SurgeX XN120 Eliminator Series Power Conditioner
The XN120 NEMA solution frees up valuable rack space, eliminates unsightly wires, and protects the most demanding AV system
SurgeX announces the XN120, the perfect protection solution for multi-circuit residential AV systems where space is at a premium. This compact 120 Volt / 80 Amp unit is hardwired as a subpanel at the service panel or the equipment room and is designed to provide failsafe protection required for multiple circuits
Engineered with professional grade Advanced Series Mode Surge Elimination Technology and Impedance Tolerant EMI/RFI noise filtering, the XN120 is the only NEMA enclosure protection product in the market that eliminates surges and transients that can degrade AV system performance and shorten service life. The XN120 frees up valuable rack space and eliminates the need for individual powerline conditioners. In most installations, there are panels located in each room that, until now, have needed to be protected separately. But, with the XN120, there is no need to protect each individual panel with a powerline conditioner at every site. When the panels are connected to a single circuit and fed through the XN120, the SurgeX unit will protect each panel on that circuit. There’s no in wall extension cords, nor individual units to install and maintain. One XN120 circuit will protect an average of 8 panels. In addition, every outlet powered by the XN120 is protected even though there is no PLC at the rack.
“The XN120 frees up the valuable rack space that you didn’t have before,” said Rick Komendera, Vice President of Sales for SurgeX. “It protects and conditions from either the equipment room, or the demarcation and acts just like separate subpanel for your AV system. There’s no in wall extension cords, nor multiple individual units to maintain.”
As with all SurgeX products, the XN120 boasts Advanced Series Mode Surge Elimination Technology and Impedance Tolerant EMI/RFI noise filtering which eliminates all surges without the side effects that come with traditional surge suppression products. Unlike sacrificial MOV based surge protectors, the XN120 completely eliminates ALL surges up to 6,000 Volts/3000 Amps without producing disturbances that can degrade the performance and shorten the service life of an A/V system. Because of this technology, installers have the confidence that their power protection unit will actually protect the equipment they are installing and not degrade or damage it over time.
With SurgeX A-1-1 Certified Advanced Series Mode technology, equipment will run better, sound better, and p icture quality will improve in the blink of an eye. SurgeX has recently extended its industry leading warranty from ten to now an industry leading eleven year Connected Warranty which not only protects the SurgeX equipment, but also every device that is plugged in to a SurgeX product.
About SurgeX
SurgeX is the leading manufacturer of AC power conditioning and surge elimination products, offering a complete line of AC power solutions for protection, power conditioning, and control of sensitive electrical and electronic equipment designed to suit every application. The company’s patented Advanced Series Mode protection technology sets SurgeX apart from its competition and is the only product that absorbs and eliminates surges, rather than using shunt mode surge suppression. Its leadership position stems from advanced engineering and commitment to provide the best products, customer service, and technical support in the industry — all backed by a dedicated team of professionals and a best in class 10 year warranty. SurgeX is owned and operated by Electronic Systems Protection, Inc. and all products are manufactured in Zebulon, North Carolina, and are distributed in over 50 countries.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
