Earbuds & In-Ear Headphones
Sony Ericsson VH300 Bluetooth Headset
The new Sony Ericsson Clip-on Bluetooth™ Handsfree VH300 — an easy to use headset with rich sound. The stylish handsfree features one-touch call handling, handy volume control and an ultra discreet reversible clip-on which will match any outfit. Just clip it onto your clothing and wear its wired ear piece around your neck — and off you go. You’ll never notice this innovative Bluetooth™ handsfree — until you take or make a call.
  • One touch call handling
  • Ultra discreet reversible clip-on
  • Handy volume control
  • Smart wearing solution — perfect if you wear glasses
  • Talk and stand-by time 10h/250h
The S312 supports GSM/GPRS/EDGE/900/1800 and will be available in selected markets from Q2 in the colours Dawn Blue and Honey Silver. The Clip-on Bluetooth™ Handsfree VH300 will be available on selected markets from Q3 2009.
The Sony Ericsson Clip-on Bluetooth™ Handsfree VH300 at a glance
Design
  • Colours: Stellar Silver, Argentum Black
  • Materials: Plastic
  • Size: 48.5×18.0x18.5mm
  • Weight: 20g
Technology
  • Talk/Standby time: 10/250h
  • Bluetooth™ version: 2.0+EDR
  • Bluetooth™ range: 10m
  • Bluetooth™ simple pairing: yes
Compatibility
  • Most Bluetooth™ phones from SEMC and other brands
Availability
  • Available in selected markets from Q3 2009
Networking
In-Wall Speakers
