Sun Audio Purified 4 Modular Loudspeakers are Future Proof
Sun Audio offers new approach to audiophile system building. Bring your own crossover, amplifier and customize all settings.
Sunaudio Purified 4 Loudspeakers
Netherlands-based Sun Audio is offering up a new speaker that takes a different approach. Instead of joining the “all in one box” trend in powered speakers, their new Purified 4 depends on an external crossover and amplification. As Sun Audio puts it, the Purified 4 is “Active Ready.”
To put it another way, the Purified 4 provides the speaker drivers, enclosure, and stand, and the buyer has to provide their own crossover and amp to make it work.
Although Sun Audio’s approach is very uncommon among home audio, many professional loudspeaker systems work this way. However, in those cases the same brand’s amp and controllers are usually required. As an example, all Theory Audio Design loudspeakers separate electronics from speaker cabinet.
Active Ready Advantages
Sun Audio feels the main advantage of keeping the electronics and software (e.g. power supply, amplifiers, DSP, DRC (Dynamic Range Compression), DAC/ADC, streamer) outside the speaker is that listeners can use the hardware and software they prefer and upgrade as they please. Another advantage is that the more ventilated and less resonant environment of the dedicated external enclosures reduces the mechanical wear of the electronics. As long as the speaker drivers remain undamaged, the loudspeakers are essentially future proof.
Sunaudio Purified 4 Loudspeaker Woofer
Enclosure Design
Purified 4’s enclosure incorporates a spherical and rounded design. This supports a smooth sound radiation pattern. Using a full aluminum enclosure minimizes unwanted resonances. A dedicated steel tripod loudspeaker stand is included with the Purified 4.
Purified 4 Speaker Driver Options
Woofer Options: The Purified 4 provides 4-inch low-distortion woofer drivers in Fiber Mix or Aluminum.
Midrange Options: The Purified 4 provides 4-inch low-distortion midrange drivers in Fiber Mix or Aluminum (BlieSMA).
Tweeter Options: The Purified 4 provides a selection of five tweeters with the following materials
  • 25mm Aluminum-Magnesium Alloy Dome.
  • 25mm Beryllium Dome.
  • 25mm Silk Dome Tweeter.
  • 34mm Aluminum-Magnesium Alloy Dome
  • 34mm Beryllium Dome
Sunaudio Purified 4 Loudspeaker Tweeter
Tip: Speaker impedance is 4 ohms
Crossover Guidance
To guide users as to how to implement their own crossover, Sun Audio provides a crossover profile tuned for optimal performance in the listening window and estimated in-room response.
In addition, the measurement data set for the Purified 4 offers the advanced user the opportunity to fine-tune the crossover and PEQ (Parametric Equalizer) used to their specific requirements.
For further crossover guidance and measurement examples, refer to the Purified 4 Measurements Page
Sunaudio Purified 4 Loudspeakers Front Angle
Included Stand
  • Tri-Pod Design
  • Steel frame with rubber dampers on top and bottom
  • Mounting hole to secure the spherical woofer or midrange module
  • Jet Black powder coated
  • Demountable design, two parts
  • Fixed WBT-703Cu pole terminals for the tweeter module
Dimensions with Stand
  • Height (with speakers mounted): 88 cm (34.6-inches)
  • Depth: 28 cm (11-inches)
  • Width (base): 31 cm (12.2-inches
Sunaudio Purified 4 Loudspeaker Rear
Price and Availability
The Sun Audio Purified 4 is available in 40 variant priced from $3,200/pair to $4,729/pair (USD) through Sun Audio in hardwood or high-quality black plastic.
Where to buy: sunaudio.com
2 Comments
2 Comments
  1. GM
    March 25, 2024 at 11:58 pm
    34.6″ high overall. So the tweeter is no more than ~26″ above the floor?
    Too low. My ears are at 42″ while seated. One would be better off sitting on the floor.
    • Ian White
      March 26, 2024 at 5:34 pm
      Gordon,
      As someone who is 6’3″, I totally get that. However, the pair of Q Acoustics M40 Wireless Speakers that are currently in my den in NJ are only 29″ tall — and that has not been an issue so far. I was rather skeptical myself and I even tried them on 2″ thick concrete bases. The top end is clear, spacious, and very open sounding on these even with the height issue. And they are not angled/tilted upwards.
      The on-axis dispersion is very good. The off-axis (sitting off to the side) is rather different.
      Best,
      Ian White
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
