Mirrorless Cameras
Sony Alpha 6300 Camera Claims Fastest Autofocus
Sony ILCE-6300
Features World’s Fastest AF speed with 425 Autofocus Points and New  24.2 MP APS-C Sensor, and 4K video recording
Sony today announced the 24-megapixel α6300 digital camera that claims to offer the world’s fastest autofocus at 0.05 seconds. The $1000 mirrorless camera, which replaces the α6000 model, shoots 4K video and has built-in Wi-Fi and NFC.
The α6300, known as the Alpha 6300 (model ILCE-6300) has 425 phase detection autofocus points over nearly the entire field of view. The camera captures 11 fps continuous shooting or 8 fps continuous in new live-view mode. Other enhancements to the a6300 include silent shooting functionality the ability to use AF in focus magnifier mode, expanded flexible spot AF, Eye AF in AF-C mode and more.
The a6300’s new 24MP image sensor employs copper wiring in its structure, which improves light collection efficiency and significantly accelerates readout speed. The BIONZ X processor features an upgraded image processing algorithm designed to maximize the sensor’s overall capabilities. Together, the two key components work together to produce images with low noise and exceptional resolution in sensitivity settings up to ISO 51200, in particular in the mid-to-high sensitivity range.
https://youtu.be/83ZSD-zj73A?list=PLL06nPE7_lzMvZSNyhbYhJ_5G_J9HiXD8
In another first for non-full-frame Sony interchangeable lens camera, the new α6300 offers internal 4K movie recording in Super 35mm format. When shooting in 4K, the camera uses full pixel readout without pixel binning to collect 20 megapixels of information – approximately 2.4×5 (6K equivalent) as many pixels as 4K UHD and then oversamples the information to produce high quality footage with exceptional detail and depth.
The camera utilizes the XAVC S codec during video shooting, which records at a high bit rate of 100 Mbps during 4K recording and 50 Mbps during standard Full HD shooting, ensuring maximum detail and clarity in both video formats. Additionally, the camera will focus approximately twice as fast as its predecessor during movie shooting thanks to its new and improved AF system. AF speed and AF tracking sensitivity are also adjustable for expanded creativity.
Other professional caliber video features include the ability to record Full HD at 120 fps at 100 Mbps, another first for α interchangeable lens cameras with APS-C sized sensors. This mode allows footage to be reviewed and eventually edited into 4x or 5x slow motion video files in Full HD8 (24p or 30p) resolution with AF tracking The new a6300 also offers S-Log gamma recording for wide dynamic range shooting – approximately 14-stop latitude in S-Log gamma setting – and supports S-Gamut for a wider color space. Both options allow for greater creativity for processing video post-production.
Also included on the new camera is a microphone line input that accepts external microphones and also supports XLR input with Sony’s XLR adapter kit, as well as Gamma Display Assist, a new function that allows users to monitor images or check focus when recording S-Log movies. The new model has enhanced Zebra functionality for greater exposure control. Picture profile settings are available, as well as Time Code / User Bit and much more.
The α6300 camera is equipped with a high contrast, high-resolution XGA OLED Tru-Finder with approximately 2.4 million dots that offers exceptional corner-to-corner visibility. There is also a new mode available for the viewfinder that allows display of images at 120 fps, ensuring that action is displayed smoothly with very few afterimages, making subject tracking through the Tru-finder easier than ever.
Aesthetically, the new α6300 camera features an extremely solid feel in hand thanks to its robust, magnesium alloy design. It can be customized to fit nearly any shooting style or preferences, with 9 customizable buttons that one of 64 different functions can be assigned to. The camera adds a digital level gauge as well as upgraded dust and moisture resistance, a reinforced lens mount structure and a new shutter release button and mode dial with improved operability and grip.
Pricing and Availability
The Sony α6300 interchangeable lens camera will be available in March 2016 for $1,000 for the camera body or for about $1,150 paired with a 16-50mm F3.5 – F5.6 kit lens (model SELP1650). Prices for the Canadian market will be about $1,350 CA for the body and about $1,500 CA for the camera kit. It will be sold at a variety of Sony authorized dealers throughout each region.
The α6300 is compatible with Sony’s lineup of α lenses including the new premium G Master lenses also announced today.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
