Digital Photo Frames
Sony DPP-F700 Digital Photo Frame Printer
Unique Digital Photo Frame With Built-in Printer Makes It Easy to View and Share Images
  • Sony Electronics is launching a stylish multitasking S-Frame digital photo frame with printer (model DPP-F700).
  • The sleek, all-in-one device allows photo viewing and printing for picture lovers who enjoy displaying and sharing copies of their special memories.
  • Showcasing your favorite photos in vibrant color and crisp detail, the DPP-F700 features a 7-inch (measured diagonally) (16:10) LCD display with WVGA (800 x 480) resolution.
  • The device prints 4 x 6-inch professional quality 300 x 300 dpi photos instantly in just 45 seconds.
  • Allowing you to edit images before printing, the device’s options include enlarge, reduce, crop, date stamp on/off, border/borderless (for single prints), and brightness, contrast, hue, and sharpness adjustment.
  • In Creative Print mode, you can make a calendar with pictures (more than 30 templates), print an ID photo, and create a “layout print” with multiple images on one sheet.
  • Using Screen Capture, you can print exactly what is displayed on the screen during a slideshow.
  • The frame-printer device features about one gigabyte of internal storage capacity with an auto-resizing adjustment that downsizes photos to let you store up to 2,000 photos.
  • Image transfer is a snap with direct USB input from your PC, as well as support for most memory cards, including Memory Stick PRO™, Memory Stick PRO Duo™, Secure Digital (SD), SDHC, Multi-Media Card (MMC), Compact Flash, and xD-Picture Card™ media.
  • Whether the device is set vertically or horizontally, the Auto Orientation sensor automatically rotates your photos into portrait or landscape format according to the placement.
  • A wide range of view and print modes and many other functions can be managed from the included remote control.
  • Multiple playback options offer flexibility to display photos as single images, as thumbnails for easy searching, or as a slideshow with ten built-in transitions.
  • The new S-Frame model supports JPEG, TIFF, and BMP image file formats.
  • Supplied accessories include a paper tray, AC adaptor, CD-ROM (print driver, PMB), operation manual, cleaning kit, and stand.
  • Optional print packs include compatible SVM-F series: SVM-F40P (40 sheets of photo paper and cartridge), and SVM-F120P (120 sheets of photo paper and cartridges).
  • The DPP-F700 digital photo frame-printer will be available for about $200 in January.
Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
