Sony VPL-FX500L and VPL-FX30 3LCD Projectors
Sony VPL-FX500L
High-Brightness Projectors For Fixed Installations
Sony is expanding its line of high-brightness 3LCD business projectors, with two new models designed for fixed installation applications. The new VPL-FX500L model delivers 7,000 lumens of Color Light Output and is capable of the widest lens shift in its class, suitable for large-screen applications such as university lecture halls and corporate auditoriums. The VPL-FX30 provides 4,200 lumens of Color Light Output, and is equipped with 1.6x standard zoom lens for flexible installation, ideal for mid- to small-sized class rooms or meeting rooms.
Both projectors apply Sony s Bright Era”! technology, and each has XGA resolution of 1,024 x 768 pixels. Each projector is outfitted with a white and flat cabinet, allowing them to easily blend into white ceilings when installed, and there are no terminals or ventilation slits on the rear side, giving audiences the impression that the projectors are blended into the ceiling when mounted.
These new projectors offer style, ease of use, and low maintenance while delivering high brightness and high performance, said Sander Phipps, product manager for LCD projectors at Sony Electronics.
The VPL-FX500L s twin-lamp system provides fail-safe and economical operation. It can output a total of 7,000 lumens with just one lamp. However, a second lamp is built-in to provide automatic back-up should the primary lamp fail. The two lamps are alternatively used, allowing the total expected lamp life to total up to approximately 8,000 hours.
The VPL-FX500L ships without a lens, and offers backwards compatibility with certain models of Sony s existing accessory lenses.
Sony VPL-FX30 3LCD ProjectorSony VPL-FX30
The VPL-FX30 s 1.6x zoom standard lens allows customers to easily upgrade from a majority of existing projectors to the VPL-FX30 without having to change ceiling mount positions. For applications where more than a standard lens is needed, the VPL-FX30 is compatible with the VPLL-Z1032 and VPLL-Z1024 accessory lenses for Sony s current VPL-FX40 series.
Depending on the lens used, the VPL-FX500L can shift images approximately vertically +/-96% and horizontally +/-64%, from their original position, making projection possible without having images distorted by digital keystone correction. This feature is recommended for applications where the ceiling mount position is limited by lighting fixtures or water sprinklers, or where the position is higher than screen.
The VPL-FX30 is planned to be available in June, and the VPL-FX500L in July.
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
