DSLR Cameras
Sony SLT-A33 Alpha Digital SLR Camera
World's First Translucent Mirror Technology Enabling Simultaneous Auto Focus and Capture in an Interchangeable Lens Digital Camera
Sony announced the 14.2-megapixel SLT-A33 Alpha DSLR camera with Sony's newly-developed Translucent Mirror Technology, which achieves the highest-level of auto focus speed for both still image and movie shooting.
Translucent Mirror Technology provides performance previously unattainable with traditional DSLR technology. Using the new technology, the α33 model can continuously and quickly focus (with TTL phase-detection) while shooting stills and recording video–even in full HD, allowing desired moments to be captured in tack sharp focus, high-definition video. It can shoot continuously at up to 7 frames per second..
By displaying the images received by the Exmor APS HD CMOS Sensor, picture quality of the camera's live view image has enhanced drastically. Coupled with the quick and accurate phase detect AF and 100 percent coverage Tru-Finder electronic viewfinder, the Quick AF Live View feature has been further advanced.
The SLT-A33 is equipped with a translucent mirror, which enables light passing through the lens to be simultaneously received by the image sensor and the auto focus sensor, allowing continuous shooting and continuous focusing at speeds never before possible.
Because of its structure, the Translucent Mirror Technology does away with the motion of raising and lowering the mirror. The absence of the moving mirror mechanism contributes to making the whole body size significantly compact compared to traditional DSLR cameras.
Sony SLT-A33 Alpha Digital SLR Camera - Top
By eliminating the need to raise and lower the mirror between shots, the technology makes it possible to achieve focusing while images are captured. Existing systems can only focus in the interval between image capture, limiting the ability to track fast moving subjects. The camera also has continuous Advance Priority AE Mode and will automatically adjust for the best exposure to help you get the most professional looking results.
High-Speed Capture with Auto Focus
Additionally, a newly developed 15-point AF system assures ultra-fast, high precision focusing. The high-speed shooting with continuous Phase Detect AF tracks rapidly moving subjects accurately. You can capture the decisive moments that you might have otherwise missed.
Creative Video Capture
The continuous phase detect AF also works in movie shooting for the first time in the world. The Translucent Mirror Technology also allows the α33 to be the first camera to ever maintain continuous phase detection AF while recording Full HD AVCHD video. With fast, precise phase detection AF continually tracking subject movement, even fast action and subjects that move quickly towards or away from the camera are easy to keep in focus.
With a large 14.2 megapixel Exmor APS HD CMOS sensor, background defocusing effects can be easily captured. The APS-C sensor size is nearly 20 times larger than a traditional compact camcorders' 1/2.88 type image sensor, providing more creative control.
Compatible with all A-mount lenses, video and photography enthusiasts alike can choose from macro to telephoto lenses to achieve their desired artistic effect.
Full-time Live View
Full-time Live View offers unprecedented freestyle shooting versatility with fast, precise AF using either the viewfinder or LCD monitor. The α33 has a fully articulated 3-inch 921,600 Xtra Fine LCD with TruBlack technology with 100 percent coverage.
The Tru-Finder eye-level viewfinder provides an unprecedented combination of 100 percent coverage and 1.1x magnification for easy and natural framing. By combining Translucent Mirror and Tru-Finder technologies, α33 iss the first interchangeable lens digital cameras to offer movie recording with the familiar eye-level shooting style — a significant advantage in fast moving and extreme lighting conditions (bright sunlight and low-light situations).
Sony SLT-A33 Alpha Digital SLR Camera - Back
The variable angle tilt LCD is adjustable to accommodate shooting from low or high angles. The electronic view finder has a high-resolution effective 1.15 million dots conversion Xtra Fine LCD display, is bright and easy to see even in low light, has a selectable shooting parameter display and shows the effects of exposure and white balance adjustments.
Advanced Shooting Features
With an Exmor APS HD CMOS sensor, BIONZ® high-speed image processing engine and ultra-high ISO sensitivity (ISO 100-12,800), the α33 camera offers advanced shooting features. These make it easy to get the best shot, even in difficult lighting conditions.
Auto HDR shoots and combines three frames into a single high dynamic range (HDR) photo with rich shadow and highlight detail. Multi frame NR shoots and combines six frames into a single photo, enabling smooth low-light imaging at half the noise level. Hand-held Twilight shoots and combines six frames into a single photo, suppressing blur to enable clear night-scene imaging without a tripod or flash.
Sony SLT-A33 Alpha Digital SLR Camera and 18-55mm zoom lens
3D Sweep Panorama technology creates two images from a single frame, enabling panoramic photos to be viewed in 3D on compatible 3D systems and other devices that support 3D technology. HDMI connectivity enables stunningly beautiful PhotoTV HD display of images on compatible Sony BRAVIA® TVs.
AUTO+ (Advanced Auto) mode offers the same benefits as Auto mode and more, resulting in cleaner, more dynamic pictures and fewer missed shots. The camera automatically recognizes the correct scene mode, then quickly shoots and combines up to six shots to produce images with greater clarity, optimum dynamic range using Auto HDR technology and lower image noise using 6 shots layering technology.
Accessories
The α33 camera accepts both Memory Stick PRO Duo (including Memory Stick PRO-HG Duo) and SD (including both SDHC and SDXC formats) media (all sold separately). With a 30MB per second transfer rate, Sony's Memory Stick PRO-HG Duo HX offers the best performance of all memory cards whether in continuous shooting mode or transferring data to other media.
A new dedicated microphone (models ECM-ALST1 and ECM-CG50) will also be available.
Pricing and Availability
The Sony SLT-A33 Alpha Digital SLR Camera will be available in September at a MSRP of:
  • $650 for the body only (model SLT-A33)
  • $750 for the body and 18-55mm zoom lens (model SLT-A33L)
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
