Loudspeakers
Sony SRS-A3, D4, D5 PC Speakers
Sony has announced three new PC speakers. The SRS-A3 joins the compact and highly versatile SRS A Series. The gaming and video optimised SRS D Series is expanded with two new products, the SRS-D4, SRS-D5.
PC speakers for everyday use need to be compact but capable of handling a wide range of output without compromise.
The new SRS-A3 compact, magnetically shielded speakers deliver a total of 5W of clear stereo underpinned with controlled, punchy bass thanks to a carefully engineered reflex port. The cabinets are tilted at precisely the right angle to enhance audio quality and feature an integrated digital amplifier for high efficiency and lower power consumption. Controls are built-in along with a headphones jack.
The SRS D Series is built for those who want something special that will add an extra dimension to gaming and video.
The new models offer increasing levels of output power and bass response so the customer can choose the best fit for them. Features shared by all models include superb sound quality from precision-engineered cabinets, digital amplification for maximum clarity, 2.1 speaker system with angled satellite cabinets, integrated controls and magnetically shielded speakers.
Sony SRS-D4 Sub/Sat PC Speakers
The SRS-D4 effectively becomes the entry-level D Series product, with a combined output of 27W from its 2.1 speaker format. Power, volume and bass volume controls are integrated into a relatively compact sub-woofer and the satellites feature a distinctive raised border around the speaker grill. This is burnished to a high finish and provides a definitive design accent that gives the PC speakers a unique character.
Sony SRS-D5 Sub/Sat PC Speakers
The SRS-D5 delivers 40W and is slightly larger all round than the D4. The sub-woofer is constructed from medium density fibreboard (MDF) for improved sound quality and the controls are integrated into one of the satellites — handy if the sub-woofer is placed on the floor.
Features at a glance:
Name SRS-A3 SRS-D4 SRS-D5
MSRP check price check price check price
Speaker System 2.0ch 2.1ch 2.1ch
Output power 5W 27 W 40 W
Speaker Unit 57mm Sat: 46mm
Sub: 95mm
Sat: 60mm
Sub: 115mm
Speaker unit Ferrite Diameter: 95mm Diameter: 115mm
Dome-shaped center cap of speaker unit
Impedance 8.0 Sat: 10.0
Sub: 5.0
Sat: 8.0
Sub: 3.6
Frequency Hz 150 – 20,000 100-10,000 100-10,000
Digital Amplifier Yes Yes Yes
Mega Bass No Yes Yes
Subwoofer material N/A Resin Medium Density Fiberboard
Controls Volume, power Volume, bass and power Volume, bass and power
Controls location In LH cabinet In Subwoofer In Satellite Speaker
Audio in Yes Yes Yes
Head-phone out No No Yes
Colour Black Black Black
Power Supply AC AC AC
Dimensions
(WxHxD) mm
71x141x91 Sub: 208x118x130
Sat: 65x65x67.5
Sub: 193x243x233
Sat: 109x203x135
Weight (g) L=205g
R=190g
Sub: 1430g
Sat: 460g
Sub: 2450g
Left Sat: 680g
Right Sat: 610g
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
