Stealth Acoustics LR6 Invisible In-Wall Speaker
Increased Audio Performance and Streamlined Installation
Stealth Acoustics has announced the upgrade of it’s existing FX series product line to the LR series. The upgrade will consist of a materials change resulting in easier installation, and increased performance across the entire product line.
Stealth Acoustics products are designed to fit seamlessly into your home or business’ decor and offer superb sound reproduction while leaving your walls or ceilings completely clean and free of bulky speaker boxes or unsightly grills. A favorite of architects, designers, and listeners alike, Stealth Acoustics has been providing invisible audio solutions for the last ten years.
The first model to receive the upgrade will be designated the LR6. Replacing the entry-level FX6 speaker, the LR6 will retain the same easy-to-work-with footprint, classic 6″ woofer, neodymium tweeter,and protected crossover. Thenew face panel material will retain all of the positive traits Stealth Acoustics products have been known for over the years but will boast a new ultra-smooth finish and increased durability. While the original 6″ invisible speaker was primarily designed as an entry level, background music speaker, the newest incarnation (LR6) will see markedly improved performance, power handling, and sound quality delivering a truly amazing audio experience to the customer – without a single speaker grill in sight.
Like all Stealth Acoustics products, the LR6 is designed to mount between two frame members and be finished into the wallboard. Like a simple drywall patch, the seams are filled and sanded leaving the smooth wall and speaker ready to be finished with any number of popular choices including latex paint, light wallpaper, light fabrics, selected texture coats. Advanced finishing methods such as Venetian plaster and select veneers are supported using special application techniques. There is no need for special vellums or other nonstandard wallboard finishing materials.
Stealth Acoustic products are distributed world-wide by our directly franchised value added resellers, custom installers and distributors. Contact Stealth Acoustics for pricing or click here for additional information on all our products. The manufacturers suggested MAP is $700 per pair.
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
