Sony VPL-VW90ES SXRD 3D Projector
Sony today announced its first 3D front projector, the VPL-VW90ES from Sony's “Elevated Standard” (ES) line, which signifies an emphasis on high build quality and outstanding video experience.
Designed with the custom and specialty consumer electronics market in mind, the VPL-VW90ES is engineered to seamlessly integrate third-party control systems. Sony has worked closely with major custom home theater control companies ensuring that drivers are available and accurate. The VPL-VW90ES is no different as it joins an elite list of Sony products that integrate easily with leading home automation systems including Control4, Crestron, AMX®, Savant, Ultimate Remote Control, RTI, Vantage, and others. The projector is also Control4 Certified and includes an AMX Device Discovery Beacon.
The Silicon X-tal Reflective Display (SXRD) full HD (1920 x 1080) projector delivers film-like performance with Sony's 24p True Cinema. It incorporates frame sequential 3D technology with active-shutter glasses that work together with Sony's proprietary 240Hz high frame rate technology, delivering smooth, full high-definition 3D images.
The new 240Hz high frame rate drive supports to minimize cross talk for minimal image distortion, producing an unrivalled 3D and 2D high definition cinematic experience. Additionally, the projector uses a single Ultra High Performance (UHP) lamp that drives brightness of 1,000 ANSI lumens and delivers a sharp, deep black picture thanks to Sony's Advanced Iris 3 technology that helps to produce a dynamic contrast ratio of 150,000:1.
The projector does not require a special screen so it can be easily placed in existing home theaters with minimal revision to the set up making it ideal for retrofit projects. It includes two pairs of Sony active shutter 3D glasses that are also compatible with Sony's 3D capable BRAVIA HDTVs.
The VPL-VW90ES SXRD 3D front projector will be available in November for about $10,000.
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
