Sony Launches VPL-ES3 Versatile Entry-Level Projector
New Sony VPL-ES3 projector combines category-leading picture quality with affordability and flexibility
Sony today announced the launch of its versatile VPL-ES3 projector for use in the office, classroom or at home. Offering exceptional picture quality at an affordable price, the VPL-ES3 has six preset picture modes for use in different environments. The aspect ratio of 4:3 is ideal for data projection and the projector can be switched to 16:9 format for watching movies and gaming.
The VPL-ES3 has been built upon an optical unit with unique technology to embed 3LCD, which will ensure excellent picture quality and true colours. It will accept a wide range of sources including high definition images while the short focal lens enables the maximum screen-size of up to 300 inches (760 cm) to be achieved in even the smallest of rooms.
The VPL-ES3 represents a leap forward in picture quality within its category with a high maximum brightness setting of 2000 ANSI lumens, which means that neither natural nor artificial lights needs to be ‘blacked-out’ in order for the images to be seen with maximum clarity. The VPL-ES3 also offers a 1500-lumen mode for darker rooms and to avoid glare from highly reflective surfaces such as whiteboards.
“Now you really can have it all — affordability plus excellent brightness and picture quality. The VPL-ES3 has rewritten the rules of what constitutes an entry-level projector,” said Catherine Cherry, Product Marketing Manager for Sony Business Projectors. “The projector’s flexible settings ensure an outstanding user experience whether it’s used for a business presentation, in a classroom, watching a movie or playing games in the home.”
Flexible inputs and outputs: designed with the user in mind
The VPL-ES3 is designed with ease of use in mind. The simplicity of its construction and its user-friendly on-screen display interface ensures straightforward, hassle-free set up and operation – even for novice users. The projector is also equipped with a monitor-out connection, enabling the image to be displayed on a second screen. This feature is particularly useful for teachers because it eliminates the need to turn away from the class to look at the screen during a lesson.
The VPL-ES3 has the versatility to be operated in different environments — it is suitable for mobile use and is also ceiling mountable. It can be integrated with other equipment thanks to features such as audio output and RS232C for control. For example, the audio output connector can be linked up to an external speaker system to further enhance the user experience by providing professional sound quality to accompany the images on screen.
The projector delivers a range of different product innovations to assure optimum user convenience. These include a front-facing exhaust, so that the audience is spared the discomfort of hot air blowing directly at them. A discreet fan ensures a low noise level of just 29 decibels, which helps to minimise distraction for the speaker and the other people in the room. The VPL-ES3 can be operated by a credit-card style remote commander that uses infrared receivers located both at the front and back of the unit, which gives the presenter the option of controlling the presentation from different sides of the room.
The VPL-ES3 projector also offers a range of security features, including password protection and control-panel locking to ensure that unauthorised access is prevented. In addition, the VPL-ES3 is equipped with a Kensington lock fitting to prevent physical removal of the projector from a desk or work surface.
New support offering provides additional reassurance
The launch of the VPL-ES3 also corresponds with another key milestone for Sony business projectors. A brand new support package, from PrimeSupport offers customers free of charge, next-day delivery of a refurbished projector of the same specification, or the option of a repair. A telephone helpdesk (a free-to-call number in most European countries) provides technical advice as well as product collection and delivery support anywhere in the EU, Norway or Switzerland.
Catherine Cherry explained how this new projector combines style and performance with valuable support: “The VPL-ES3 will be the first Sony projector to offer a market-leading support package along with the stylish design and easy-to-use features that people expect from Sony. The new PrimeSupport offering also ensures that should a problem occur, our customers will receive a prompt and comprehensive response.”
The VPL-ES3 will be available from mid-March 2006.
Summary of Main Specifications
Panel Type: 0.63-inch p-Si LCD x 3
Resolution: SVGA (800 x 600 x 3)
Brightness: 2000 ANSI lumens (lamp mode high), 1500 ANSI lumens (lamp mode standard)
Contrast Ratio: 300:1
Weight: 2.9kg
Dimensions (w x h x d): 308×98×252 mm
Fan noise: 36/29dB
Standard Lens Zoom: 1.2 times / Manual
Vert. Keystone Correction: +/-15°
Lamp type: 165W
Lamp life: 2000/3000 hours*
Filter Cleaning Time: 500 hours
Speaker: 1W Mono
Throwing distance: 2.3 to 2.8m at 80-inch screen size
Screen coverage: 40 to 300-inch
Inputs: Analog RGB/Component (15 pin D-sub), Composite video, S-Video, Audio
Outputs: Monitor out (15 pin D-sub), variable audio out
Control: RS232C
IR receiver: Front and rear
Features: Security lock, control panel key lock, 6 picture mode ceiling mountable
* These are not the guaranteed number of lamp hours, but the recommended hours after which the lamp should be replaced to ensure optimum picture quality.
About Sony
Sony manufactures audio, video, communications and information technology products for the global consumer and professional markets. With its music, pictures, game and online businesses, Sony is uniquely positioned to be one of the World’s Leading Consumer Brands. Sony recorded consolidated annual sales of EUR 53.43 billion (yen 7,160 billion) for the fiscal year ended March 31, 2005 and it employs approximately 151,400 people worldwide.
In Europe, Sony recorded consolidated annual sales of EUR 12.03 billion (yen 1,613 billion) for the fiscal year ended March 31, 2005, based on an average market exchange rate for the same period of yen 134 to the EUR. Sony Europe, headquartered at the Sony Center in Potsdamer Platz in Berlin, is responsible for the company’s European electronics business and registered consolidated sales of EUR 8.87 billion for the fiscal year ended March 31, 2005.
About Professional Solutions, Sony Europe
Professional Solutions Europe (PSE), a division of Sony Europe, is a leading supplier of solutions for broad horizontal communications, AV/IT, as well as magnetic and optical storage. PSE’s market segment solutions, service and support packages are targeted at organisations in the Healthcare, Media, Network Video Monitoring, Retail, Transport and Large Venue sectors. Device components such as camera sensors and modules, displays, batteries and semiconductors are targeted at OEM manufacturers and system integrators. Sony’s Professional Solutions business offers its customers access to the expertise and local knowledge of skilled professionals in every European country, as well as “best of breed” hardware, services and resources from other organisations. For more information please visit www.sonybiz.net.
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
