Mirrorless Cameras
Sony NEX-C3 APS-C Digital Camera
Sony announced the 16.2-megapixel (alpha) NEX-C3 digital camera claiming to be the smallest, lightest interchangeable lens camera with an APS-C sized sensor.
Offered in a range of stylish colors, the NEX-C3 brings the promise of DSLR-quality photography to the millions of consumers looking to take professional-looking photos without the size and bulk of traditional DSLR cameras.
The NEX-C3 features an attractive new body design that combines a satisfyingly solid metal top casing with an easy-to-use streamlined grip shape. Reducing the size of its internal circuitry visibly shrinks the camera's size and achieves a body weight of just 225g (approximately 8 ounces) — nearly six percent lighter than its predecessor, the NEX-3 camera. Image quality, functionality and usability of the NEX-C3 camera also surpass that of the NEX-3 model.
The resolution of the camera's large Exmor APS HD CMOS sensor is boosted to 16.2 effective megapixels, capturing stills and 720p HD video with breath-taking clarity. The large, DSLR-sized sensor also lets users produce pro-quality background defocus effects, whether shooting HD video or stills.
Sony NEX-C3 APS-C Digital Camera - Back
“Building on the success of last year's α NEX launch, the new NEX-C3 model takes the idea of 'small camera body, SLR-quality photos' to a whole new level,” said Kristen Elder, director of the alpha digital imaging business at Sony. “This camera's brand new, large CMOS sensor and user-friendly interface will allow all photographers, regardless of experience level, to produce unique, custom-styled photographs.”
Photo Creativity
The intuitive new Photo Creativity interface on the NEX-C3 camera puts sophisticated controls within easy reach, whether users are shooting stills or HD Video. Technical terms like 'aperture', 'exposure value' and 'white balance' are replaced with the friendlier and more intuitive 'background defocus', 'brightness' and 'color', allowing users to easily create custom-styled photographs. A traditional interface with Aperture/Shutter Priority, Manual and custom functions is always available for experienced users, along with highly customizable soft-keys for programming direct access to important controls.
With the NEX-C3 camera, users don't need to dig into confusing menu options or guess their effect on a composition. They just need to turn the camera's rear-mounted control wheel and instantly see the effect of their settings previewed on screen. Also, two or more different settings can be combined to create more sophisticated creative effects.
A new in-camera 'Picture Effect' setting lets users add extra impact to stills or HD video during shooting, without the worry of editing images afterwards. 'Picture Effect' options include Partial Color, Retro Photo, Pop Color, High Contrast Monochrome, Posterization, High-key and Toy Camera. There's also a 'Soft Skin' effect that removes wrinkles and blemishes from portrait subjects.
Tilting for comfortable viewing at any angle, the high contrast 3-inch (measured diagonally) Xtra Fine LCD features TruBlack screen technology for high-contrast images with rich, deep blacks. This is an ideal way to compose shots and judge the effect of adjusting picture settings, even when viewing outdoors in bright sunlight.
Long-Lasting Battery
The NEX-C3 works even harder to capture amazing images and HD video between battery charges. Improved energy efficiency boosts battery life to a generous 400 still shots per charge — a more than 20 percent increase from the both the NEX-5 and NEX-3 cameras.
Multi-Shot Imaging Technologies
Sony's Advanced multi-shot technologies further broaden the possibilities of the NEX-C3 camera. 3D Sweep Panorama mode captures extra-wide images that can be viewed in 3D on a 3D television with compatible 3D glasses. Auto HDR “stacks” a high-speed burst of three successive exposures to capture extreme shadow and highlight details in a single frame. Similarly, Handheld Twilight and Anti-Motion Blur modes automatically combine six exposures to capture smooth, low-noise images. This avoids hand-blur and subject-blur when shooting in available light.
Sony NEX-C3 APS-C Digital Camera with Lenses
New E-mount 30mm Macro Lens and Other Compatible Accessories
The versatility of the α E-mount compact camera system grows with new style-matched accessories to expand shooting possibilities even further.
Joining the range of E-mount interchangeable lenses, the SEL30M35 is currently the world's lightest life-size macro lens (approx 4.9 ounces) for interchangeable-lens cameras. This high-quality 30mm F3.5 macro lens features a 1:1 magnification ratio and minimum working distance of just 0.95 inches (2.4 cm), making it ideal for capturing detail-packed close-ups of small subjects like flowers and insects. Despite its extremely compact size, the SEL30M35 employs one ED glass and three aspherical lens elements for excellent optical performance, with minimized aberration and very high edge-to-edge sharpness and contrast. It also offers smooth, quiet autofocus operation whether shooting stills or HD video. The macro lens is supplied with a matching lens hood.
Also available as an option, the new HVL-F20S is a style-matching flash that clips onto the Smart Accessory Terminal of NEX-C3 and other E-mount cameras. Powered directly by the camera, the flash requires no batteries, making it ultra-compact and light weight for travelling. With a generous GN20 (50mm, at ISO 100, m) flash power rating and adjustable head, it's ideal for creating natural fill-in and bounce flash effects with portraits and everyday shooting subjects.
The expanded range of coordinating accessories features a new body case/lens jacket and a soft carrying case.
The new camera is also compatible with Sony's full line of SD memory cards, including the newest Class 10 versions, as well as the Memory Stick PRO-HG Duo HX series. Available in capacities up to 32 GB, both media enable higher read speeds for more stable and optimal performance by Sony hardware features such as high-speed burst shooting or HD movie shooting.
Firmware update for NEX-5, NEX-3
A firmware upgrade (Version 4) adds the new 'Picture Effect' function to existing NEX-5 and NEX-3 cameras. It also adds a Peaking function to assist with more precise manual focusing. This upgrade will be available June 20th and can be downloaded from: (www.esupport.sony.com).
Pricing and Availability
The new NEX-C3 ultra-compact digital camera will be available this August in silver, black and pink with an 18-55mm kit zoom lens (model SEL1855) and will cost about $650. It will also be offered in black only with a 16mm lens (model SEL16F28) for about $600.
The new SEL30M35 E-mount Macro lens will be available this October for about $250 and the HVL-F20S flash will be available this August for about $150.
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
