Sony URX-P41D Wireless Microphone Enhance Podcast Recording
Sony adds to its UWP-D wireless microphone product line with the Sony URX-P41D Receiver and UWP-D27 wireless microphone package.
Sony URX-P41D Wireless Microphone Mounted on Camera
When you are tasked to do a live video recording of an event, performance, or video cast, using the built-in microphone in your camera or camcorder just doesn’t quite cut it.
To get satisfactory results, it’s best to use a good wireless microphone paired with a good transmitter and receiver to capture the audio. If you use compatible Sony XDCams or Alpha Series Interchangeable Lens Cameras, the 4th Generation UWP-D wireless microphone product line might be just the ticket.
URX-P41D
The URX-P41 is a two-channel portable audio receiver, that is designed to work with Sony’s XDCAMs, Alpha Interchangeable lens cameras, and select Cinema Line Cameras.
Digital Audio Interface
The URX-P41 incorporates Sony Digital Audio Processing and DSP (Digital Signal Processing) to improve audio quality as the distance between the microphone/transmitter varies. In addition, transient response is improved with provides for better audio quality for interview settings.
When using Sony’s SMAD-P5 Shoe Adapter, direct audio recording is possible as the D/A and A/D conversion steps are eliminated. In addition, audio status information is fed to the Camcorder/Camera viewfinder (if compatible).
Sony SMAD
Tip: The URX-P41 also has an OLED status display.
NFC Sync Function
The feature allows the receiver to lock to the microphone transmission frequency more precisely, similar to the way you can pair a smartphone and Bluetooth speaker. After the initial pairing, all you have to do is touch the transmitter and receiver to resync if needed.
For additional lock on the NFC pairing function finds the two best channels available.
Stable RF Reception
In addition to its precision pairing capability, the URX-P41D has two adjustable antennas to improve signal reception.
The URX-P41D uses analog UHF in the following transmission bands:
  • 470.125 to 541.875 MHz
  • 536.125 to 607.875 MHz
  • 941.625 to 951.875 MHz
Compact Form Factor
The URX-P41D is smaller than previous versions allowing it to sit on top of the camcorder/camera attached to an MI shoe without exaggerated physical balance issues. This makes it easier to hold the camcorder/camera for long periods of time.
External Microphone Input and Mixing Function
In addition to wireless microphones, the URX-P41D also has an input for a wired microphone, should that be needed. 3 and 4 channel audio recording is supported, depending on the microphone configuration.
Tip: A Headphone output is also provided.
Sony URX-P41D Wireless Microphone Connections
On-Location Audio Settings
The URX-P41D includes an Auto Gain Mode and Output Level control to make sure that your on-location audio is correct. This includes minimizing distortion while maintaining satisfactory audio levels.
Power
You can use two AA batteries (alkaline or NiMH rechargeable). The run time with a full charge is up to 4 1/2 hours. It can also be powered via USB when available.
UWP-D27
Sony URX-P41D Wireless Microphone Pair
Although the URX-P41D is compatible with other products in Sony’s UWP wireless microphone series, they suggest getting the UWD-D27 wireless microphone kit. The kit comes with 2 microphones, 2 UTX-B40 Bodypack Transmitters, and the URX-P41D receiver. You have to supply your own camera or camcorder of course.
Availability and Pricing
The URX-P41D ($679.99) and UWP-D27  ($1,299.99) are available through authorized Sony Dealers.
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Can the first child of Audeze and Sony be a sonic superman for only $150? The Sony Pulse Elite is for more than just...
HDTV 4K & 8K TV
There's a new OLED TV in town and it's sure to be a top contender for best TV of 2025.
Open wireless earbuds are gaining in popularity as more users are becoming concerned about situational awareness. Sony's Linkbuds Open provide a rather unique take.
With trickle down technology from its flagship XM series, Sony's LinkBuds Fit offer some great features for those looking for a reliable workout earbud.
Sony just unveiled two new entry-level Dolby Atmos-compatible soundbars for those who want to beef up their TV sound without breaking the bank.
