Soundmatters Introduces SUBstage250Cube: Brilliant, High-Def Bass Response from a Diminutive Enclosure
soundmatters international introduced SUBstage250Cube, a new digitally powered mini-subwoofer for high-impact, high-definition bass response that is typically associated with subwoofers measuring twice the size and cost. Measuring only 10.4″ x 10.1″ x 9.6″ (HxWxD), the SUBstage250Cube fits in many otherwise challenging room locations without sacrificing one degree of performance.
“A subwoofer is a crucial element in any home audio system, yet we hear from a surprising number of consumers who are forced to forego a sub because their listening rooms are too small for a large, often obtrusive box,” said Lee Adams, soundmatters’ Vice President of Sales and Marketing. “The SUBstage250Cube conquers the challenge of adding bass to a limited space environment thanks to our proprietary technology, and it can be daisy-chained with additional SUBstage models for superior room boundary coupling and extreme sound pressure levels.”
What sets the SUBstage250Cube apart from other mini-subwoofers is soundmatters’ patented “bass plate,” extreme-energyTM and Neodymium Sandwich Magnet Technology, featuring a patented 6.25″ ExtremeEnergyTM neo-sandwich woofer with a 6″ flat aluminum diaphragm and 1.4″ voice coil. This combination of soundmatters-specific elements produces high-definition bass that is normally associated with the most expensive subwoofers on the market. Additionally, a patented “sky-firing” super woofer with moving walls makes it possible for soundmatters to design the SUBstage250Cube with an ultra-compact enclosure, making it easy to hide without affecting performance.
The SUBstage250Cube is magnetically shielded, and features a response of -3dB @ 30Hz. Included are a built-in heat pipe for efficient cooling, a finned die cast aluminum heat sink, and adjustable “air suspension” multi-surface feet. In order to enhance placement options, soundmatters designed the unit with all connections on the bottom.
Soundmatters’ new SUBstage250Cube will ship in August 2007 at a U.S. MAP of $449.
soundmatters international, inc. (www.soundmatters.com), which recently relocated to Reno, NV, is dedicated to developing consumer electronics that enhance, rather than complicate consumers’ lifestyles.
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
