Camcorders
Sony NEX-VG20H Handycam Interchangeable Lens Camcorder
Sony announced the Handycam NEX-VG20H HD camcorder compatible with the E-mount Interchangeable Lens System for shooting cinematic Full HD (AVCHD Progressive 24p/60p) video or 16-megapixel high-resolution still photos.
The new camcorder offers several enhancements over Sony’s acclaimed NEX-VG10 — the world’s first consumer HD camcorder with interchangeable lenses — including comprehensive manual controls, improved imaging quality and upgraded sound. Significantly refined ergonomics include enhanced grips for balance and low-angle shooting, and a second record button, among many others.
With a resolution of 16.1 effective megapixels, the camcorder’s Exmor APS HD CMOS sensor assures outstanding video image quality, with extremely low noise in low light. It also captures pristine 16 megapixel still photos, with RAW format support for all the post-processing flexibility that’s familiar to DSLR users. The sensor also allows the creation of background defocus (‘bokeh’) effects with a user’s E-mount lenses.
Full HD video shooting in the AVCHD format is now complemented by a choice of 24p and 60p (progressive) frame rate options. Footage shot at 24p can be enhanced with Cinema Tone Gamma and Cinema Tone Color for an even richer, more cinematic look.
Dialogue and other sounds are captured by the precision Quad Capsule Spatial Array Microphone that now supports stereo and 5.1 channel surround. The camcorder also offers a new audio level control.
Several ergonomic refinements let videographers shoot HD video and stills in even greater comfort. The camcorder’s handgrip has been redesigned for excellent stability. Allowing manual adjustment of exposure, iris and other settings, the control dial can now be accessed even when the LCD panel is closed.
The button layout now features “hard” function keys, direct access to each shooting mode (Iris, Shutter speed, Program AE), a second REC button for low-angle shots and expanded focus button — all located for intuitive operation so users don’t have to take their eyes away from the electronic viewfinder.
Shooters can frame and review footage on the three-inch (7.5cm) Xtra Fine LCD display that features TruBlack technology for clear, high contrast images. The screen can rotate up to a 270-degree range for easy framing in any position, even with the camera held low. A touch-panel simplifies fingertip operation of shooting functions.
The NEX-VG20H camcorder comes with the SEL18200 F3.5-6.3 E-mount lens. With a wide 11x optical zoom range and built-in Optical SteadyShot image stabilization, this versatile lens offers smooth, quiet autofocus operation during movie and still shooting.
A choice of seven E-mount lenses can cover virtually any shooting situation. The optional LA-EA2 lens mount adaptor provides even wider compatibility with the established family of A-mount optics. Sony is also planning to develop a third-party “eco-system” to allow consumers to use the camcorder with other brands’ lens assets.
The new camcorder is compatible with Sony’s Memory Stick PRO-HG Duo HX series as well as Sony’s full line of SD memory cards. Available in capacities up to 32 GB, both media enable necessary transfer speeds for stable and optimal performance of Sony hardware features such as full HD movie shooting.
Price and Availability
The Handycam NEX-VG20H Full HD E-mount system camcorder will be available with a retail price of about $2,199. A body-only version, the NEX-VG20, will be available for $1,599. The European models are known as NEX-VG20EH and NEX-VG20E (body only).
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
