Starke Sound Launches HALO Series Speakers, Subwoofers & Amplifiers for Home Theater
Discover the Starke Sound HALO Series, featuring the M1 bookshelf speakers, C2 center channel, W1 on-wall speakers, SUB1 and SUB5 subwoofers, and A2 and A3 power amplifiers.
Starke Sound Halo Series Speakers, Subwoofers and Amplifiers
Starke Sound, known for crafting high-end audio gear that punches above its price, has launched the HALO series—a bold new lineup of loudspeakers, subwoofers, and power amplifiers designed to deliver uncompromising performance for “serious” home theater enthusiasts — as opposed to the rest of us who are just in it for the fun, love of music and salty meat treats?
From Scott DeLoache, Chief Design Director, Starke Sound Inc: “Our new HALO Series is designed to be a breath of fresh air for the audio industry, in that the models are powerful and voiced for true high-end listening in demanding systems, yet its price range is remarkably affordable for the series’ performance and overall build quality,…As Starke Sound celebrates its 15th anniversary, it’s a privilege to bring the third-generation HALO products to music and movie lovers of every stripe.
The HALO Series includes seven models across three categories: three loudspeakers, two subwoofers, and two power amplifiers.
The three speaker models in the HALO Series are the M1 bookshelf speaker, the C2 center channel, and the W1 slimline on-wall speaker. Each features Starke Sound’s Rogrid™Aluminum Frame and a reinforced cabinet, engineered for long-term durability and precise acoustic performance.
M1
starke-sound-halo-m1
The M1 bookshelf speaker uses high-quality components, including a Diamaze28™ beryllium tweeter for clear high frequencies and a MaxCarbon65™ woofer for solid bass response. A first-order crossover ensures clean signal handling and consistent phase alignment across the drivers.
For flexible installation, Starke Sound offers the optional Stand 3S for the M1, available in black or silver. Made from aircraft-grade aluminum, the stand uses a three-point base and mechanically connects to the speaker to maintain structural integrity and support performance.
C2
starke-sound-halo-c2
The C2 center channel features a Diamaze28™ beryllium tweeter alongside two MaxCarbon65™ mid-bass drivers. This configuration delivers clear dialogue and balanced sound, making it well-suited for home theater setups where accuracy and tonal consistency are important.
W1
starke-sound-halo-w1
The HALO Series W1 is a slim on-wall speaker designed for spaces where floor or shelf placement isn’t practical. Using the same Diamaze28™ beryllium tweeter and MaxCarbon65™ mid-bass drivers found in the rest of the lineup, the W1 delivers solid performance while saving space—making it a smart choice for surround or standalone use in compact rooms or minimalist setups.
HALO Speaker Comparison
M1W1C2
Product TypeBookshelf SpeakerOn-Wall SpeakerCenter Channel Speaker
Price$4,200 (pair)$1,950 (pair)$3,150 (each)
TweeterDiamaze28™ Be: 28 mm(1.15 inch)Diamaze28™ Be: 28 mm(1.15 inch)Diamaze28™ Be: 28 mm(1.15 inch)
WooferMaxCarbon65™: 165 mm (6.5 inch)MaxCarbon65™: 165 mm (6.5 inch)MaxCarbon65™: 165 mm (6.5 inch) x 2
Max SPL output (1m, typical room)112dB112dB115dB
Frequency response (-3dB)33.5Hz-40 kHz40Hz-40 kHz33.5Hz-40 kHz
Recommended Amplifier Power50 – 500W50 – 500W80 – 500W
Nominal Impedance4 ohms4 ohms4 ohms
Sensitivity (2.83V at 1m)89dB89dB90dB
FinishTrueChrome™ Piano Lacquer & CNC AluminumTrueChrome™ Piano Lacquer & CNC AluminumTrueChrome™ Piano Lacquer & CNC Aluminum
Color optionsSamurai Black/Lunar White/Ember NoirSamurai Black/Lunar White/Ember NoirSamurai Black/Lunar White/Ember Noir
Dimensions with Grill (HWD)15.8 x 8.9 x 17 inches
402 x 225 x 431 mm
19.6 x 8.9 x 7.4 inches
498 x 225 x 188 mm
10.2 x 30.3 x 17 inches
258 x 770 x 431 mm
Dimensions without Grill (HWD)15.8 x 8.9 x 16.4 inches
402 x 225 x 416 mm
19.6 x 8.9 x 6.8 inches
498 x 225 x 173 mm
10.2 x 30.3 x 16.4 inches
258 x 770 x  416 mm
Weight30.2 lbs(13.7 kg)25.4 lbs (11.5 kg)51.6 lbs(23.4kg)
HALO Series Subwoofers
​Starke Sound’s HALO Series introduces two subwoofers designed to complement their speaker lineup: the SUB1 and SUB5. The SUB1 features a 12.5-inch driver powered by a 1000W RMS amplifier, delivering deep, precise bass in a compact form factor. For those seeking more extensive low-frequency support, the SUB5 incorporates a 17-inch driver with a 3000W RMS amplifier, capable of reaching frequencies as low as 8Hz, making it suitable for larger rooms or home theater setups. Let’s take a look at each one and see which one might be a better option depending on your specific needs.
SUB1
starke-sound-halo-sub1
The SUB1 is a compact subwoofer that still incorporates a robust 12.5-inch driver and 1000W RMS of clean, controlled power to fill a space with bass that is both deep and precise, proving size is no limit to performance.
SUB5
starke-sound-halo-sub5
If you need something a little beefier, you can opt for the SUB5. This sub incorporates a large 17-inch driver combined with a Umbraxis™ Diaphragm Support Structure, and industry-leading 120mm excursion, delivering bass that plunges as low as 8Hz. Powered by up to 3000W RMS, it produces ultra-deep, dynamic, distortion-free low frequencies that can fill the largest rooms.
HALO Subwoofer Comparison
SUB1SUB5
Product TypePowered SubwooferPowered Subwoofer
Price$2,499$4,999
Driver 12.5 inch with LMF technology 1-piece carbon fibre sandwich cone17-inch with Umbraxis™ technology, extremely high excursion.
Amplifier Power Output1000W Continuous RMS
2000W Peak Power
3000W Continuous RMS
6000W Peak Power
Frequency response (-3dB, Half space)18Hz-250Hz8Hz-250Hz
Max SPL output 104.5 dB@20Hz(Half space, 1 meter)
116 dB @40Hz-200Hz(Half space, 1 meter)
120 dB @40Hz-200Hz(Typical room, 1 meter)
101 dB @10Hz (Half space, 1 meter)
113.5 dB@20Hz(Half space, 1 meter)
125 dB @40Hz-200Hz(Half space, 1 meter)
130 dB @40Hz-200Hz(Typical room, 1 meter)
Input terminalsLine In: RCA Stereo (Left & Right)
Balanced Input: XLR Stereo (Left & Right)
Digital In: AES
Digital In: AES
Outputs Balanced Output: XLR
Digital Out: AES
Digital Out: AES
FinishTrueChrome™ Piano LacquerTrueChrome™ Piano Lacquer
Color OptionSamurai Black/Lunar White/Ember NoirSamurai Black
Dimension (HWD) withGrille, with feet16.5 x 15 x 20 inches
417.9 x 380 x 508.5 mm
21.3 x 20.1 x 24.6
540 x 510 x 625.5 mm
Dimension (HWD) without grille, without  feet15 x 15 x 17.7 inches
380 x 380 x 450 mm
20.1 x 20.1 x 21.7 inches
510 x 510 x 550 mm
Weight62 lbs (28.1kg)164 lbs (74.5kg)
HALO Series Power Amplifiers
Having high-quality speakers is just one part of the equation; you also need an amplifier capable of delivering the power those speakers require. To meet this need, Starke Sound offers two power amplifiers: the two-channel A2 and the three-channel A3.
Power amplifiers like the A2 and A3 are designed to deliver power and transmit audio signals to speakers. Unlike home theater receivers, they lack features like radio, input switching, or AV processing. The only control typically found is a primary gain control (similar to volume). A separate preamp or AV processor is needed to send audio signals from content sources to the amplifier.
starke-sound-halo-a2
A2 (two-channel amp)
Both the A2 and A3 amplifiers feature Starke Sound’s third-generation Class A+AB amplifier design, delivering up to 620 watts per channel at 4Ω. They incorporate a fully balanced topology and a power supply capacitor array of up to 176,000 microfarads, ensuring high efficiency and stable performance.
starke-sound-halo-a3
A3 (three-channel amp)
The high-bias design of the A2 and A3 amplifiers allows them to operate in Class A mode under typical conditions, providing excellent linearity and low distortion for a clean, natural sound.
When the signal demands more power, the amplifiers switch to Class A/B mode, maintaining efficiency while preserving dynamic range and ensuring the system can handle demanding audio without sacrificing performance or clarity. This design strikes a balance between audiophile-grade sound quality and practical power output.
Halo Amp Comparison
A2A3
Product TypePower AmplifierPower Amplifier
Price$6,000$6,900
Amplifier TypeClass A+ABClass A+AB
Number of Channels2 channels3 channels
Output PowerClass A/B: 620W RMS at 4 ohms
Class A: 50W at 2Ω, 4Ω, 8Ω, per channel
Frequency Response (+0/-1 dB)5 Hz to 50 kHz5 Hz to 50 kHz
Signal-To-Noise Ratio (SNR)>120 dB, A-weighted>120 dB, A-weighted
THD+N<0.002% at 1 kHz, at 10 W, 4 Ω<0.002% at 1 kHz, at 10 W, 4 Ω
Maximum Output Current per Channel100A100A
Input Terminals2 Balanced Self-locking XLR connector, 24K gold plated, Teflon PTFE Isolation3 Balanced Self-locking XLR connector, 24K gold plated, Teflon PTFE Isolation
Output Terminals2 pairs of HL301, CNC beryllium copper binding posts, 24K gold plated2 pairs of HL301, CNC beryllium copper binding posts, 24K gold plated
Power input32A self-locking power socket32A self-locking power socket
Dimensions (WHD – with foot & faceplate ) 17.3 x 7 x 21.3 inches
440 x 177.8 x 540 mm
Weight88.2 lbs (40kg)89.5 lbs (40.6kg)
The Bottom Line
The Starke Sound Halo Series offers everything you need for a home audio or home theater system, except the preamp/processor and source. With all new drivers and components, Halo Series promises “high end performance at an affordable price.” Yet that affordability starts at about $10K for a two channel system or $30-$50K for a 5.1 or 7.2 home theater. Intriguing claims. We want a listen!
Finish, Availability, and Price
HALO models are finished in TrueChrome piano lacquer, with 14 layers of paint and a mirror-finish polish to complete the picture. The new HALO speakers and the SUB1 are available in Samurai Black, Lunar White, and Ember Noir. The SUB5 is available in Samurai Black only.
All of the following products can be purchased directly from Starke Sound or through Authorized Dealers at the following MSRPs:
iFi Go Pod Air Wireless IEM Adapter Collage
Earbuds & In-Ear Headphones
At $249, the iFi GO Pod Air brings wireless hi-res audio to your IEMs without the weight of its predecessor. Same hi-res magic, now...
iFi Up Travel Bluetooth DAC iFi Up Travel Bluetooth DAC
Dongle DACs
Transform your travel audio from ‘meh’ to ‘oh wow’ with the iFi UP Travel. Hi-res Bluetooth, crystal-clear calls, and a design so sleek, you...
DALI V-16 F Subwoofer DALI V-16 F Subwoofer
DALI's flagship 16-inch subwoofer is a 1500-watt beast built to match its KORE and EPIKORE speakers, offering low distortion extension down to 18Hz.
We are Rewind GB-001 Boombox We are Rewind GB-001 Boombox
Rediscover retro cool with the We Are Rewind GB-001 boombox—Bluetooth-enabled, rechargeable, and built for modern mixtape lovers. Vintage vibes, modern tech, all in one...
PMC prophecy9 Speakers Lifestyle PMC prophecy9 Speakers Lifestyle
Discover PMC's latest Prophecy speakers at High End Munich 2025, showcasing cutting-edge technology, powered by the new PMC cor Integrated Amplifier.
NAD M33 V2 BluOS Streaming Amplifier and M23 V2 Stereo Power Amplifier NAD M33 V2 BluOS Streaming Amplifier and M23 V2 Stereo Power Amplifier
NAD’s M33 V2 and M23 V2: No bling, no hype, just solid sound and engineering that actually matters with support for MQA FOQUS and...
Mother's Day Gift Guide 2025 for Audio Video TV Lifestyle Projectors and Gadgets
Upgrade Mom's home audio and video experiences this Mother's Day with 10 gift ideas she'll absolutely love -- and you might too.
SVS brings Ultra Evolution speakers and new 5000 & 17-Ultra R|Evolution subwoofers to HIGH END Munich 2025. Full demos, gear reveals, and more.
Stenheim’s new Alumine Sub crashes the High End Munich party with Swiss precision, isobaric muscle, and a price tag steep enough to make the...
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
Ask an Expert
The ultimate guide to choosing a SVS subwoofer for home theater or high fidelity music listening? All 16 models compared!
Monitor Audio Vestra Subwoofers deliver unbeatable value and performance. With deep bass, customizable tuning, and sleek designs, the W10, W12, and W15 offer premium...
SVS will showcase their flagship Ultra Evolution home theater speaker system for T.H.E. Film Festival movie screenings.
Larger cabinet, bi-wiring, new crossover, and reengineered bass port are only some of the changes for the new Triangle BOREA BR04 which will retail...
