Sony BRAVIA BX450 and BX330 Series LCD HDTVs Announced
For 2012, Sony has released their entry-level and lowest priced BRAVIA LCD HDTVs with two BX450 Full HD 1080p HDTVs in 40- and 46-inch diagonal screen sizes and the 32-inch BX330 720p HDTV. Both BX series models provide a 60Hz panel with Digital Noise Reduction, 2 HDMI inputs, and a USB media player. The BX450 series adds a Clear Resolution Enhancer claiming better, well-defined images with reduced picture noise.
The BX Series (and higher models) allow you to share your vacation photos instantly on the big screen or listen to your favorite music and simply connect your compatible digital camera, USB-enabled MP3 player or USB storage device directly to your HDTV's USB input. Additionally, four HD inputs include two HDMI inputs for sources like your HD cable box, home theater system, Blu-ray Disc player or PS3 system, one HD component input and a PC input (HD-15 pin) which lets you use your HDTV as a computer monitor.
BRAVIA BX450-series LCD HDTV
  • Full HD (1080p) CCFL backlight LCD HDTV
  • 60Hz panel with Clear Resolution Enhancer and Digital Noise Reduction
  • 1920×1080 resolution
  • USB Media Player
  • 2 HDMI inputs
Sony BRAVIA KDL-BX330 Series LCD HDTV
BRAVIA BX330-series LCD HDTV (above)
  • 60Hz panel (720p) with Digital Noise Reduction
  • 1366 x 768 resolution
  • USB Media Player
  • 2 HDMI inputs
Price and Availability
46-inch KDL-46BX450 → $699.99
40-inch KDL-40BX450 → $499.99
32-inch KDL-32BX330 → $329.99
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
