Hard Drives
Sony HD-PG5 500GB External Hard Drive
Sony introduced its first ever range of external hard drives. The HD-PG5 series offers 500GB and high-speed transfer via USB 3.0. Model HD-PG5U connects via USB with compatible BRAVIA models, allowing direct recording of HD television programs from the TV's tuner or connected cable/satellite service. The supplied USB adaptor cable also allows easy 'PC-free' transfers of video footage from compatible Handycam camcorders with Direct Copy function, including the new DCR-SX21E and DCR-SR21.
PlayStation 3 users can connect the hard drive via USB and view stored AVCHD videos via the 'Filmy' application — with no PC needed.
Available in a choice of black or white finishes and weighing a travel-friendly 180g, the stylish drives coordinate beautifully with your PC, BRAVIA or PlayStation 3. The smoothly-contoured case is finished in a scratch-resistant paint layer that keeps your drive looking good for longer. The minimalist design is enhanced by a single blue LED that indicates drive activity.
Connection to your PC is via a single USB cable, with no separate power adaptor needed. Support for USB 3.0 SuperSpeed assures blazing data transfers up to 3x with compatible PCs. Even if you're connected via USB 2.0, pre-loaded Data Transfer Accelerator software also doubles effective transfer rates to slash backup times when you're in a hurry.
All HD-PG5 models are ready to use with a generous suite of security and backup applications. Easy-to-use Password Protection Manager software uses powerful 256-bit security to safeguard your files against unauthorised access. Just key in your personal password to lock or unlock data when the HD-PG5UB is connected to any PC. Backup Manager software takes care of protecting your precious files with automated scheduled backups.
Price and Availabililty
The Sony HD-PG5 series of 500GB external hard drives are available this month for $119.
Specifications
Disk size 2.5 inch
Capacity 500GB
USB port USB 3.0/USB 2.0×1
Transfer Rate (Max) Max. 5Gbps (USB 3.0) / Max. 480Mbps (USB 2.0)
Supported OS Windows 7 (32bit/64bit); Windows Vista (32bit/64bit); Windows XP; Mac OS X 10.4 or later
(NB: Mac OS supports only USB2.0)
File System NTFS [model HD-PG5U: FAT32]
Package Dimension (Approx. W x H x D) 80x16x126mm
Package Weight (Approx.) 180g
PC Software (pre-loaded) Data Transfer Accelerator, Backup Manager, Password Protection Manager, FAT32 Formatter
Cable USB 3.0 cable (60cm) Standard-A to Micro-B
[Model HD-PG5U only: supplied cable length 1m / includes supplied USB adaptor cable for Handycam]
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
