Sonos ZP120 and ZP90 ZonePlayers Now Available
ZP120
Wireless Range and Amplifier Design Innovations Deliver State of the Art Multi-Room Music Experience
Sonos, Inc., introduced two new ZonePlayers to deliver a state-of-the-art multi-room music experience. With innovations in both wireless technology and amplifier design, the Sonos ZonePlayer 120 (ZP120) and the Sonos ZonePlayer 90 (ZP90) make Sonos the ideal system for music lovers who want to enjoy all the music they love, all over the house. The new ZonePlayers are available starting today at all Sonos authorized retailers and at http://www.sonos.com.
The two new Sonos ZonePlayers give music lovers the ability to add music to absolutely any room. Connect speakers to the amplified ZP120 and place in the bedroom or the backyard. The non-amplified ZP90 can be connected to a home theater or stereo, allowing customers to make use of the audio equipment they already own.
“Sonos’ mission is to fill every house — and every room — with music,” said Phil Abram, President & Chief Operating Officer, Sonos, Inc. “These new products continue Sonos’ heritage of blending the latest technology, software and user experience to create an unmatched music experience in the home.” The new ZonePlayers incorporate SonosNet™ 2.0, our latest wireless mesh network technology, which doubles the wireless range of the Sonos Multi-Room Music System. SonosNet 2.0 uses Sonos’ mesh network combined with state of the art MIMO (Multiple Input Multiple Output) wireless technology which uses 3 antennas to send and receive music. SonosNet 2.0 helps assure the music gets to all the right rooms, near or far, at the right time — creating perfect synchronization of music without all the wires. The extended range works between any mix of ZP120s and ZP90s and is compatible with all previous generations of Sonos ZonePlayers, Controllers and ZoneBridges.
ZP120
Advances in power supply design, digital amplifier engineering, industrial design, and mechanical engineering make this the smallest, lightest, most powerful amplified Sonos ZonePlayer ever. The incredibly efficient amplifier and power supply, combined with the fan-less design of the aluminum case, allows the ZP120 to operate silently. The ZP120 delivers 2×55 watts per channel RMS at 8 Ohms. With measurements of THD+N < 0.02%, 20Hz-20kHz, the ZP120 delivers powerful low distortion audiophile quality sound to every room of the house. The ZP120 can be connected to speakers and discreetly placed on a bookshelf, under furniture or beds, or hidden in cabinets with connections to in-wall speakers. The ZP120 will retail for $499 individually. It is also included as part of the Sonos Bundle 150 (see accompanying press release) for $999. Sonos ZonePlayer 120 Technical Specifications
  • Class-D Amplifier: Great sounding amplifier that is lightweight, small and very energy efficient
  • Output: 2x55W RMS (55W power into 8 ohms, THD+N < 0.02%)*
  • Speaker connections: Spring binding posts
  • Line In: Auto-detecting RCA allows any external audio source to be played by all ZonePlayers in the system
  • Subwoofer out: Auto-detecting RCA, 80 Hz crossover
  • Wireless connectivity: SonosNet™ 2.0, a secure AES encrypted, MIMO peer-to-peer wireless mesh network
  • Network bridging: 2-port switch (10/100Mbps, auto MDI/MDIX) allows Ethernet devices to connect through SonosNet
  • Power Supply: AC 120/240V, 50-60Hz, user-switchable
  • Dimensions: W 7.3 inch x H 3.5 inch x D 8.15 inch (W 185mm x H 89mm x D 207mm)
  • Weight: 5.1 lb (2.3 kg)
  • Product finish: Anodized precision machined extrusion aluminum case. Aluminum casing also facilitates passive cooling.
* Both channels driven, minimum continuous average power, 22Hz-20kHz-AES17 measurement bandwidth
Sonos ZonePlayer 90
ZP90
ZP90
The Sonos ZonePlayer 90 allows music lovers to play all the music they want, all over their house, on all of their favorite audio equipment — a home theater system, powered speakers, a premium table top radio such as a Bose Wave Radio, and more. It is the easiest way to integrate existing audio equipment into a multi-room music system.
The ZP90 will retail for $349 individually. It is also included as part of the Sonos Bundle 150 (see accompanying press release) for $999.
Sonos ZonePlayer 90 Technical Specifications
  • Sound quality: THD+N < 0.009%, 20Hz-20kHz
  • Line-out: Analog (RCA), digital (optical and coaxial)
  • Line-in: Analog (RCA), auto-detecting
  • Network bridging: The 2-port switch (10/100Mbps, auto MDI/MDIX) allows Ethernet devices to connect through SonosNet™
  • Power Supply: AC 100-240V, 50-60Hz
  • Dimensions: W 5.5 inch x H 5.4 inch x D 2.9 inch (W 139.7mm x H 136mm x D 74mm)
  • Weight: 1.5 lbs (0.69 kg)
  • Product finish: Light gray, high quality PC
Sonos System Technical Specifications
  • Audio formats supported: MP3, WMA (including Windows Media DRM), AAC (MPEG4), Ogg Vorbis, Audible (format 4), Apple Lossless, Flac (lossless) music files, as well as uncompressed WAV and AIFF files.
  • Native support for 44.1kHz sample rates. Additional support for 48kHz, 32kHz, 24kHz, 22kHz, 16kHz, 11kHz, and 8kHz sample rates.
  • Music services supported: Best Buy™ Digital Music Store, Napster, Pandora, Rhapsody 3.0+, SIRIUS Internet Radio, and downloads from any service offering DRM-free tracks, including Amazon MP3™, eMusic and more.
  • Operating systems (for stored files): Windows XP SP2 or higher, Windows Vista™ Mac OS X v10.4 and v10.5 NAS (Network Attached Storage) devices supporting CIFS.
  • Internet radio supported: Streaming MP3, WMA
  • Album art supported: JPEG, PNG, BMP, GIF
  • Playlists supported: Rhapsody, iTunes, WinAmp, Windows Media Player, and MusicMatch™ (.m3u, .pls, .wpl)
In conjunction with today’s ZP120 and ZP90 announcement, Sonos also introduced Sonos Software 2.6 to all Sonos customers. The new feature update includes more than $200 in DRM-free music offers, support for music collections with up to 65,000 tracks, and more.
Sonos is the first wireless, multi-room music system that lets you play all the music you want all over your house — and control it all from the palm of your hand. To learn more about Sonos, to place an order or to locate an authorized Sonos dealer, please visit http://www.sonos.com or call 877.80.SONOS.
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Home Video
Can a new video streamer save Sonos from a year of horrible missteps? Project Pinewood does not have us convinced - and now it...
Daily Deals
With the introduction of the Sonos ARC Ultra Soundbar - it is time to clear out the remaining stock of the original Sonos ARC
Sonos ventures deeper into the business and commercial landscape with a variation of its ERA 100 wireless speakers with features specifically designed for that...
Eleven years after the first Sonos soundbar hit the market, Sonos just introduced a new flagship: the Sonos Arc Ultra.
While the Sonos Ace may not be the headphones Sonos users were expecting, that isn't necessarily a bad thing.
Months after unleashing a catastrophic app update to the Sonos mobile app, the CEO just made seven commitments to his customers. Will it be...
The limited edition Sonos Ace wireless noise cancelling headphones emblazoned with Sporty & Rich logo are $449 while supplies last.
Gift ideas guaranteed to bring the thrill of the Olympics into your home for a more enjoyable and memorable experience with family and friends.
