Sony STR-ZA3000ES 4K A/V Receiver
Sony STR-ZA3000ES A/V Receiver
Sony just announced announced its new top-of-the-line 7.2-channel 4K A/V Receiver for $1700, model STR-ZA3000ES, designed to be custom installer friendly. The STR-ZA3000ES delivers cinema-like surround sound and crystal clear music reproduction (110W @ 8 ohms, 1 kHz, 0.9% THD). Designed for a three room multi zone installation, every detail has been scrutinized and tuned in the higher interest of reliable, consistent sound performance. An 8-port Giga Ethernet Hub with Power over Ethernet* support helps various network installation cases, allowing for system flexibility and simple connectivity. The HDCP 2.2 Repeater (2 input/2 output) delivers full-performance playback of 4K Premium Content with maximum visual and multi-channel sound quality, all with a simple HDMI connection.
Sony ES engineers have taken the existing on-screen user interface and tailored it for a faster, more fluid integration, whether using the on-screen menu, the front panel display or available web browser functionality. From the removable magnetic faceplate, to electronic component selection, special second generation ES solder, structural/chassis elements, and even screw placement, all of the new ES Z Series models are optimized for the most seamless install possible. The newly designed front panel includes install-friendly cursor keys, providing full operability without a remote, a two line-display that shows the information of Field and Value at the same time, and a numbered menu structure that helps the user not lose where they are in the process. While creating this appealing front panel, Sony’s designers also created an elegant way to conceal the added buttons from wandering fingers with a magnetic faceplate.
The back panel layout has also been redesigned to make wiring in a rack easier. A single-lined speaker terminal row allows for easy cable installation and management along with isolated Digital / Analog inputs provides for better audio/video quality. Whether it’s providing a PDF of an install manual with a product manual or discrete IR codes in the new remote, the new ES line is designed for the installer to exceed customers’ expectations.
Sony also announced two lower priced models in the same series, the STR-ZA2000ES with 100W @ 8 ohms, 1 kHz, 0.9% THD, and the STR-ZA1000ES at 90W @ 8 ohms, 1 kHz, 0.9% THD). With just the right amount of flexible, multi-zone High Definition connectivity, easy IP integration with leading control systems, powerful browser-based configurability and well-renowned ES build quality, these models provide an incredible Audio/Video experience the consumer won’t easily forget. In-Ceiling Speaker mode is available for the customer using ceiling speakers, and the Sound Optimizer delivers real surround effects even at low sound.
Built with a no compromise system design, the new models now include an install friendly user interface and read panel, a button rich front panel for integration hidden by a magnetic faceplate, HDMI with HDCP 2.2, HDMI Matrix Switching, 3rd party certification and In-Ceiling speaker adjustment, all allowing for incredible flexibility for any install need.
Pricing and Availability
  • Sony STR-ZA3000ES $1,699 (mid-September 2014)
  • Sony STR-ZA2000ES $1,399 (mid-September 2014)
  • Sony STR-ZA1000ES $899 (January 2015)
STR-ZA1000ES 7.2 Channel 4K AV Receiver
  • 90W @ 8 ohms, 1 kHz, THD 0.9%
  • Optimized chassis and internal circuitry for incredible audio performance
  • HDMI 6 in/2 out (4K) with HDCP 2.2 support (1-main theater 4K, 1-2nd Zone 4K)
  • Flexible HD connectivity with 7 assignable inputs (5 HDMI, 2 component)
  • Convenient front USB for system updating and setup
  • Seamless IP Control Integration (1-port)
  • Supports 4K upscaling and pass-through with 3D and full TRILUMINOS color support
  • 1, 12-Volt triggers for triggering external peripherals, amplifiers, etc.
  • 3, IR repeaters (1-in, 2-out) for external device control
  • Supports Digital Cinema Sound, Dolby, and dts Digital Surround Audio Codecs
  • In Ceiling Speaker mode for the customer which uses ceiling speakers
  • HDMI, Digital (Optical, Coaxial), Analog 2nd Zone Out
  • Powered Zone 2
  • Zone 2,3 variable line out
STR-ZA2000ES 7.2 Channel 4K AV Receiver adds:
  • 100W @ 8 ohms, 1 kHz, THD 0.9%
  • Flexible HD connectivity with 8 assignable inputs (6 HDMI, 2 component)
  • Aluminum front panel, faceplate
  • Front HDMI in
STR-ZA3000ES 7.2 Channel 4K AV Receiver adds:
  • 110W @ 8 ohms, 1 kHz, THD 0.9%
  • 8-port Giga Ethernet Hub with PoE (x2) support for flexible connectivity
  • 3, 12-Volt triggers for triggering external peripherals, amplifiers, etc.
  • Multi-channel Preout
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
On this episode Caleb Denison, formerly of Digital Trends, shares his thoughts on 2025 TVs along with the launch of his new YouTube channel,...
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Can the first child of Audeze and Sony be a sonic superman for only $150? The Sony Pulse Elite is for more than just...
HDTV 4K & 8K TV
There's a new OLED TV in town and it's sure to be a top contender for best TV of 2025.
Earbuds & In-Ear Headphones
Open wireless earbuds are gaining in popularity as more users are becoming concerned about situational awareness. Sony's Linkbuds Open provide a rather unique take.
With trickle down technology from its flagship XM series, Sony's LinkBuds Fit offer some great features for those looking for a reliable workout earbud.
