Sumiko Wellfleet MM Cartridge Aims to Elevate Your Vinyl Listening Experience
Can the $450 Sumiko Wellfleet MM Cartridge dethrone the Ortofon 2M Bronze and Nagaoka MP-200 for less money? Stay tuned.
Sumiko Wellfleet MM Phono Cartridge
If you doubt that vinyl is on solid ground in 2022, one only needs to look at the growing number of affordable high-end phono cartridges being introduced to understand that consumers are starting to really wonder just how good their new record collection can actually sound. Brands like Sumiko have understood for a long time that music listeners often take baby steps before opening their wallet for the first time on a high-end turntable like the Pro-Ject Debut PRO and the brand new Sumiko Wellfleet MM Phono Cartridge.
I recently reviewed the Debut PRO and found it to be a surprisingly strong performer below $1,100 — it might be as good as my fully tricked out Thorens TD-145 running a Dynavector 10×5 low output moving coil cartridge. I like the supplied Sumiko cartridge but I suspect the Wellfleet or even the Sumiko Blue Point No. 3 could take this table to another level.
Eric Pye recently reviewed the Sumiko Blue Point No. 3 cartridge and was completely smitten by its tonal balance and excellent detail retrieval.
The Japanese cartridge manufacturer sells a lot more of its Rainier MM carts than its expensive MC offerings for the simple reason that most consumers getting into vinyl for the first time are buying integrated amplifiers with a MM phono stage and consider $350 to be their maximum ceiling for a phono cartridge.
Sumiko Wellfleet MM Phono Cartridge Angle
Sumiko Wellfleet
The $449 Sumiko Wellfleet MM Cartridge pushes that price ceiling higher but the early word is that the new nude elliptical stylus MM cartridge is quite the overachiever below $500 — which puts it in direct competition with the Ortofon 2M Bronze, Nagaoka MP-200, and Grado Labs Timbre Series Platinum3 cartridges.
Sumiko has applied and upgraded its award-winning design of the Moonstone
cartridge, retuning the suspension for optimal performance of a nude elliptical diamond with the existing generator and resonance-optimized housing found in the rest of the Rainier series.
The Sumiko Wellfleet utilizes a highly polished nude elliptical stylus, eliminating the bonding between the stylus tip and shank. With the new assembly, excessive mass in the shank is cut away to further reduce tip mass, resulting in a faster,
more direct, and more accurate response of the stylus’ movement by the cantilever and magnet.
Sumiko Wellfleet MM Phono Cartridge Up
This series of MM carts offer between 2.5 mV and 5 mV of output and we’re clarifying that detail in regard to the Sumiko Wellfleet. The Moonstone is around 2.5 mV while the Rainier is almost 5 mV.
If the Sumiko Wellfleet can deliver most of the performance of the Amethyst for $150 less — that might make it quite the bargain.
Look for our review of the Sumiko Wellfleet in the next 2 months.
For more information: sumikophonocartridges.com
Related reading: Best Phono Cartridges
1 Comment
1 Comment
  1. Steven Denfeld
    February 17, 2022 at 4:49 pm
    Will be shopping around for a solid upgrade from my 2M Red this spring and will be definitely curious about the Wellfleet in comparison to the Audio-Technical VMxxxML carts. I hope the compliance will be high enough to be a good match for my 6-ish gram tonearm. Looking forward to the review.
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
$449 or $599, find out which Sumiko moving magnet phono cartridge is right for you?
Ask an Expert
Are you a recent convert to vinyl playback? Are you records not sounding as great as you would have hoped? Your phono cartridge installation...
Our favorite audiophile turntables in 2023 include Pro-Ject, Rega, Technics, Orbit and more.
Pro-Ject adds balanced connectivity with Pick it Pro MM cartridge to its award-winning Debut PRO Turntable for only $100 more.
Does one need to spend more than $500 for a phono cartridge? Grado, Sumiko, and Goldring would beg to differ.
We've tested the Q Acoustics 5050 Floorstanding Loudspeakers with a range of equipment. Find out what works best.
Is the Rotel A12MKII the ideal amplifier to build a $3,000 stereo system around with 2 great sources? I would say you're foolish not...
