Preview: Sun Audio’s Purified 4 Desktop Speaker System Comes in 4 Variations
Priced from $7,559, Sun Audio extends its Purified 4 modular speaker concept to the desktop with an all-in-one system.
Sun Audio Purified 4 Desktop Speaker System Front
In March 2024, we reported on the release of the very unique Sun Audio Purified 4 Modular Speaker. Now, as a follow-up, Sun Audio has released a smaller version designed for desktop use simply called Purified 4 Desktop.
The Purified 4 Desktop is a complete table-top audio solution which combines a pair of speakers, a Nord DSP-DAC NCAS500MP Amplifier, and Atohm 9 passive subwoofer.
Purified 4 Speaker (Desktop Version)
Sun Audio Purified 4 Desktop Speaker System Rear
The desktop version of the Purified 4 is similar to the floor stander we reported on previously, except for the tripod stand, which is much smaller so that it can be placed on a typical desk or credenza.
The Purified 4 Desktop is available in four variants with PURIFI 4-inch woofers and BlieSMa 25mm tweeters. Woofers are available in either fiber mix or aluminum, and its dome tweeter can be made of Aluminum-Magnesium Alloy or Beryllium. Every variant includes a crossover profile tuned for optimal tonal balance. The spherical-shaped mid-woofer enclosure enables an exceptional linear on- and off-axis response.
We were told the fiber mix woofer with Beryllium tweeter offers the most ‘organic and colorful’ sound which is especially good with world, baroque and various jazz. Although, Sun Audio also says the aluminum woofer and tweeter are more energetic or ‘electrifying’ for electronic and rock.
Sun Audio Purified 4 Desktop Speaker Angle
Tweeter Module
  • Tweeter Material: BlieSMa Aluminum-Magnesium or Beryllium
  • Enclosure Material: CNC machined solid aluminum
  • Finish: Jet Black powder coated
  • Dimensions: 178 mm diameter, 30 mm depth
  • Wiring: QED OFC, with WBT push-on connectors and threaded protection cover
Woofer Module
  • Surface Cover Options: Bloodwood solid wood or Black thermoplastic cover, sandwiched between a Jet Black powder-coated aluminum front and rear baffle
  • Shape: Spherical outside, cylindrical inside
  • Driver Options: PURIFI 4″ Ultra Low Distortion Extended Woofer (OEM), with PP-coated paper/fiber mix or aluminum cone
  • Impedance: 4Ω
  • Sensitivity (2.83Vrms/1m): 84dB
  • Long-term Maximum Power: 200W
  • Diameter: 222 mm
  • Loudspeaker Terminals: WBT 703Cu & WBT 718 assembly
  • Internal Wiring: QED OFC
Dimensions (Speaker w/Stand)
  • Height: 409 mm (16.1 in)
  • Width:  178 mm (7 in)
  • Depth: 191 mm (7.5 in)
Atohm 9 Passive Subwoofer
Sun Audio Atohm 9 Passive Subwoofer
The next model in the new line-up is the rather compact Atohm 9 (9-inch) passive subwoofer. The subwoofer incorporates a sealed aluminum enclosure with an internal volume of only 8.5 liters. With a minimal industrial look and black powder-coated finish, it is designed to blend into most interiors.
For more audio output, users can stack multiple subs. Since the subs are passive, depending on the capacity of the amplifier used, two to three units can be configured in parallel. With an ANSI/CEA2010-B rating, the Atohm 9 has an SPL rating of 110dB (1m), and an 82dB sensitivity. The Atohm 9 can handle a peak power of 1200 watts. The Atohm 9 is sold in pairs.
Atohm 9 Specifications
  • Shape: Cylindrical
  • Enclosure Material: Aluminum
  • Surface Finish: Powder coating Jet Black (RAL 9005)
  • Driver: 9 inch ATOHM® LD230 TDR 08M
  • Impedance: 8Ω
  • Power Handling: 300W RMS
  • Peak Power: 1200W
  • Sensitivity @ 2.83V: 82dB [1M]
  • Diameter (cylinder): 260 mm
  • Front & Rear Baffle: 30 mm
  • External Net Volume: 16 liter
  • Internal Volume (Vb): 8.5 liter
  • Feet: Isolating Screw-in rubber feet (M8)
  • Grill: Acoustically transparent fabric
  • Connection Terminals: WBT 703Cu & WBT 718 assembly
  • Dimensions (HxWxD): 296 x 290 x 270 mm (11.65 x 11.40 x 10.6 in)
  • Weight: 18.3 kg (40 lbs 5 oz)
To round out the system, Sun Audio has introduced the Nord DSP-DAC NCAS500MP Amplifier. This is a Hypex NCore amplifier with an onboard Hypex DSP engine and DAC is built in cooperation with UK-based Nord Acoustics
The DSP profile for the Purified 4 loudspeakers is pre-loaded into the Nord making the combination easy to set up and use. The Nord DSP-DAC NCAS500MP provides digital and analog inputs, powered outputs for the tweeters and mid-woofers, and subwoofer outputs (RCA).
Nord DSP-DAC NCAS500MP Amplifier Rear
Nord DSP-DAC NCAS500MP Specifications
  • Technology: NCORE®, Hypex NCore® NCAS500MP two-channel module
  • DSP Engine: Hypex DSP3-213
  • DSP Profiles: 3 Pre-installed presets).
  • Outputs: 3 (tweeter, mid-woofer, and subwoofer on RCA)
  • Analog Inputs: XLR and RCA
  • Digital Inputs: XLR and Optical
  • Power Output (4Ω): 440W (mid-woofer) + 120W (tweeter)
  • Impedance: 47K Ohms Input Impedance, low output impedance
  • Efficiency: 92%
  • THD: 0.007% + 0.005%
  • S/N Ratio: 119dB + 113dB
  • Voltage Gain: 26dB
  • Input Sensitivity: 2.3Vrms
  • Master – Slave operation: Yes
  • PSU (Power Supply Unit): 650W
  • Binding Posts: WBT-0703 Cu nextgen™
  • Color: Black
  • Dimensions (WxHxD): 240 x 280 x 102 mm (9.4 x 11 x 5 in)
  • Weight 6Kg (13 lbs 4 oz)
Tip: A remote control is included in the package.
Initial Impressions
There’s no denying Sun Audio’s all-in-one desktop speaker system offers impressive specifications and a unique design. And with 4 ways to mix-and-match drivers, audiophiles are more likely to find a combination to meet their taste. However, given its high asking price, we wonder how it competes with active studio monitor setups in the same price range.
Sun Audio Purified 4 Desktop Amp/Speaker Pair Front
Pricing & Availability
Purified Speakers and related components are available directly through Sun Audio. All products are shipping in all variations and all are built upon order:
Tip: The approximate total cost for the entire system is listed at $7,559 to $8,576.
Related Reading
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
DAPs
With support for 32-bit PCM, DSD, Roon, LDAC, aptX HD, and a brand new docking cradle, the Astell&Kern PD10 DAP might replace your streamer.
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
On this episode Caleb Denison, formerly of Digital Trends, shares his thoughts on 2025 TVs along with the launch of his new YouTube channel,...
HDTV 4K & 8K TV
DTS:X is an immersive surround sound format that is both similar to and different from Dolby Atmos. Find out how DTS:X and its variations...
Does it make sense to spend more than most audiophiles spend on their entire system on a little box that makes your power clean?
HDTV 4K & 8K TV
The well known TV reviewer and tech journalist extraordinaire has announced the launch of a new company, CD Creative Media LLC and a new...
