DSLR Cameras
Sony DSLR-A380, DSLR-A330 and DSLR-A230 Digital Cameras
Designed For First-Time Digital SLR Buyers
Sony is making it easy for first-time digital SLR buyers to step up from point-and-shoot digital still cameras with the introduction today of three new easy-to-use α (alpha) cameras (models DSLR-A380, DSLR-A330 and DSLR-A230), four new lenses, a flash and accessories.
Sony DSLR-A380
Uniquely Matched to Customers’ Needs
The new cameras are designed to overcome challenges faced by many customers taking their first steps in DSLR photography. Without compromising performance and versatility, the new models are smaller, lighter, easier to use and offer innovative expansion options not found in other systems.
“Our new alpha cameras, lenses and accessories make it easier for new users to get the great photos they expect without the steep learning curve that DSLRs have traditionally required,” said Kristen Elder, senior manager for the alpha business at Sony Electronics Inc. “By overcoming the obstacles, we’ve made it much easier for newcomers to take great pictures with DSLRs.”
Sony DSLR-A230
Sony DSLR-A230
Light and Compact
The 10.2 megapixel α230 camera is the lightest, most compact alpha DSLR camera body ever at 15.9 ounces. The 10.2 megapixel α330 and the 14.2 megapixel α380 cameras are also smaller and lighter than their predecessor models (the DSLR-A300 and DSLR-A350, respectively). These cameras are also more compact and feature an intuitive control layout that allows for easy single-handed operation.
SteadyShot INSIDE™ in-camera image stabilization is built into each camera body, so every α-mount lens benefits from the ability to minimize blur due to camera shake.
Sony DSLR-A380
Sony DSLR-A380
Quick AF Live View System
Both the α380 and α330 cameras offer Sony’s Quick Autofocus (AF) Live View technology, so you can frame photos on the camera’s LCD screen as well as in the optical viewfinder. Through the use of a dedicated image sensor, Quick AF Live View maintains the rapid response of a DSLR, while avoiding the focus delay common to other live view systems.
The new cameras feature a 2.7-inch (diagonally) Clear Photo LCD™ screen that is easy to view even in bright sunlight. Additionally, the LCD on the α380 and α330 models can be tilted up or down, making it easy to frame your subject from high or low positions, otherwise difficult to see using an eye-level viewfinder. The range of adjustment has been increased from their predecessors, making it even easier to get shots from difficult angles.
Sony DSLR-A330
Sony DSLR-A330
By combining Quick AF Live View and an adjustable LCD, users can frame the scene without holding the camera in front of their face, allowing parents, for example, to maintain eye-contact when photographing their children for more natural expressions.
An HDMI™ terminal gives you the option of connecting your camera to a compatible HDTV and playing back your images in high definition quality (HDMI cable required, sold separately). Additionally, BRAVIA Sync™ works with compatible Sony BRAVIA HDTVs to let you control camera playback using the television’s remote (HDMI cable and BRAVIA Sync capable HDTV required, sold separately).
The new cameras include dedicated slots for high-capacity Memory Stick PRO Duo™, Memory Stick PRO-HG Duo™ and SD/SDHC media (sold separately).
Built-in Help Guide
The α380, α330 and α230 models are Sony’s first DSLR cameras to feature a graphical user interface (GUI) with built-in on-screen Help Guide.
The Help Guide offers clear, concise explanations of various modes and settings, while the Graphic Display helps you understand the relationship between aperture and shutter speed, as well as the effect each has on photographic results.
Systems, Lenses and Flash
Making it easier for first-time DSLR users to get started, the new Sony cameras come in camera-and-lens packages. In addition to the two new standard zoom and telephoto lenses that are offered with the camera bodies, the company introduced new portrait and macro lenses. These purpose-built lenses make it much easier to obtain professional-looking, creative results.
Optimized for use with APS-C sized image sensors, these lenses feature a Smooth Autofocus Motor (SAM) that enables in-lens auto focus (AF) drive for smooth, quiet operation, and high optical performance in a compact size.
The DT 18-55mm F/3.5-5.6 standard zoom lens (model SAL-1855) incorporates aspherical and Extra-low Dispersion (ED) elements to provide an all purpose lens with outstanding image quality. The DT 55-200mm F/4-5.6 telephoto zoom lens (model SAL-55200/2) features an ED glass element and helps bring distant subjects closer, ideal for capturing sports. Both the SAL-1855 and SAL-55200 lenses are available separately, or packaged as kits with the new cameras.
To make the benefits of portrait and macro photography easier and more accessible, Sony is introducing a DT 50mm F/1.8 portrait lens (model SAL-50F18) and DT 30mm F/2.8 (model SAL-30M28) macro lens. The wide aperture SAL-50F18 lens helps users capture beautiful portraits with gently defocused backgrounds while the SAL-30M28 macro lens captures intricate close-ups. Both techniques are difficult to achieve with standard lenses.
HVL-F20AM Flash
HVL-F20AM
To help users take better shots with flash, Sony offers an affordable, compact external flash unit (model HVL-F20AM) that is simple to operate. Unlike a camera’s built-in flash, this external flash provides higher output (Guide Number 20), and enables users to bounce light off the ceiling to eliminate harsh shadows and achieve more even illumination when shooting indoors.
Pricing and Availability
Pre-orders will begin on May 18, 2009 at www.sonystyle.com. and at selected retailers nationwide. The cameras and a range of accessories will be available in July at Sony Style retail stores, at military base exchanges and at authorized dealers nationwide.
The α380L, α330L and α230L will cost about $850, $650 and $550, respectively. The L series one-lens kit comes with the SAL-1855 standard zoom lens.
The α380Y, α330Y and α230Y will cost about $1050, $850 and $750, respectively. The Y series two-lens kit comes with both the SAL-1855 standard zoom and SAL-55200 telephoto zoom lenses.
  • The SAL-1855 standard zoom lens will cost about $200.
  • The SAL-55200 telephoto zoom lens will cost about $230.
  • The SAL-50F18 portrait lens will cost about $150.
  • The HVL-F20AM flash will cost about $130.
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
