Sprint International Mobile Hotspot by ZTE
Sprint has released its first international mobile hotspot. The device, made by ZTE, is equipped with an unlocked SIM card and slot, so you can connect up to 5 Wi-Fi-enabled devices (802.11b/g) on the Sprint 3G network or a single device on the GSM network.
The ZTE Wi-Fi Hotspot is compact and secure, providing “connector-less” Mobile Broadband access with WEP/WPA/WPA2 security and a web interface to customize your settings. Just be sure to use it in the U.S., first, before you start using it abroad. Sprint claims 4 hours of use time (1,000 hours standby) and includes multiple country adapters for recharging in international outlets.
Price and Availability
The Sprint International Mobile Hotspot by ZTE is available now for $49.99 with agreement at sprint.com.
Key Features
  • Universal Wi-Fi compatibility
  • Provides mobile broadband access to 5 Wi-Fi enabled devices while on CDMA and 1 Wi-Fi enabled device while in GSM
  • Easy to use: compact, portable device requires no connector or software installation
  • Compatible with Windows 7, Vista, XP, Macintosh Linux
  • Wi-Fi 802.11b/g
  • Web UI for customized settings and security
  • External display indicating data transfer and battery condition
  • World Mode — device comes with a pre-installed, unlocked SIM card that is both WCDMA and GSM capable
  • Multiple country adapters for easy charging in international outlets included in box
  • Wi-Fi range up to 131 feet
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
