New SVS 17-inch Subwoofer Will Rock Your World: CEDIA 2024 [Updated]
Those who want to fill a large living room or home theater with deep gut-wrenching bass will rejoice at the news of a new SVS flagship subwoofer that can reach below the limits of human hearing..
SVS 17-Ultra R|EVOLUTION Subwoofers
Update: SVS officially released its new 17-Ultra R|Evolution Series Subwoofers on October 1, 2024. Final specifications and new photos have been added to the article.
Speaker maker SVS likes to surprise its fans and customers with new products at trade shows like CES and CEDIA Expo. At CES 2024, it was their new flagship speaker line, the Ultra Evolution series. This week at CEDIA Expo 2024 in Denver, the company showed off their latest surprise: a 17-inch beast of a subwoofer that can extend all the way down to 12 Hz (±3dB) in its ported version and 15 Hz in the smaller sealed version.
Note: the company initially claimed a low frequency response of 8 Hz on the ported version and 11 Hz on the sealed version, but the productions versions are rated down to 12 Hz with two ports open (ported version) and 15 Hz for the sealed version, each at -3dB.
SVS SB17 and PB17 Ultra Revolution Subwoofers
SVS SB17 (left) and PB17 (right) Ultra R|Evolution Subwoofers
The new models are the SB17 Ultra R|Evolution subwoofer ($2,499) for the sealed version and the PB17 Ultra R|Evolution subwoofer ($2,999) for the larger ported version. We’ll refer to them as Ultra Revolution because it’s simpler. Apparently they were going to name them Ultra Evolution to match the flagship speaker line but some car audio company claimed a copyright on that term so they made a last-minute change.
While the human ear only perceives sound down to about 20 Hz, sounds in nature can extend below that and a subwoofer that can extend below the reach of human hearing can create a more impactful bass experience that you can not just hear but feel in your core.
SVS SB17 Ultra R|Evolution Subwoofer (sealed) at CEDIA 2024
SVS SB17 Ultra Revolution at CEDIA Expo 2024
SVS PB17-Ultra Subwoofer Cutaway at CEDIA 2024
CEDIA Expo 2024 visitors were treated to a cutaway version of the SVS PB17 subwoofer exposing the advanced cabinet design and components.
We got to hear a demo of the ported version and the bass was not just extended but tuneful and precise. Stereo music tracks and immersive Dolby Atmos movie clips took on a new dimension of realism and impact with a pair of the 17-inch subs joining the new Ultra Evolution loudspeakers in an impressive-sounding 5.2.2 channel home theater set up.
Both versions of the Ultra Revolution sub use the same all-new 17-inch driver, DSP and amplifier platform. The subs feature dual voice coils and each voice coil has its own dedicated amplifier for a true dual mono design. The DSP (digital signal processing) on each sub is optimized for the specific enclosure type (ported or sealed) with five times the processing power of its predecessor. And each sub features fully regulated power supplies.
SVS 17-Ultra Revolution Subwoofer Drivers
SVS 17-Ultra R|Evolution Subwoofer Drivers
At the show, the company hadn’t provided final specifications, but we are including what was printed on their sign (above). These specs are subject to change as the unit goes into production. Production specs are included below.
  • High-excursion 17″ SVS driver with dual 8″ voice coil design
  • 2,800 Watt RMS, 6,000 Watt Peak Power with Discrete MOSFET Output*
  • SVS Auto Room Correction with Outboard Microphone
  • Subwoofer Control Smartphone app with 6 PEQs, custom presets and advanced calibration tools.
* Final amplifier power specifications have not been released due to new FTC requirements. However, we’re told power is considerably more than 16-Ultra subwoofers.
SVS CEO Gary Yacoubian and VP of Marketing Nick Brown unveil the new SVS 17-Ultra R|Evolution subwoofer series at CEDIA Expo 2024.
According to SVS CEO Gary Yacoubian, “The outcome of all this design and development is the deepest low frequency extension we’ve ever had in a subwoofer as well as the highest output, but still with the same delicacy, refinement and musicality that our customers have come to expect from SVS.”
The 17-Ultra Revolution subwoofers will be the company’s first to support Auto Room EQ, so they’ll reach their peak performance in your specific listening room, living room or home theater. This may not be delivered at launch but will likely come in a future app update. SVS says that future subwoofer products will also feature Auto Room EQ.
Specifications (Updated for Final Production):
SB17PB17
MSRP$2,499$2,999
Cabinet ConfigurationSealedPorted
Driver Size17″17″
AmplifierSTA-2800 Class DSTA-2800 Class D
Useable Low Frequency Extension (-3dB)15 Hz12 Hz (extended mode, two ports open)
14 Hz (standard mode, all ports open)
Max Low Frequency Output at 30Hz132.3 dB137.1 dB
Frequency Response ±3dB15Hz to 320Hz14Hz to 220 Hz (standard mode, all ports open)
12Hz to 220 Hz (extended mode – two ports open)
Port SizeN/A3 x 4″
InputsRCA, XLR, IR, USB (for wireless transmitter)RCA, XLR, IR, USB (for wireless transmitter)
OutputsRCARCA
Standby Modeyesyes
Low Pass Controlyesyes
Low Pass Slope6dB, 12dB, 18dB or 24dB / octave6dB, 12dB, 18dB or 24dB / octave
Phase Control0 – 180 degrees continuous0 – 180 degrees continuous
Parametric Equalizeryesyes
Room Gain Compensationyesyes
Grille MaterialFabric MeshFabric Mesh
5 Year Unconditional Warrantyyesyes
Lifetime Tech Supportyesyes
FinishGloss Black, Black OakGloss Black, Black Oak
Subwoofer Dimensions
(H x W x D)
20″ x 19.5″ x 21.2″25″ x 21.7″ x 29.3″
Weight124 lbs164.7 lbs
SVS SB17 Ultra R|Evolution Subwoofers
SVS SB17 Ultra R|Evolution Component Diagram.
SVS PB17 Ultra R|Evolution
SVS PB17 Ultra R|Evolution Component Diagram.
Price & Availability
The new SVS 17-Ultra R|Evolution subwoofers are available to order as of October 1, 2024 at the following prices:
Tip: SVS 17-Ultra subwoofers replace the 16-Ultra subwoofers (2016 models), which could go on sale to clear out inventory.
You May Also Like:
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Shanling ONIX Zenith XST20 SACD/CD Transport Shanling ONIX Zenith XST20 SACD/CD Transport
CD Players
At $2,399, the Shanling ONIX Zenith XST20 SACD/CD Transport is here to breathe new life into the "dead" audiophile formats of SACD and CD.
Sony's 2025 ULT wireless speaker line-up. Sony's 2025 ULT wireless speaker line-up.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
SVS SB-5000 and PB-5000 R|Evolution Subwoofers SVS SB-5000 and PB-5000 R|Evolution Subwoofers
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
Totem Tribe Tower Thunderbird Speakers Drivers Close-Up Totem Tribe Tower Thunderbird Speakers Drivers Close-Up
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Vertere DG-X Turntable Red Vertere DG-X Turntable Red
With a precision main bearing, cutting-edge motor drive, and advanced Groove Runner X Tonearm, the DG-X delivers unparalleled sound clarity and resonance elimination. Explore...
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
Explore Craft Recordings' Record Store Day 2025 preview featuring exclusive releases from Carla Thomas, Thelonious Monk with Gerry Mulligan, and the Jazz Dispensary Night...
