal design eliminates any chance of coloration or resonance from the cabinet, even when the deepest low frequencies are played at reference levels.
“Our engineers obsessed over making the 2000 Pro Series a truly breakout product line since we’re replacing the most popular subwoofer models in our company’s history,” said Gary Yacoubian, SVS President and Managing Partner. “We reimagined every aspect of the 2000 Pro design, from driver and amp to cabinet and control. By deploying the most advanced technology from our flagship models with new innovations, we’ve achieved reference performance at a lower price range than ever before. They are a true reflection of the passion we have for creating world-class audio experiences.”
Yacoubian continued, “More people than ever can now enjoy astonishing output, deep bass extension below the limits of human hearing, pinpoint accuracy and all the immersive thrills of a world-class subwoofer.”
SVS 2000 Pro Series
SVS SB-2000 Pro Subwoofer Lifestyle
SVS SB-2000 Pro
SB-2000 Pro Sealed Cabinet Subwoofer
Jaw-dropping deep bass extension and massive output with stunning musicality that will delight both audiophiles and home theater fans. Reference subwoofer performance has never been available near this price from a cabinet of this size, ever.
  • Frequency Response:
    • 19Hz to 240Hz +/-3 dB
SVS PB-2000 Pro Subwoofer Lifestyle
SVS PB-2000 Pro
PB-2000 Pro Ported Cabinet Subwoofer
Room-shaking output and subterranean low frequency extension down to 16 Hz. Breathtakingly forceful yet always accurate in frequency response. Dual port design maximizes airflow and driver motion while eliminating potential for port turbulence.
    • 16Hz to 290Hz +/-3dB (standard mode)
    • 17Hz to 290Hz +/-3dB (sealed mode)
PC-2000 Pro Ported Cylinder Cabinet Subwoofer
Iconic cylinder design uses cabinet height to reduce footprint while delivering the immense output and low frequency extension of a larger subwoofer. Saves floorspace while delivering deep, earth-shaking output with stunning refinement. Comes standard with SVS SoundPath Subwoofer Isolation System.
Price & Availability
2022 Update: All prices have increased since original launch in 2019:
  • SB-2000 Pro:
    • Premium Black Ash – $799.99 $899.99
    • Piano Gloss Black – $899.99 $999.99
  • PB-2000 Pro:
  • PC-2000 Pro:
    • Piano Gloss Black Top Cap – $949.99 $1,099.99
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
SVS will showcase their flagship Ultra Evolution home theater speaker system for T.H.E. Film Festival movie screenings.
Ask an Expert
The ultimate guide to choosing a SVS subwoofer for home theater or high fidelity music listening? All 16 models compared!
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
