Sonus faber Lilium Loudspeakers
Sonus faber introduced the Lilium full frequency range high end floor standing speaker, built around the knowledge gained through the creation of their flagship Aida loudspeaker. There is one enclosure for the subwoofer, with a “no port noise” passive radiator (heritage of Ex3ma), decoupled from the enclosure of the main spectrum radiators and with the axis of subwoofer and ABR at 90° (orthogonal) to the main radiation axis of all other drivers, to avoid any direct/indirect modulation.
The driver units complement are a totally new project and a 100% Sonus faber design and development; of course they follow a musical attitude that is becoming every day more and more recognizable: a new high-speed 29mm soft dome DAD tweeter, a new midrange and new midwoofers, both having a size of 180 mm (same diameter and similar structure for the best “merging” of the relative spectra). Finally the 11” subwoofer and its companion ABR are also special, in the sense that they have been sonically optimized for these very low frequencies’ reproduction.
3.5 way, orthogonal non interactive dual enclosure, para-aperiodic vented box “Stealth Reflex System” on the main enclosure, passive radiator tuned and “Zero Vibration Transmission” technology on the subwoofer enclosure, modulation-free 90° and decoupled from the main one, staggered low frequency floorstanding loudspeaker system.
The crossover also pays a strong tribute to the Ex3ma, borrowing some of it’s key solutions.
Cabinet
“Lyra shape” design, progressive thickness triple curvature cabinet walls damped spread resonance spectrum system, Sub–structural ribs are strategically placed for total rejection of spurious vibrations and standing waves control. Two double “dampshelves” (from “The” experience), i.e. CNC anodized machined avional “vibration dampers” (on the top and on the bottom of each cabinet) “stiffen” the column structures reducing consistently structural micro-vibrations coming from the cabinets’ walls and the transducers. The “Anima legata” system is used in an innovative way, encompassing the structural ribs of the subwoofer enclosure. A special steel rod, a high speed mechanical interface, concentrates the remaining micro-vibrations conveying them to the dual multiple “Tuned Mass Dampers”, i.e. two differently tuned special custom devices optimized to erase micro-vibrations, by oscillating in anti-phase. The subwoofer enclosure has been decoupled from the main enclosure through a new implementation of the Zero Vibration Transmission technology, a suspension system, eliminating any acoustic feedback and any vibration propagation to the listening room. The radiation of the main enclosure and of the subwoofer one are orthogonal to avoid any intermodulation.
Tweeter
Sonus faber “Arrow Point” DAD (Damped Apex Dome, synthesis of the classic dome and ring transducer) H28 XTR-04. A Sonus faber designed 28 mm moving coil driver, with Sonus faber’s vibration optimized mechanical interface. The ultra dynamic linearity is given by the new Neodymium motor system. Implemented with a natural wood acoustic labyrinth rear chamber, a mechanical anti-resonator designed for this application.
Midrange
Sonus faber M18 XTR-04. A Sonus faber designed 180 mm neodymium magnet system ultra dynamic linearity midrange. CCAW wire is used on a composite former “eddy current free” voice coil. The dynamically linear magnetic field motor incorporates triple Kellog/Goeller rings. A special custom diaphragm is made with a real time air dried non pressed blend of traditional cellulose pulp, kapok, kenaf and other natural fibers, developed according to the most natural sound. To further inhibit any residual cone coloration we are using a transparent viscous surface damping coating. The same way as the tweeter, the midrange is decoupled from the main baffle board and designed synergistically with its optimized “acoustic chamber”. A special coaxial anti-compressor is used, designed to remove cavity resonances and distortions.
Woofers
Sonus faber W18XTR-16. A triple of Sonus faber designed 180 mm lightweight “sandwich” cone structure (high-tech syntactic foam core and two external surface skins of cellulose pulp) woofers are integrated in an acoustically amorphous “stealth reflex” chamber. Designed to blend perfectly with the special midrange and, at the same time, to have absolute definition in their range: the sandwich structure with outer paper pulp skins has the same sonic character of the midrange cone. A powerful long stroke motor system with a 1,5” controlled “eddy current” voice coil is implemented for high speed, performance and linearity.
Infra Woofer
Sonus faber SW26 XT-08. Sonus faber designed a 260 mm infra woofer, lightweight hard paper composite sandwich cone technology for a maximum rigidity and implemented it in an acoustically amorphous passive radiator tuned separated enclosure. The unit features a very powerful long throw motor with a 2.5” voice coil for ultra dynamic linearity. To perfectly match the low-end performance to different listening rooms it is possible to adapt the SPL of the infra woofer.
Cross-over
Non-resonant design, optimized amplitude/phase response for optimal space/time performance. “Paracross topology”. The impedance at low frequencies is controlled for a clear and friendly amplifier performance. Double staggered transfer function low frequency/room interface optimized filter. Highest quality is used in terms of the components: Mundorf “Supreme” Silver/Gold/Oil capacitors, Jantzen inductors. Cross-over: 80Hz – 250 Hz – 2500Hz.
Price and Availability
The Sonus faber Lilium loudspeaker is available in Europe and the U.S. for about USD $65,000/pair.
Specifications
  • FREQUENCY RESPONSE: 20 Hz – 35.000 Hz, Stealth reflex included.
  • SENSITIVITY: 92 db SPL (2.83V/1 m).
  • NOMINAL IMPEDANCE: 4 ohm.
  • POWER HANDLING: 100W – 800W, without clipping.
  • DIMENSIONS: 1600 mm x 491mm x 705 mm (HxWxD)
  • WEIGHT: 103 (156) Kg each – net (shipping) weight
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Hi-Fi Components
Bose Corporation has acquired McIntosh Group, the parent company of two iconic high-end audio brands; McIntosh and Sonus faber.
At $5,000/pair, Sonus faber's fourth generation Concertino G4 are a striking modernization of the Italian manufacturer's most underrated loudspeakers.
Car Audio
Lamborghini's newest hybrid supercar will have a sound system to match the driving performance.
Priced from $1,249 to $7,999 a pair, Sonus faber's Sonetto G2 loudspeaker series features seven new models arriving July 2024.
Podcasts
On this episode Editor in-Chief, Ian White discusses his picks for the best wireless speakers of 2024 (so far) under $4,000.
The new Sonus faber Suprema are the talk of CES 2024. An Italian masterclass in design and acoustical engineering. Forza!
Sonus faber's Lumina II Amator and Lumina V Amator deliver even more performance and luxury at a surprising price from the Italian loudspeaker maker.
Italian crafted luxury wireless speakers are perfect for streaming music, but can also connect to a TV or turntable.
