Check Out Sony’s Compact New Bluetooth Speaker, the SRS-XB100
Sony’s latest compact Bluetooth provides punchy sound for under $60.
Sony SRS-XB100 Portable Bluetooth Speakers
Bluetooth wireless speakers come in all shapes and sizes these days. Sony’s latest offerings illustrate that fact. Today, Sony officially unveiled two new speakers in its Bluetooth speaker line: the compact SRS-XB100 ($59) and the powerhouse SRS-XV800 ($649.99). At a press event in Manhattan we got to check out both speakers in action. The little guy can be paired with a twin for stereo listening, but it packs a wallop on its own.
Sony-SB100-in-hand-20230507_163714
Say “Hello” to my little friend, the Sony SRS-XB100 Bluetooth speaker.
The SRS-XB100 is cylindrically shaped, measuring 3 inches in diameter and about 3 3/4 inches high, and weighing about 10 ounces. The XB100 is Sony’s only Bluetooth speaker that doesn’t use Sony’s Music Center mobile app for synchronization or sound adjustments. Honestly, it doesn’t need the app to do what it does: play audio from a Bluetooth source like a phone or tablet.
Pairing the speaker with a second one for stereo listening is done via a few button presses on the speaker itself. The XB100 also includes a built-in microphone so it can be used as a speakerphone for voice calls or video conferences. It even includes a “multi-way strap” so you can carry it around safely with the strap around your wrist or tie it to your parachute while skydiving. May I suggest Tom Petty’s “Free Fallin'” for that particular playlist?
Sony-SRS-XB100-backpack-900px
Sony’s SRS-XB100 goes where you go.
At $59/each or $118 for a pair, it’s hard to go wrong with the SRS-XB100. When I turned it on and hit the Bluetooth button a pairing message popped up on my Android phone almost immediately and the pairing process completed within seconds. If you crank it up, it can definitely get loud, with an up-firing driver that radiates sound 360 degrees. Vocals come through cleanly and bass response is surprisingly solid considering its compact size. Battery life is rated at 5 to 16 hours, depending on volume and a full recharge takes about 4.5 hours using the included USB-A to USB-C cable.
Sony-SRS-XB100-Aquamarine-Beach-900px
With an IP67 rating, the waterproof SRS-XB100 speaker makes an excellent beach companion.
The matte finish has a nice textured feel to it that makes it easy to grip and less likely to be dropped. But if it does escape your grasp, don’t fret. Its IP67 rating means it will survive the occasional dip in the ocean (or bathtub). The speaker is available in black, light gray, light blue and orange finishes.
The SRS-XB100 is available to pre-order from authorized Sony retailers starting today and is expected to begin shipping later this month (May, 2023).
> Find Out More or Order the Sony SRS-XB100 on Amazon.com
Related Reading:
Sony’s New SRS-XV800 Bluetooth Speaker Lets You Take the Party With You
SoundCore Announces New Outdoor Bluetooth Speaker with Spatial Sound
Beats Cables Promo Image
Audio Cables
Networking
Earbuds & In-Ear Headphones
PS Audio PMG Signature Series Audio Components
In-Wall Speakers
HDTV 4K & 8K TV
Last month, we got a sneak peek at Sony’s new BRAVIA 4K TVs. Here’s what’s coming down the pike this year.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Can the first child of Audeze and Sony be a sonic superman for only $150? The Sony Pulse Elite is for more than just...
HDTV 4K & 8K TV
There's a new OLED TV in town and it's sure to be a top contender for best TV of 2025.
Open wireless earbuds are gaining in popularity as more users are becoming concerned about situational awareness. Sony's Linkbuds Open provide a rather unique take.
Devialet today announced Gold Phantom, which claims to be the most extreme self contained speaker ever made. It boasts a maximum volume of 108db...
With trickle down technology from its flagship XM series, Sony's LinkBuds Fit offer some great features for those looking for a reliable workout earbud.
