Take Stereo Audio the Distance with the New TV One-Task Cat 5 Extender
TV One-task has added the 1T-VGAST-CAT-XL, which is capable of sending and then
outputting the stereo audio along with the VGA signal over a distance up to 1000 feet.
MARGATE, Kent, 24th May 2007 — The popular Cat.5 series in the TV One-task line has added the 1T-VGAST-CAT-XL. This unit can send both stereo audio, either from a PC or microphone, and a 1280×1024 VGA resolution image to a maximum distance of 1000 feet.
The unit consists of a transmitter that takes in the Stereo Audio and VGA signal and a receiver which outputs the same Stereo Audio and VGA Signal. This makes it possible to send both signals to a remote location and maintain the Stereo Audio. A VGA loop-thru is provided and there are gain and equalization adjustments at each receiver.
The 1T-VGAST-CAT-XL has a locking DC connector and is RoHS compliant. The suggested retail price for the 1T-VGAST-CAT-XL is £279 (€410) and is available now.
For more information about TV One and their products, please visit their website www.tvone.co.uk. Alternatively you can contact their European Sales and Technical Department on +44 (0) 1843 873311 or at sales.europe@tvone.com.
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
