Stratton Acoustics Announces Element 12 Loudspeaker
For $42,000/pair, the Stratton Acoustics Element 12 offer a reference level stand-mount loudspeaker that’s hand-made in the UK.
Stratton Acoustics Element 12 Loudspeaker Finishes
Stratton Acoustics Ltd, the UK-based manufacturer of the acclaimed, high-end Elypsis 1512 loudspeaker, has launched its new Element 12, a smaller (and more affordable?) 2-way, reflex-loaded design with an integral stand.
The Element 12 was developed by the duo that created the Elypsis 1512 – David Fowler (founder, designer, and manufacturer) and Phil Ward (electro-acoustic engineer).
The goal of the Element 12 is to provide the same performance as the Elypsis 1512 in terms of dynamics, rhythm, and engagement, but housed within a smaller, more easily placeable cabinet.
Stratton Acoustics Element 12 Loudspeaker in Maple and Silver
The Element 12 cabinet is formed from 26mm/46mm bamboo ply panels and incorporates internal bracing. The cabinet houses a single, custom-made 12-inch paper bass/mid driver with dual voice coils and a NeFeB (neodymium-iron-boron) magnet motor system. Twin reflex ports located on the bottom of the speaker are tuned to deliver an in-room response down to 38Hz.
The Element 12 uses the same 29mm (1.2 inch) soft dome tweeter that the Elypsis 1512 does. The tweeter is housed in Stratton’s patented Mechanically Isolated Tweeter Assembly using a NeFeB magnet motor.
Stratton Acoustics Element 12 Loudspeaker in Maple and Silver Rear Top
The speaker cabinet assembly has an integral stand, formed from 3mm thick, powder-coated, structural steel panels – based on Voronoi geometry – all underpinned by a high-gloss bamboo ply and natural cork base.
From David Fowler: “There are many, many forms of addiction,…Ours is simply the desire to continue creating beautifully crafted, artisan-built loudspeakers that nail you to your seat the instant you hear them playing the music you can’t get enough of. In short, we get our ‘fix’ by supplying customers with theirs…
Comparison
Stratton Acoustics Element 12 and Elypsis 1512 Loudspeakers
Element12Elypsis 1512
Speaker TypeTwin bass reflex-loaded, two-way, high-sensitivity passive loudspeaker Quad bass reflex loaded 3-way passive speaker.
Enclosure Fully braced bamboo ply with CNC-machined aluminum trimsBraced Birch Wood
Integrated Stand Folded Voronoi geometry structural panels with a bamboo ply base
Bass Drivers2 x 380mm (15 inches) with paper diaphragm and ferrite motor system.
Ports24
Bass/Mid Driver 1 x 300mm (12 inches) with NeFeB motor, paper diaphragm, and twin voice coils
Midrange Drivers1 x 300mm (12-inch) with hand-doped paper diapraghm and NeFeB Motor system.
Tweeter 29mm (1.2 inch) waveguide loaded NeFeB motor soft dome29mm (1.2 inches) with waveguide-loaded soft dome and NeFeB Motor system.
Crossover Frequency 1.7kHz350Hz and 2.5kHz
Frequency Response 50Hz to 18kHz ±2dB45hz to 18kHz (+/- 2dB)
Low Frequency Cut-off-6dB @ 37Hz -6dB @ 28Hz
Midband Sensitivity (2.83V @ 1m)94dB96dB
Nominal Impedance 8 ohms8 ohms
Electrical Phase< ±45° between 100Hz and 10kHz
Group Delay <10ms above 50Hz <12ms above 40Hz
Amplifier Compatibility Any amplifier will work according to Stratton AcousticsAny amplifier will work according to Stratton Acoustics
EQ OptionsMF and HF +/- 2dB
Connections Bi-wire custom binding posts Tri-wire/Tri Amp Neutrik Speakeron sockets
Dimensions (HWD)1214 x 500 x 596mm (48 in x 19.7 x 23.5 in)876 x 1001 x 515mm (34.5 x 39.4 x 20.3 inches)
Weight47.6kg (105 lbs)140kg (308.6 lbs)
Price£32K, $42K, €38KStarts at £69,000
Available Finishes
Similar to the Elypsis 1512, the Element 12 is available in four high gloss finishes: Piano white with silver, Piano black with Black and Gold, Maple with Silver, and Ziricote with Black and Gold.
Price & Availability
The Element 12 is priced at $42K (£32K or €38K) per pair and is available directly from Stratton Acoustics with shipping (charged at cost) to anywhere in the world.
Note: As of the published date of this article, the Element 12 is not showing on the Stratton Acoustics Website
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
Ready to dive into the dark, twisted world of film noir? Check out the 20 best films, plus where to grab the sharpest Blu-ray,...
While Record Store Day (RSD) is over for now, Mark Smotroff reports on his scores, some of which you still may be able to...
Think you’ve seen it all? These 25 essential American films are the ones every true movie lover should own.
Hi-Fi Components
Goer Dynamics will expand the distribution of Gryphon Audio Designs into Asia and open up opportunities in the luxury car audio sector.
Over-Ear Headphones
Can the Meze Audio POET combine the sound quality of the ELITE series with the compact design of the LIRIC series, thanks to its...
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
