Loudspeakers
SoundSense Announces NoiseOut Acoustic Speaker Back
SoundSense Solves In-Wall and In-Ceiling Speaker Noise Problems With NoiseOut™ Acoustic Speaker Back While Enhancing Installed Speakers Performance
SoundSense will feature and demonstrate its patent-pending new NoiseOut Acoustic Speaker Back in booth #453 at the CEDIA Expo 2008. These high-performance acoustic enclosures are engineered to maximize the performance of recessed speakers while virtually eliminating noise problems in adjacent environments. Designed with the installer in mind, the NoiseOut Acoustic Speaker Back comes as a single unit, completely constructed and ready for installation. Due to the flexibility of the material, the speaker backs can easily be used in both new construction and retrofit applications. NoiseOut Acoustic Speaker Backs are available in two standard sizes, addressing both ceiling and wall applications. Custom enclosures can also be ordered to fit any speaker size.
“The new NoiseOut Acoustic Speaker Back is an essential product for every high-performance speaker installation where the quality of sound reproduction matters,” says Bonnie Schnitta, SoundSense LLC president. “This product solves adjacent environment noise problems while improving the sound quality of the speakers all at the same time.”
The NoiseOut Acoustic Speaker Back was developed to reduce noise transmission through speakers in walls and ceilings, keeping the “noise out” of adjacent rooms. The materials used to create the speaker backs are acoustically tested to significantly reduce noise transmission between walls and floors.
About SoundSense
SoundSense, LLC is a turnkey acoustical engineering design firm. SoundSense founder and President, Dr. Bonnie Schnitta, is at the forefront of breakthrough technology to encourage awareness of acoustics and development of unique products to reduce noise and create a soothing and peaceful acoustic environment.
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
