Sony Unveils VPL-PHZ61 & VPL-PHZ51 3LCD Projectors
The Sony VPL-PHZ61 and VPL-PHZ51 are designed to provide accurate colors and optimal image quality in professional setups despite their compact size.
Sony VPL-PHZ61 3LCD Projector Front On
Video projectors have become increasingly popular in home theater setups, with UST Laser Projectors becoming the fast-growing home theater projector category.
Sony continues its leadership in the video projector market with two entries that are sure to get some attention, the VPL-PHZ61, and VPL-PHZ51
The Foundation
What distinguishes these projectors is that as of the publication date of this article, they are the smallest 3LCD Laser Projectors available, but don’t let their small size fool you.
On the outside, these projectors are identical in look and size, but the VPL-PHZ61 can output as much as 6,400 lumens of White and Color output while the PHZ51 is no slouch either with the ability to output 5,300 lumens of both White and Color.
Tip: These projectors combine a laser light source with 3LCD imaging chip technology to project images.
Sony VPL-PHZ61 3LCD Projector Angle
Resolution
With their foundation, the VPL-PHZ61 and PHZ51 can project bright colorful images. However, we need to discuss resolution.
The stated resolution for these projectors is 1920 x1200 pixels (WUXGA) which is a common resolution used in professional and PC settings.
WUXGA is sometimes referred to as 1080p+ as the number of horizontal pixels is the same, but the number of vertical pixels is 1,200 instead of 1,080. This equates to a 16:10 aspect ratio, once again common in the professional world.
Tip: Total number of pixels on each imaging chip (R,G,B) numbers 2,304,0000. The number of pixels in 1080p resolution is 2,073,600 (a 13.95% difference)..
Another interesting thing is that while these projectors can accept a 4K/60Hz input signal, the signal is scaled down and processed for optimum display quality at WUXGA resolution. An incoming 4K UHD image contains approximately 8,200,000 pixels which is almost 4 times the number that these projectors can display natively.
Tip: Unlike many “4K” home theater projectors, pixel shifting is not used in the VLP-PHZ61 or  PHZ51 to display a near-4K UHD resolution image.
Sony VPL-PHZ61 3LCD Projector Rear
Core Features
Moving from their foundation, here is an overview of core features that both projectors also share.
Compact Size: Sony is promoting these projectors as the smallest 3LCD-based Laser projectors today with cabinet dimensions of 422 x 129 x 338 mm (16 5/8 x 5 3/32 x 13 5/16 inches). It is surprising how much light these projectors can put out from such a small cabinet.
Easy Installation: With their compact size the PHZ61 and 51 are easy to install. They can be placed in several spots in relation to the screen including the front, front ceiling, rear, and rear ceiling. For ceiling installations in meeting rooms and classrooms the +55% vertical lens shift, is the widest in the fixed lens models.
Sony Reality Creation: This feature provides real-time signal processing, mapping, and analysis technology. It enables the projectors to display crisp and clear pictures.  Reality Creation enhances the overall sharpness, resolution, and quality of the imagery.
Reality Text: This feature improves text-based presentation materials by providing clearer letters and lines with enhanced legibility.
Advanced Intelligent Settings: This feature provides optimization based on the room environment. The settings include
  • Bright View: This enables colors to accurately maintain their contrast and vividness, even in brightly lit rooms.
sony-vpl-phz61-3lcd-projector-front
  • Ambiance: This feature automatically measures the room’s brightness using an ambient light sensor, and further calibrates the Bright View, color gain, and Reality Creation settings accordingly.
Additional Features
Auto Light Output: By utilizing the ambient light sensor, the brightness of the projector is automatically controlled at night to save power consumption
Auto Power On: New Auto Power On feature that turns the projector on when the video signal is sensed.
Auto Input Select: If the video projector is on it can automatically change the input when s  new video signal is detected.
Data Cloning Function: This allows users to copy any settings on one projector to all subsequent projectors using a USB device.
Screen Size Range: 1.02 to 7.62 meters (40 to 300 inches)
Lens Shift (Manual): Vertical –35% to +55%, Horizontal: +/–15%
Keystone Correction (Max.):
  • Horizontal: +/-30 degrees
  • Vertical: +/-30 degrees
Input Connections: 2 x HDMI, 1 X RGB/Y PB PR, Video In (composite), Audio In (3.5mm), HDBaseT
Output Connections: Audio (3.5mm)
USB: Power and Firmware Update only.
Audio: 16-watt mono speaker system.
Maintenance: Sony makes it easier for users to remove the filter and to know when the filter needs cleaning with a new sensor.
Availability and Pricing
  • VPL-PHZ61 ($5,500) is expected to be available in November 2022.
  • VPL-PHZ51 ($4,500) is expected to be available beginning in December 2022.
While supplies last, the previous models are available for:
For additional availability check Sony’s Professional Dealer Network.
Sony Debuts 3 High-End 4K UHD Laser Projectors For 2022
The Sony VPL-GTZ380 4K Laser Projector Turns Up The Brightness
Sony SLS-1A Powered Line-Array Loudspeaker Unveiled
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
On this episode Caleb Denison, formerly of Digital Trends, shares his thoughts on 2025 TVs along with the launch of his new YouTube channel,...
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Can the first child of Audeze and Sony be a sonic superman for only $150? The Sony Pulse Elite is for more than just...
Ask an Expert
If you can't get picture or sound from your TV or projector don't despair. Here are some debugging tips from our resident home theater...
HDTV 4K & 8K TV
There's a new OLED TV in town and it's sure to be a top contender for best TV of 2025.
Open wireless earbuds are gaining in popularity as more users are becoming concerned about situational awareness. Sony's Linkbuds Open provide a rather unique take.
