In-Wall Speakers
Steinway Lyngdorf Releases BWS-110 / DW-1 In-Wall Subwoofers
Enjoy low bass performance down to 30Hz from subwoofers hidden in your wall that are only 4-inches deep.
Steinway & Sons BWS-110 In-Wall Woofer Lifestyle (no grilles)
Steinway Lyngdorf has introduced in-wall subwoofers to complement architectural speakers in its Steinway & Sons and Lyngdorf Audio lines. The passive in-wall woofer is being sold as the Steinway & Sons BWS-100 as well as the Lyngdorf Audio DW-1.
The two models are nearly identical with two slight differences. External branding identifies each model, and each has a different connector type. The Steinway model only works within a closed system with Steinway audio components. Alternatively, the Lyngdorf DW-1 connects via regular speaker cable which allows flexibility to connect third-party audio components as well as Lyngdorf’s own electronics.
Steinway & Sons BWS-110 In-Wall Woofer Lifestyle (with grilles)
Steinway & Sons BWS-110 In-Wall Woofers
The BWS-110 and DW-1 are high-performance in-wall woofers made for custom installations that require a shallow woofer solution. The enclosure is rigid and sealed and can be integrated into 4-inch/10 cm cavity walls, while the extended height provides the large inner cabinet volume required for effective bass extension.
Steinway & Sons BWS-110 and Lyngdorf Audio DW-1 In-Wall Woofers
Since in-wall woofers/subwoofers have to be rather thin, the limited depth requires a special high-performance driver. The BWS-110 and DW-1 utilize a patented high-excursion shallow woofer design that fits 4-inch/10 cm cavity walls customized and based on an innovative voice-coil cone geometry and suspension, which allows the highest excursion from the most space-saving construction.
The woofer driver is 10 inches in diameter and incorporates a four-layer voice coil, an ultra-rigid dual aluminum cone, a powerful neodymium magnet, and a rigid cast basket to provide impressive bass performance, achieving a high output level and low reach. The high-bandwidth design ensures an accurate, fast response and allows the most seamless sound integration with the main speakers.
Steinway & Sons BWS-110 In-Wall Woofer Close-up
The BWS-110 and DW-1 are designed to be an ideal subwoofer or woofer solution for home theaters, living rooms or media rooms with in-wall speaker systems. They’re also useful when there’s no space or desire to place in-room subwoofers. Just paint over their magnetically attached grilles and they’ll practically disappear in a room.
Steinway & Sons BWS-110 In-wall woofer connection
Steinway & Sons BWS-110 bottom connection
Specifications
The specifications of the BWS-110 and DW-1 are identical as follows:
  • Models: Steinway & Sons BWS-110 and Lyngdorf Audio DW-1
  • Product Description: Passive in-wall woofer
  • Woofer: 1 x 10-inch, dual aluminum cone, 4-layer voice coil, neodymium magnet
  • Enclosure: MDF with internal bracing, 19 mm and 16 mm
  • Frequency Range: 30 – 200 Hz (-3 dB)
  • Nominal Impedance: 4 Ohms
  • Power Handling (IEC long term): 300 W
  • Maximum SPL:  109 dB (60 V/1 m)
  • Sensitivity: 82 dB (2.83 V/1 m)
  • Connections: Push-type spring terminal, gold-plated
  •  Recommended Placement:  In-wall floor-standing, boundary woofer
  • Recommended Amplification: 1 x 400 W (A1 or A2 amplifier, 1 channel required
  • Dimensions (WHD):  350 x 1000 x 86 mm / 13.78 x 39.4 x 3.4 inches
  • Weight:  16 kg / 35.3 lbs
  • Standard Finishes:  Matte black, paintable front grill
Lyngdorf Audio DW-1 In-wall woofer
Lyngdorf Audio DW-1
Pricing & Availability
Both products are expected to start shipping October 2024 at the following prices:
  • Lyngdorf Audio DW-1 ($2,999 MSRP)
  • Steinway & Sons BSW-110 ($3,100 MSRP)
Related Reading
QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
WiiM Sound Lite Smart Speaker in white WiiM Sound Lite Smart Speaker in white
WiiM's original smart speaker sheds features to hit a lower price point ($229) for those who can live without a touch display and voice...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
At $229, the 3rd generation iFi ZEN DAC adds a USB-C digital input and improves hi-res audio decoding up to 32-bit/768kHz PCM.
The British audio company just introduced two totally redesigned in-ear ANC TWS earphones that audiophiles are sure to get excited about.
Roku's budget-friendly 4K streaming stick may not have Dolby Vision or an ethernet port, but for the price, it's hard to beat.
Sony's flagship soundbar system will add punch to your movie and TV viewing and music listening, but at a price.
NBC Universal's flagship streaming service is promising live football broadcasts in 4K/HDR with Dolby Atmos surround sound, but will it work on your gear?
In-Wall Speakers
KEF expands its Extreme Home Theater line with the THX-Certified Ci5120QLM-THX and Ci3120QLM-THX in-wall speakers, priced at $1,699.99 and $1,299.99 each.
At $3,499, the Hisense PX3-PRO might be one of the best new UST projectors of 2024.
Four flagship OLED TVs enter a dark room. But only one can emerge the winner.
