Sony HT-S400 Soundbar Wireless Subwoofer System Unveiled
If you are looking for something basic to improve TV sound, the Sony HT-S400 $299 soundbar/subwoofer system might be right for you.
Sony HT-S400 Soundbar with Wireless Subwoofer
Sony has offered up some high-end soundbar and wireless speaker options, but there is also a large customer base looking for affordable soundbar systems for improving TV sound. If that is your desire, then the Sony HT-S400 might be a soundbar system for you.
There is nothing fancy like Sony 360 Reality Audio, Dolby Atmos/DTS:X, or 4K/UHD HDR pass-through, but for less than $300, there are some practical features that might just be the ticket.
Product Design
The Sony HT-S400 consists of a 35.5 inch wide 2 channel soundbar combined with a compact wireless ported subwoofer with a 6.3-inch driver.
Sony HT-S400 Soundbar with Wireless Subwoofer Front
Speaker Complement
Sony incorporates two X-balanced (rectangular) speakers within the sound bar unit. The rectangular shape increases effective diaphragm size and reduces the amount of in-out motion needed to produce sound.
Sony Regular Speakers vs. X-Balanced Speakers
Power Output
Total System: 330W distributed as follows:
Soundbar: 100W + 100W per channel = 200W total
Subwoofer: 130W; 200W + 130W = 330W
Note: No power rating reference point is provided
Audio Format Support
Sony HT-S400 Soundbar with Wireless Subwoofer Sound Waves
Traditional Formats: Dolby Digital, Dolby Dual Mono, LCPM 2ch
S-Force PRO Virtual Front Surround: This feature creates an immersive soundfield from 2.1 channels utilizing the 2 speakers integrated into the soundbar.
Additional Sound Settings: Night Mode (maintains an even frequency range at low volume), Voice Mode (for when you can hear the dialog over all the other sound effects), Sound Field (provides a surround sound listening experience from two-channel stereo sources).
Control
The HT-S400 can be controlled via the provided wireless remote or control buttons on the soundbar.
Sony HT-S400 Soundbar Remote Control Buttons
Tip: When connected to select Sony Bravia TVs via HDMI, Soundbar settings automatically appear onscreen in the TV’s Quick Settings menu.
Connectivity
Sony HT-S400 Soundbar Rear Connections
HDMI-ARC: This transfers audio directly from the TV to the soundbar using an HDMI cable. The TV has to have an HDMI connection labeled HDMI-ARC or eARC for this to work.
Digital Optical: If your TV doesn’t have an HDMI-ARC connection, this is the next best option to get audio from your TV to the soundbar.
Tip: The HT-S400 does not provide an analog audio connection option.
Bluetooth (ver 5.0): Receiver only. This means that you can play music from smartphones, tablets, and laptops/PCs on the HT-S400 but you can’t use the soundbar to send sound to Bluetooth headsets or external Bluetooth speakers.
Tip: The HT-S400 can connect to select Sony TVs wirelessly via Bluetooth. This means that an HDMI-ARC or Digital Optical connection may not always be required.
USB: Firmware Update Only
What’s In The Box
  • Soundbar and Subwoofer
  • Optical Cable (HDMI cable not included)
  • Wireless Remote Control with batteries
  • AC power cable
  • Quick Setup Guide
  • Instruction Manual
Tip: The HT-S400 can be wall mounted if desired, but mounting hardware is not included.
Sony HT-S400 Soundbar Sound Waves
Pricing and Availability
The Sony HT-S400 is available for pre-order for $299.99 at Amazon, direct from Sony.com or through authorized Sony dealers. The expected release date is set for April 15th, 2022.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Can the first child of Audeze and Sony be a sonic superman for only $150? The Sony Pulse Elite is for more than just...
HDTV 4K & 8K TV
There's a new OLED TV in town and it's sure to be a top contender for best TV of 2025.
Open wireless earbuds are gaining in popularity as more users are becoming concerned about situational awareness. Sony's Linkbuds Open provide a rather unique take.
With trickle down technology from its flagship XM series, Sony's LinkBuds Fit offer some great features for those looking for a reliable workout earbud.
Sony just unveiled two new entry-level Dolby Atmos-compatible soundbars for those who want to beef up their TV sound without breaking the bank.
