Sony Debuts 3 High-End 4K UHD Laser Projectors for 2022
Sony has been at the forefront of 4K UHD video projectors, and although they aren’t cheap, they continue to deliver great performance. Find out what they have in store for 2022.
Sony VPL-XW6000ES Ceiling Mounted White Projector
In September 2021, Sony released the VPL-GTZ380 4K Laser projector with advanced features and 10,000 lumens of peak brightness — at a price of $80,000.
Of course, not too many consumers can afford it, but Sony has announced three more projectors for 2022, the VPL-XW5000ES, VPL-XW6000ES, and VPL-XW7000ES. These projectors don’t push out as much light as the GTZ380 but offer some similar high-performance features in a “lower” priced package. Let’s check out what they offer before we tell you the price of each one.
Sony VPL-XW7000ES 4K SXRD Home Theater Projector Black Top Front
All three projectors have same exterior design
Features All Three Projectors Share
3-Chip SXRD (Silicon X-tal Reflective Display): SXRD technology employs LCD chips that are placed on top of a reflective surface instead of a light pass-through surface. There are separate LCD chips for red, green, and blue primary colors.
Note: SXRD is Sony’s trademark for LCOS (Liquid Crystal on Silicon) technology. For example, JVC uses D-ILA (Direct-Drive Image Light  Amplification) as their trademark for the same technology in their projectors.
Native 4K Resolution: All three projectors project 8.3 million discreet pixels (3840 x 2160) onto the screen. Sony doesn’t use pixel-shifting that you find with most other branded video projectors. With the XW series, you get a full native 4K UHD resolution image.
Laser Light Source: Instead of a lamp, a blue laser diode is combined with a yellow phosphor wheel. A portion of the blue laser light passes through, while another portion hits a yellow phosphor wheel which creates red and green light. This technology provides up to 20,000 use hours of life (no lamp means no periodic lamp replacement).  In addition, the Laser/Phosphor combination does not contain any mercury, which is common with most projector lamps.
X1 Ultimate Video Processor for Projectors: These projectors use a variation of the X1 processor used in select high-end Sony TVs. This enables the projector to provide precise video upscaling, detail enhancement, and video noise reduction when needed. The X1 processor also performs Dynamic HDR enhancement (Tone Mapping). This process fine-tunes the contrast and brightness of HDR content in accordance with the projector’s light output capabilities.
Wide Dynamic Range Optics: The SRXD panel in combination with the laser/phosphor light engine and lens assembly provide precise light control for shadows and blacks.
Color Range: All three projectors can display 95% of the DCI-P3 color range via Sony’s Triluminos Pro technology.
IMAX Enhanced: All three projectors are compatible with IMAX Enhanced video standards.
HDMI: Two HDMI 2.0b inputs are provided with 4K resolution, 18Gps transfer rate, and HDR10/HLG support.
Tip: Sony VPL-series projectors have a tendency to be large and heavy. For 2022, Sony has reduced the size and weight of the XW series as much as 30% over some previous models.
VPL-XW5000ES
Sony VPL-XW5000ES Projector White
Sony VPL-XW5000ES
MSRP: $6,000
In addition to the above features, the Sony VPL-XW5000ES provides 2,000 lumens of maximum light output and features a manually operated lens (focus, zoom, lens shift). Sony also claims that the XW5000ES is the world’s smallest native 4K projector (at least until Sony or someone else comes out with a smaller one).
Sony VPL-XW5000ES Projector Rear Inputs White
Sony VPL-XW5000ES
VPL-XW6000ES
Sony VPL-XW6000ES Projector Black
Sony VPL-XW6000ES
MSRP: $12,000
The Sony VPL-XW5000ES provides the next step with 2,500 lumens of maximum light output and features a motorized ACF lens with picture position memory.
Sony VPL-XW6000ES Projector Rear Inputs White
Sony VPL-XW6000ES & VPL-XW7000ES add 3D SYNC OUT
VPL-XW7000ES
Sony VPL-XW7000ES Projector Black
Sony VPL-XW7000ES
MSRP: $28,000
The Sony VPL-XW7000ES provides another performance jump with the following:
Light Output: 3,200 lumens of max light output.
Advanced Crisp Focus (ACF) lens: The lens assembly on the XW7000ES provides precise clarity across the entire screen with the following:
  • 70mm aspherical front lens provides a wider 4K-level focus area.
  • Floating focus system that delivers more stable image performance from corner to corner without distortion from short to long throw distance.
  • Extra-low dispersion glass to reproduce the crisp image without color deviation.
Live Color Enhancer: This feature provides more vivid and vibrant images without compromising on color saturation where needed (high color volume).
Availability & Pricing
All three projectors are available for pre-order with expected release dates in June 2022.
Tip: No matter which of these projectors you decide to purchase, it is a good idea to have it professionally installed and calibrated.
Related reading: Best 4K Projectors
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Can the first child of Audeze and Sony be a sonic superman for only $150? The Sony Pulse Elite is for more than just...
HDTV 4K & 8K TV
There's a new OLED TV in town and it's sure to be a top contender for best TV of 2025.
Open wireless earbuds are gaining in popularity as more users are becoming concerned about situational awareness. Sony's Linkbuds Open provide a rather unique take.
With trickle down technology from its flagship XM series, Sony's LinkBuds Fit offer some great features for those looking for a reliable workout earbud.
Sony just brought its most powerful video processor for projectors down to what should be a much more affordable price point.
