Sonos Unveils The Sub Mini: Preview
The Sonos Sub Mini, is a compact cylindrical designed subwoofer with a lower price than the Sonos Sub.
Sonos sub mini Home Theater Lifestyle
Following up on the release of two soundbars, the Beam 2 and Ray, Sonos is expanding its home theater lineup with the Sub Mini. With the Sonos Sub Mini, customers now have two subwoofers to choose from, the other being the Sonos Sub (Gen 3). Building on the foundation of the Sub (Gen 3), Sub Mini delivers deep base in a more compact, cylindrical design.
Sub Mini Core Features
Bass Without Buzzkill: Dual custom woofers and advanced audio processing produce a deep base with no buzz or rattle. Within the acoustically sealed cabinet, both woofers face inward to create a force-canceling effect that neutralizes distortion.
Balanced Sound: Advanced digital signal processing maximizes bass response and reproduces the full-toned low frequencies expected from a much larger subwoofer. This enables other paired Sonos speakers like ARC, Beam, Ray, One, or One SL to focus on the mid-range and high frequencies. The result is a more balanced transition through all frequencies.
Pairs Well With…: The Sub Mini can be paired with Sonos ARC, Beam, or Ray soundbars for TV and movie viewing, or a pair of Sonos Ones for dedicated music listening. The Sub MIni will not pair with portable Sonos Speaker products such as the Roam or Move
Stylish Look: Unlike other subwoofers, Sub Mini features a round, cylindrical design that allows it to blend naturally into your home aesthetic without taking up too much space or being visually distracting.
Seamless Set-Up: Add Sub Mini to your Sonos system in just a few taps on the Sonos S2 app.
Trueplay: In addition to the basic setup, Trueplay measures the acoustics of the room and then fine-tunes the sound. Supported iOS device required.
Adjustable EQ: Audio settings automatically equalize to balance Sub Mini and the paired Sonos product(s). You can also use the Sonos app to manually adjust bass and loudness.
Sonos sub mini
Additional Specifications
Design: Cylindrical Sealed Cabinet with Center Open Tunnel.
Speaker Drivers: Dual 6-inch drivers mounted face-to-face for force-canceling effect. This maximizes sound output while minimizing cabinet buzz and rattle.
Amplifier Type: Class-D
Power Output: Not provided
Frequency Response: Down to 25 Hz (upper range not provided)
Sound Pressure Level (SPL): Not provided
Wireless Network Connectivity  Wi-Fi 802.11a/b/g/n broadcast-capable router. 5 GHz connection to a Sonos soundbar enhances audio transmission speed for high-quality sound synced with your TV.
Wired Network Connectivity: Ethernet 10/100 port.
Finish: Black or White Matte.
Dimensions: (Height) 12 in/305 mm, (Diameter) 9.1 in/230 mm
Weight: 14 lb (6.35 kg)
Sonos sub mini Black inside
Pricing and Availability
Sub Mini will be available globally starting October 6, 200 at $429 at Sonos and other authorized dealers.
Tip: Sonos Sub (Gen 3) is also available for $749 at Sonos or authorized dealers.
Sub Mini vs Sonos Sub (Gen 3) Differences
FeatureSub MiniSub (Gen 3)
CabinetCylindricalSquare
Power Output (Exact spec not provided)Less power than the Sub (Gen 3)More power than the Sub Mini
Pairing CapacityCan’t Pair with Additional Sub Minis or Sub (Gen 3)Pairing for up to three Sub (Gen 3)s
Wi-Fi5Ghz2.4Ghz or 5Ghz
Size230 x 305mm (12 x 9.1-inches)389 x 402 x 158mm (15.3 x 15.8 x 6.2-inches)
Weight6.35kg (14lbs)16kg (36.3lbs)
Price$429 (US)$749 (US)
Sonos Acquires Mayht To Develop Smaller Speakers That Really Sing
Sonos Adds DTS Support To Sonos ARC And Beam
Sonos Releases Arc, Premium Dolby Atmos Soundbar
Sonos SUB Wireless Subwoofer Announced (2012)
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
Home Video
Can a new video streamer save Sonos from a year of horrible missteps? Project Pinewood does not have us convinced - and now it...
Daily Deals
With the introduction of the Sonos ARC Ultra Soundbar - it is time to clear out the remaining stock of the original Sonos ARC
Sonos ventures deeper into the business and commercial landscape with a variation of its ERA 100 wireless speakers with features specifically designed for that...
With both Bluetooth and wired connectivity, Onkyo's Creator Series GX10DB and GX30ARC Powered Speaker Monitors are a versatile and affordable compact audio solution.
With updated styling and connectivity, the $349 Andover SpinBase 2 is a compact wireless speaker designed to sit under any turntable.
Eleven years after the first Sonos soundbar hit the market, Sonos just introduced a new flagship: the Sonos Arc Ultra.
While the Sonos Ace may not be the headphones Sonos users were expecting, that isn't necessarily a bad thing.
Digital Music Systems
At $649, the REVO SuperCD includes digital music streaming, Bluetooth 5.1, global radio, podcasts with dedicated app, and remote.
