SunBriteTV 4630HD Outdoor LCD HDTV
SunBriteTV has announced the 4630HD 46-inch full-HD 1080p all-weather outdoor LCD HDTV that is designed with outdoor-rated ASA plastic resin and integrated speakers. The resin exterior protects the internal TV components from rain, dirt, insects and other outdoor elements. Built into the exterior is an anti-reflective, impact- and scratch-resistant window that protects the 46″ full-HD 1080p LCD screen with 4000:1 contrast ratio. The integrated 20-watt speakers and user-friendly operating controls are sealed against rain and moisture.
The TV's internal climate control consists of a filtered multi-fan airflow system that quietly keeps the unit cool in temperatures up to 122 degrees. A thermostatic heater automatically protects the TV from damage in external temperatures to -24 degrees while at the same time controls humidity and condensation.
SunBriteTV's innovative watertight cable entry system and cable pass-through design ensures quick and easy hook-up to a wide selection of video inputs including four HDMI connections, component, VGA, S-Video, composite, RF and discreet IR control. RS232 is available as an optional item. Model 4630HD ships with SunBriteTV's weather-proof remote control and two-year residential in-factory, parts and labor limited warranty.
“Incorporating SunBriteTV's signature all-
weather feature-set, we've designed a sleek and
lower-cost outdoor TV, without compromising
the durability and quality that our installers and
customers have learned to trust.”
— Lynn Stearn, SunBriteTV's VP of Marketing
Price and Availability
The SunBriteTV 4630HD Outdoor LCD HDTV is available immediately for $4,195.
Installation
For optimum viewing, SunBriteTV offers a full complement of ceiling mounts and articulating and tilt wall mounts. For additional placement choices, a deck/planter pole mount is also available. The pole can be set in concrete, or bolted directly to a flat surface such as a patio or pool deck. The pole and supporting flange are made from heavy-gauge aluminum for the 22″ and 32″ models and zinc plated steel for the 46″ and 55″ models and are powder-coated to eliminate corrosion. All wall mount and deck planter poles are equipped with stainless steel hardware.
SubBrite Product Line
SunBriteTV's product line offering is divided into two subsets, the Pro-Line series and the HD-Line series. The Pro-Line series includes models 5510HD, 4610HD, 3220HD and 2220HD. These 55-, 46-, 32- and 22-inch models (respectively) are engineered with corrosion-resistant powder-coated aluminum exteriors that protect the inner workings of the TV from rain, snow, dust, insects and extreme temperature ranges. They are equipped with detachable speaker modules that can be removed when the TV is hooked up to an external speaker system. The four models are similar in design and aesthetically work well together in projects that require different size specifications.
The Pro-Line models are ideal for high-end residential and commercial installations where whole-house control systems and networking may be required. To simplify integration, the Pro-Line models feature RS232 and discrete IR input control functions. For networking applications, the Pro Line models can be modified with SunBriteTV's Internal Media Compartment and Cable Kit that customizes the TV to accommodate networking hardware.
  • Model 5510HD, a 55-inch full-HD 1080p with 120Hz refresh rate is offered at $6,795
  • Model 4610HD, a 46-inch full-HD 1080p LCD TV is offered at $4,895
  • Model 3220HD is offered at $2,595
  • Model 2220HD is offered at $2,095
The SunBriteTV HD-Line series includes 32-inch Model 3230HD and 46-inch Model 4630HD. Positioned to target residential installations and budget-minded commercial installations, the HD Line is engineered with outdoor-rated ASA plastic resin and integrated speakers.
  • Model 3230HD is a 32-inch 1080i HD LCD TV at $2,095
  • Model 4630HD, a full-HD 1080p LCD TV, is offered at $4,195
The entire SunBriteTV product line is engineered with the company's proprietary all-weather outdoor feature set that protects the TV from rain, dust, insects and extreme temperatures. They carry an in-factory parts and labor Limited Warranty for residential installations that protects the TV for two full years from the date of purchase.
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
