Camera Lenses
Sony Announces Flagship G Master E-Mount Lenses
Sony G Master Interchangeable Lenses
Sony announced three E-mount full frame G Master interchangeable lenses for Sony α (Alpha) mirrorless cameras, including the new Alpha 6300. The new flagship lenses include a 24-70mm constant F2.8 standard zoom, an 85mm F1.4 prime and a 70-200mm constant F2.8 telephoto zoom. Each features Sony’s innovative optical element technology, design and calibration. Sony says this allows them to produce still image and video content with a level of detail and expression that has never before been possible.
Sony FE24-70mm F2.8 GM Standard Zoom Lens
The new FE 24-70mm F2.8 GM (model SEL2470GM) is engineered for portrait, travel and event photography or even simple everyday shooting. It is built with three aspherical elements including a newly developed, extremely precise XA (extreme aspherical) element that reduces aberration and delivers the ultimate resolution throughout the entire zoom range and aperture range, as well as from corner to corner of all image files. Additionally, an ED (Extra-low-Dispersion) glass element and Super ED glass element keep chromatic aberration to a minimum while maximizing resolution and bokeh without any unnatural coloration.
The lens features a 9-bladed aperture that maintains a near circular shape at all settings and is coated with Sony’s original Nano AR coating to suppress reflections and ensure spectacular contrast and clarity.
It also has a direct drive SSM (Super Sonic wave Motor) focusing system that positions the lens elements quickly and accurately. The motor is smooth and quiet, making it an ideal choice for shooting both still images as well as movies.
To maximize usability, the lens is dust and moisture resistant and features a compact, streamlined design that includes AF/MF switch as well as focus hold, zoom lock and hood release buttons.
Two new matching filters for the FE24-70mm F2.8 GM lens have also been introduced, including the VF-82MP MC protector and VF-82CPAM Circular PL filter.
Sony FE 85mm F1.4 GM Telephoto Prime Lens
Designed as the ultimate portrait lens, the new FE 85mm F1.4 GM telephoto prime lens (model SEL85F14GM) aims to strike a perfect balance between resolution and bokeh in a compact package.
The lens features a new XA (extreme aspherical) element as well as three ED glass elements that work together to ensure that the in-focus areas are captured in extremely high resolution while the surrounding out-of-focus areas dissolve smoothly into a beautiful soft backdrop. It has a circular aperture with 11 blades – the most ever used in an α lens – that ensures bokeh is smooth and visually appealing. Externally, the new model has Sony’s original Nano AR Coating, which is of particular importance in a portrait lens as it reduces flare and ghosting, even with backlit subjects or similarly challenging lighting conditions.
For accurate autofocusing, the FE 85mm F1.4 GM lens includes a ring drive SSM motor system that provides ample power and speed to drive the lens’ large, heavy focus group. It’s also equipped with two position sensors to support flawless focus control of the large, heavy lens elements.
This new professional portrait lens is dust and moisture resistant and also has an aperture ring with on/off switchable click stops that can be adjusted based on whether a user is shooting still images or movies. It also has an AF / MF switch and a focus hold button2.
Sony FE 70-200mm F2.8 GM OSS Telephoto Zoom
The new telephoto zoom lens (model SEL70200GM) offers extremely high rendering, AF performance and image stabilization, making it a versatile choice for shooting wildlife, sports, weddings and a variety of other events and locations1.
Sony’s new flagship telephoto zoom lens claims to deliver sharpness and clarity throughout the entirety of its zoom range thanks to its three advanced lens elements including XA, Super ED and ED glass components, as well as its Nano AR coating.
The new FE 70-200mm F2.8 GM OSS lens features a floating focusing system – implemented in an α zoom lens for the first time – that contributes to an impressive minimum focusing distance of merely 0.96m and ensures AF performance is optimized during both still and video shooting. The lens includes a SSM (Super Sonic Motor) plus dual linear motors that work together to move large lens elements quickly – a task that requires a high level of drive control and ensures focus accuracy. The new model also has built in Optical SteadyShot image stabilization for capturing sharp, blur-free subjects at all focal lengths and a rotating tripod mount that allows the camera to be quickly removed from a connected tripod as needed.
The new 70-200mm telephoto zoom lens is dust and moisture resistant with an additional fluorine coating added to the front lens. It also has a focus hold button as well as a focal range limiter.
Sony has also announced new compact 1.4x and 2x Teleconverters – models SEL14TC and SEL20TC respectively – that offer even greater reach while maintaining the overall streamlined design and feel of the 70-200mm lens.
Pricing and Availability
  • Sony FE 24-70mm F2.8 GM Standard Zoom – $2,200 (March 2016)
  • Sony FE 85mm F1.4 GM Telephoto Prime – $1,800 (March 2016)
  • Sony FE 70-200mm F2.8 GM OSS Telephoto Zoom – Price TBD (May 2016)
Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
