House of Marley’s Stir it Up Lux Turntable Offers Bluetooth Connectivity
This entry-level turntable comes equipped with Bluetooth connectivity, a switchable phono preamp, and Audio-Technica MM Phono Cartridge.
House of Marley EM-JT-010 turntable angle
House of Marley made its name with consumers offering eco-conscious headphones and loudspeakers. The brand new Stir it Up Lux Bluetooth turntable has been unveiled and it comes equipped with an Audio-Technica MM Phono Cartridge, Bluetooth connectivity, and a switchable phono pre-amplifier.
The Stir It Up Lux (Model Number: EM-JT010) honors Bob Marley’s legacy of love for music and the planet by providing an excellent music listening experience with sustainability in mind.
The new Stir it Up Lux features an updated design and upgraded features.
In addition to vinyl record playback, the Stir it Up Lux is equipped with Bluetooth (vr 5.3) connectivity adding flexibility for music playback (allows wireless connection to any Bluetooth speaker).
For added flexibility, the Stir it Up Lux has a switchable phono preamp output. This enables it to physically connect to any amplifier or audio system that has either a dedicated phono input or standard RCA line inputs.
House of Marley EM-JT-010 turntable rear connections
The Stir It Up Lux was created in collaboration with Bob Marley’s family to honor the music legend’s love for music in its purest form.
From Cedella Marley, daughter of Bob Marley and an accomplished singer and entrepreneur: “Vinyl is the most genuine way to listen to your favorite music – there’s no skipping tracks, so you’re listening to the album exactly as the artist intended you to…That’s everything for a musician. Immersing yourself deep in the roots of an album with House of Marley’s new Stir it Up Lux turntable is an unforgettable experience.
House of Marley EM-JT-010 turntable Top
Key Feature Spotlight
  • 45 and 33 RPM speeds
  • Solid, sustainably crafted bamboo plinth
  • Infinitely recyclable glass platter
  • Double-sided Cork slipmat, with zoetrope side (zoetrope works best at 33RPM and 11 Hz or 11 FPS)
  • Belt drive with Auto start/stop
  • Built-in, switchable pre-amp; 3.5mm AUX out and RCA (phono/line) out
  • Replaceable Audio-Technica elliptical stylus (AT-95E) and adjustable counterweight
Turntable Specifications
House of Marley EM-JT-010 turntable speed knob
  • Model Number: EM-JT010
  • Drive Method: Belt
  • Motor: DC Servo Controlled
  • Platter: 8mm Glass with Double-sided Cork Slipmat
  • Nominal Speeds: 33.33 / 45 RPM
  • Wow and Flutter: <.03 %
  • Signal/Noise Ratio (SNR): 50 dB
  • Output Level (Preamp Off): 5mv @1 kHz, -10dB
  • Output Level (Preamp On-Line Output): 250mv @1 kHz, -10dB
  • Weight: 10 lbs/4.5 kg
  • Dimensions: 16.5 x 13.7 x 4.13 in   (42 x 34.8 x 10.5 cm)
  • Power Adapter: Universal 100-240 VAC/50-60Hz
Cartridge Specifications
House of Marley EM-JT-010 turntable phono cartridge.
  • Cartridge Type: Moving Magnet (½-inch mount)
  • Cartridge Model: AT-95E
  • Frequency Response: 20 Hz – 20 kHz.
  • Channel Separation: >20 dB at 1 kHz.
  • Tracking Force: 1.5 – 2.5 g (2 g recommended)
  • Stylus: 0.4 x 0.7 mm elliptical diamond.
  • Cantilever: Alloy tube.
  • Mount: Half-inch.
  • Replacement Stylus: ATN95E.
Included Accessories
House of Marley provides everything you need to get started.
  • Double Sided Cork slipmat
  • Main power adapter with UK, AU, US, and EU plugs
  • RCA to Aux cable
  • Stylus pressure gauge
  • Quick start guide
House of Marley Stir It Up Lux EM-JT010 Turntable Zoetrope Slipmat Design
Sustainability
As stated previously, the Stir It Up Lux Bluetooth Turntable is also about sustainability. Carefully crafted using bamboo, aluminum, glass, and cork, this music must-have harnesses the power of mindfully-sourced materials while delivering a sleek and compact design.
Bamboo is one of the world’s fastest-growing plants which can grow up to a meter in height in just 24 hours – making it an extremely renewable resource.
Aluminum and glass are both infinitely recyclable, while cork is made from stripped-down bark as opposed to cut-down trees.
The anti-slip reversible mat has a cork natural aesthetic on one side, while the flipside has a special Zoetrope design that adds a pop of color and an unexpected animation that elevates your vinyl experience.
Tip: Each purchase contributes to House of Marley’s global give-back initiative, Project Marley, which supports global reforestation through One Tree Planted.
Price and Availability
The Stir it Up Lux is priced at $399.99 and is available at House of Marley, Amazon, and other select retailers.
Tip: Assemble a compact two-channel system with the addition of The House of Marley Duo Bluetooth Speakers (EM-JA019-SB) priced at $169.99 (pr)
House of Marley EM-JT-010 turntable bundle with Bluetooth Speakers
Beats Cables Promo Image
Audio Cables
Networking
Earbuds & In-Ear Headphones
Designed for studio applications the ATH-R70xa and R50x provide audio clarity while providing all-day wearing comfort for less than $400.
Check out our favorite wired over-ear headphones at different price points, from very affordable to cost no-object.
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
At $999, the Audio-Technica AT-ADX3000 open-back headphones use the same driver technology as its flagship AT-ADX5000.
At $999, the Audio-Technica AT-LP8X is a three speed semi-automatic direct drive turntable with AT-VM95E cartridge.
