Car Navigation Systems
Sony NV-U71T Portable Car Navigation System Announced
Sony’s New Personal Navigation System Offers Comprehensive Daily Driver Mapping Tools and Traffic Information
For daily commuters who want to avoid traffic, Sony Electronics today revealed the latest nav-u personal navigation system. The new NV-U71T model is the second offering in the company’s navigation lineup.
Ready to use right out of the box, this slimmer, easy-to-use device helps drivers map a destination, locate points of interest, find home again and avoid traffic congestion.
With an included RDS-TMC real-time traffic receiver built into a supplied cradle, the device notifies drivers of heavy traffic areas and automatically gives them an alternate route choice. The real-time traffic service requires a separate subscription, but drivers will receive the first 90 days free of charge. For continued traffic service, a subscription will cost $4.95 a month after the initial trial period.
“It’s safe and easy to use while driving, and it comes with everything you need to get started,” said Allan Jason, vice president for mobile electronics and portable audio products at Sony Electronics. “Our aim is to make navigation easy without sacrificing any of the features drivers need to get where they’re going.”
Based on customer feedback, Sony developed an intuitive user interface integrated in the new device that eliminates drilling down through multiple menu systems for common functions.
The new Gesture Command™ function makes frequently used commands, such as Sony’s “take me home” feature, available through simple finger movement on the 3.5 inch touch-screen. Drawing an invisible inverted “V” on the screen activates the feature.
With anti-glare coating, it’s easy to see the screen in any lighting. A new super-suction cup for the mounting bracket is made from material that safely adheres to most surfaces in the car. Some states prohibit affixing devices to the windshield. However, with the new mounting device, it can be mounted on most dashboards or a surface on the center console.
The unit’s compact design makes it a breeze to transfer between vehicles. Drivers can choose from nearly seven million points of interest — four times as many as its predecessor — and destinations from U.S. and Canadian maps pre-loaded on its 2GB Flash memory. Maps of Alaska, Canada, Hawaii and Puerto Rico also come pre-installed on the device.
A powerful speaker ensures that voice prompts are clear and audible. An embedded rechargeable lithium-ion battery allows up to six hours of operation without using the supplied car power adapter.
Pricing and Availability
Pre-orders for the dark metallic blue and silver NV-U71T navigation device are now being accepted at www.sonystyle.com/navu. The device is expected to be available this winter for about $500 at SonyStyle online and retail stores nationwide, as well as at authorized retailers around the country.
Sony will be demonstrating the new nav-u device from Oct. 31 to Nov. 3 at the SEMA (Specialty Equipment Market Association) convention at the Las Vegas Convention Center (booth #1106).
Separate accessories include a second vehicle kit with an additional mounting bracket and a car charger for about $100, as well as an external GPS antenna for about $100. A travel case will also be available for about $30.
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
