Soundcast OutCast 3.4 Multi-Room Wireless Speaker System
Soundcast Systems announced the OutCast 3.4 multi-room, multi-source wireless speaker system with subwoofer.
OutCast 3.4's technology lets you easily access and enjoy up to 3-sources of your favorite music in up to 4 separate areas of your home or business, indoors or outdoors.
The OutCast 3.4 has a powerful wireless broadcast range of up to 300-feet. Clear, precise transmissions easily travel through walls, doors, floors, ceilings and roofs. You enjoy rich, multi-directional, uninterrupted sound anywhere and anytime.
Additional features include:
  • Tri-amplified, high-definition audio reproduction w/DSP
  • Long-range, interference-free wireless technology
  • Internal battery provides 10-to-20 hours of wireless music (+/- power level)
  • Easy to use backlit top panel keypad for control
You set the stage and command performance with the built-in smart control system. In addition to allowing 3-source music selection and control for your iPod/iPhone/MP3/PC or Mac personal music library, take advantage of Pandora, Rhapsody, iTunes, Radio, HD Radio, Cable Music and even legacy audio sources for the receivers' zone 2 output. Like magic, music you choose is sent to each Soundcast 3.4-equipped listening area (zone).
MSRP: $1,199.00 w/Transmitter included
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
