Studio Experiences Affordable Matinee 1HD Designed to Excite any Home Theater Enthusiast
Studio Experience Introduces New Home Theater Projector
Affordable Matinee 1HD designed to excite any home theater enthusiast
Poulsbo, WA (November 2002)–Studio Experience, the division of BOXLIGHT specializing in advanced home theater projectors, is proud to present the Matinee 1HD–the first wide screen home theater projector under $2000. This budget-conscious unit will bring the excitement of the big screen into the comfort of your own home.
You will be astonished that such an amazing picture could be created in your very own living room. Featuring true 964 x 544 wide VGA resolution, 800:1 contrast ratio, 700 ANSI lumens, and an incredible price tag this projector rivals the best DLP units on the market. Weighing in at a mere 7.5 lbs the projector can be easily moved from room to room or even over to a friend’s house. The Matinee 1HD has been designed to create an astounding picture in any environment.
The Matinee 1HD is user friendly from the moment it is taken out of the box. A short throw lens allows projection on a large screen even in a small room. The Picture Image Select Function allows you to choose from Standard, Cinema/Real, and Image settings optimized for different video mediums. And during installation the image it is easy to perfectly align on the screen with the horizontal and vertical power lens shift.
The Matinee 1HD believes in being seen and not heard. It is one of the quietest projectors available with a whisper mode of only 28 dB of audible noise, guaranteeing the hum of the fan will never interfere with dialogue.
HDTV/EDTV Compatible, the Matinee 1HD is attuned with 1080i, 1035i, 720p, 575p, 575i, 480p, and 480i standards. Image adjustments are made easy right from the remote with the auto flesh tone, auto gray scale and color temperature adjustment. With the power management function, the projector is energy efficient and saves on lamp life by automatically shutting off if no signal is received for five minutes.
The manual zoom lens eliminates set-up difficulty, and the Digital Keystone Adjustment allows the picture to be adjusted to create a square image in any environment. Use the backlit remote control to check out a scene you just missed, or pause for a break without interrupting the show by turning on the lights.
The Studio Experience Matinee 1HD offers a quality home theater projector, packed with a myriad of features at an affordable price. Flexible enough to be used in a variety of ways this projector is an exceptional choice for any home theater enthusiast.
Along with its own branded line, Studio Experience offers projectors from the best manufacturers in the industry, including BOXLIGHT and SONY. They guarantee optimal brightness and clarity from every projector they sell by featuring only those units with over 700 ANSI lumens and high resolution for the best quality video images for the home theater. Studio experience also sells other components essential for home theater, including plasma displays, projection screens and all-inclusive home theater packages. Studio Experience provides knowledgeable assistance on all of the products that are offered, as well as helpful tips for specific applications and installations.
All projectors purchased from Studio Experience are covered through the company’s exceptional, full 15-day money back guarantee, 30-day upgrade policy, and full manufacturer’s warranty.* Studio Experience offers a 3-year parts and labor warranty on their Cinema 20HD, which can be upgraded for up to five years of total coverage. In addition, a 120-day lamp guarantee is standard on all Studio Experience branded projectors.
Studio Experience offers free 24-hour/7-day-a-week technical support for the life of their products. 180 days Same-as-Cash financing options are also available. More information on Studio Experience’s complete line of home theater products is available via the company’s website, www.studioexperience.com. All products can be ordered by calling 1-800-667-6147.
*This applies to stocked projectors. Conditions do not apply to special order items.
EDITOR’S NOTE: The Studio Experience Matinee 1HD is available for review. If you would like to request a review unit or would like to speak with a Studio Experience representative, please contact Emily Dance or Ginger Vaughan at 206-842-8922 or via
E-mail at emilydance@bainbridge.net or ginger@bainbridge.net .
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
