There’s no shortage of “budget” speakers out there, but most still expect you to drop half a grand before you even plug them in. Sony’s CS Series isn’t pretending to be that. This is entry-level gear, plain and simple—built for folks who want decent sound in a bedroom, home office, small living room, or starter home theater without blowing the budget.
With the SS-CS5M2 bookshelf speakers, SS-CS3M2 towers, SS-CS8M2 center channel, and SS-CSEM2 Atmos modules, Sony’s giving you the basics: clean sound, solid build quality, and prices that leave room in the cart for an AVR—and maybe even a sub. No nonsense, no audiophile marketing fluff. Just speakers that get the job done.
These new additions to Sony’s CS Series are built to deliver a solid music or home theater experience for listeners who don’t want to max out their credit card. Sony would love for you to pair them with one of their A/V receivers, but you’re free to mix and match with whatever you already have. Just don’t forget—you’ll need to bring your own subwoofer if you want to feel the low-end.
Here’s a quick look at each speaker joining the lineup:
SS-CS3M2
The SS-CS3M2 is a 3-way, 4-driver floorstanding speaker designed to deliver balanced sound with extended high-frequency detail and solid low-end performance. It features dual 5.12″ woofers with reinforced cones for added bass impact, a high-precision soft dome tweeter, and Sony’s wide dispersion super tweeter to support high-resolution audio playback. Housed in a ported bass reflex cabinet, the SS-CS3M2 is rated for a frequency response of 45 Hz to 50,000 Hz—well beyond the range of human hearing at the top end—making it compatible with Hi-Res Audio content.
SS-CS5M2
The SS-CS5M2 bookshelf speakers are compact and versatile, featuring a 3-way, 3-driver design with a 5.12″ woofer, soft dome tweeter, and wide dispersion super tweeter. They deliver a broad frequency response from 53 Hz to 50,000 Hz, supported by a rear-mounted bass reflex port that enhances low-frequency output.
These speakers work well as mains in a compact audio or home theater setup—perfect for smaller rooms—or as surround speakers when paired with the floorstanding SS-CS3M2 and front main speakers.
SS-CS8M2
The SS-CS8M2 is a 2-way, 3-driver center channel speaker designed for flexible placement—horizontally or vertically—though it does not include wall-mount options. Focused on delivering clear dialogue and rich vocal depth, it features dual 3.94″ woofers paired with a high-precision soft dome tweeter. A rear-mounted bass reflex port enhances low-frequency performance, helping to fill out the sound in home theater setups.
SS-CSEM2
The SS-CSEM2 is a Dolby Atmos Enabled upfiring height speaker designed to sit atop either the SS-CS3M2 floorstanding or SS-CS5M2 bookshelf speakers. It reflects sound off the ceiling to enhance Dolby Atmos immersive audio. You can place two on top of the front or surround speakers, or use four—positioned on both front and rear speakers—depending on how many height channels your AVR supports. Each SS-CSEM2 houses a single 3.94″ full-range driver in a sealed cabinet for clear, focused upward-firing sound.
Comparison
SS-CS3M2 | SS-CS5M2 | SS-CS8M2 | SS-CSEM2 | |
Speaker Type | Floorstanding | Bookshelf | Center-Channel | Upfiring Height |
Price | $279.99/each | $249.99/pair | $229.99/each | $249.99/pair |
Driver Configuration | 3-way, 4 drivers | 3-way, 3 drivers | 2-way, 3 drivers | 1-way, 1 driver |
Super Tweeter | 19mm dome type x 1 | 19mm dome type x 1 | N/A | N/A |
Tweeter | 25mm dome type x 1 | 25mm dome type x 1 | 25mm dome type x 1 | N/A |
Full Range | N/A | N/A | N/A | 10cm cone type x 1 |
Woofer | 13cm cone type x 2 | 13cm cone type x 1 | 10cm cone type x 2 | N/A |
Port (Bass Reflex) | Front Port | Rear Port | Rear Port | Sealed |
Impedance | 6 ohms | 6 ohms | 6 ohms | 6 ohms |
Sensitivity (2.83V / 1m) | Not indicated | Not Indicated | Not Indicated | 86dB |
Frequency Response | 45Hz-50kHz | 53Hz-50kHz | 55Hz-25kHz | 70 Hz – 32,000 Hz (Conforms to Dolby Atmos Specification) |
Crossover Frequency | 2.5kHz, 17kHz | 2.5kHz, 17kHz | 2.5kHz | Not Applicable |
Maximum Input Power | 145W | 100W | 145W | 100W |
Speaker Terminals | Screw Type | Screw type | Screw type | Push type |
Enclosure Material | Wood | Wood | Wood | Wood |
Grille | Detachable/Cloth | Detachable/Cloth | Detachable/Cloth | Detachable/Cloth |
Finish | Cloth (Grille), PP Sheet (Cabinet) | Cloth (Grille), PP Sheet (Cabinet) | Cloth (Grille), PP Sheet (Cabinet) | Cloth (Grille), PP Sheet (Cabinet) |
Dimensions (WHD) | 230 x 921 x 260 mm 9 1/8 x 36 3/8 x 10 1/4 in. | 178 x 335 x 220 mm 7 1/8 x 13 1/4 x 8 3/4 in. | 430 x 146 x 220 mm 17 x 5 3/4 x 8 3/4 in. | 178 x 146 x 190 mm 7 1/8 x 5 3/4 x 7 1/2 in. |
Weight | 11.1 kg / 24 lbs 8 oz | 4.3 kg / 9 lbs 8 oz | 5.1 kg / 11 lbs 4 oz | 2.8 kg / 6 lbs 3 oz |
The Bottom Line
We’ve covered plenty of high-end speakers with jaw-dropping price tags, but let’s be honest—not everyone needs that level of complexity or cost. The Sony CS Series offers a straightforward, well-built option that delivers solid sound for those on a budget or anyone looking for a reliable secondary system without breaking the bank.
If you’re curious, head to a dealer and give them a listen. They might just surprise you. And if they’re not your cup of tea, the market is packed with plenty of alternatives across brands, designs, and price points to fit your needs.
Price and Availability
All four products are available for Pre-Order through Sony Electronics and authorized retailers. Shipping is expected to begin in July. 2025.
- SS-CS3M2 Floorstanding Speaker: $279.99/each at Amazon | Sony
- SS-CS5M2 Bookshelf Speakers: $249.99/pair at Amazon | Sony
- SS-CS8M2 Center-Channel Speaker (Each): $229.99/each at Amazon | Sony
- SS-CSEM2 Dolby Atmos® Enabled Upfiring Height Speakers: $249.99/pair at Amazon | Sony
Related Reading
