The Sonos Ray Aims to Disintegrate the Affordable Soundbar Competition
After a recent leak under the code name “Fury”, the Sonos Ray Soundbar is finally here but will consumers looking for lower-priced soundbars buy it?
Sonos Ray Soundbar White with Touch Controls
In our previous report, we discussed the impending release of a new inexpensive soundbar from Sonos, which at that time was unofficially labeled “Fury aka Model S36”. This soundbar has now been released as the Sonos Ray with a $279 asking price. Also, it looks like most of the features discussed in the leaked report are included.
Let’s take a look at the Sonos Ray and see if it offers what you are looking for in a soundbar.
Sonos Ray Soundbar White Front Angle
Sonos Ray Soundbar White Rear
Core Features
Compact Size: The Sonos Ray is 22-inches wide, 2.79-inches high, and 3.7-inches deep making it an easy fit below most TVs or wall mounting via an optional wall mounting bracket. The compact size works for TVs or PC gaming setups.
Amplifiers: Four tuned Class-D digitally controlled amplifiers.
Speakers
The speaker complement inside the Ray is as follows:
  • Tweeters:  Two with Split waveguides to project a wider soundfield.
  • Midwoofers: Two centered high-efficiency mid-woofers handle the midrange and upper bass frequencies
  • Ports (Bass Reflex System): Two ports are included to provide an extended bass response.
Adjustable EQ: Use the Sonos app to adjust bass, treble, and loudness.
Trueplay: This is software that measures the acoustics of the room to fine-tune soundbar performance. A supported iOS device is required (Not available for Android).
Speech Enhancement: This Sonos app setting boosts voice frequencies for clearer dialog.
Night Sound: This Sonos app setting reduces loud sounds and increases the level of quieter sounds.
Home Theater Audio Formats
Tip: The Sonos app’s Now Playing screen will show which audio format is being decoded.
Sonos Ray Soundbar White Rear Connections Closeup
Connections: 1 Digital Optical (for connection to TV) 1 Ethernet Port, and a Power receptacle. WiFi is also built-in.
Apple AirPlay 2: Send sound directly from your iPhone, iPad, or Mac, to the Ray.
Tip: Bluetooth is not supported.
Sonos App: The Sonos App (S2 version) is not only used for setup but provides access to several popular music streaming services as well as Sonos Radio
Multi-Room Audio: Sonos products provide wireless multi-room audio. This means that in addition to using the Ray for watching TV, you can include it in a Sonos multi-room audio system via wireless connection with other compatible Sonos speaker products.
Optional Surround Speakers: You can add a pair of Sonos One SL speakers for a full surround sound experience.
Tip: Other Sonos speakers can be used with the Ray as surround speakers such as Sonos Five, Play:1, Play:3, and Play:5 (Gen 2) as well as the Sonos Amp with regular speakers.
Color Options: The Ray comes in black or white.
Sonos Ray, Sonos Beam and Sonos Arc Soundbars Black
Larget to smallest: Sonos Arc, Sonos Beam 2, Sonos Ray Soundbars
What’s in the Box
  • Sonos Ray soundbar
  • Power Cable
  • Digital Optical Cable
  • Quickstart Guide and legal/warranty information
  • Weight
  • 4.29 lb (1.95 kg)
What the Sonos Ray Doesn’t Include
As outlined in our previous “leak” report, the Ray doesn’t include some features you find on the Sonos ARC and Beam/Beam 2 soundbars:
  • No HDMI connection: This means no ARC/eARC functionality.
Sonos Ray Soundbar Black Lifestyle in Bedroom
Pricing and Availability
The Sonos Ray will be available starting on June 7th, 2022 in black or white at a $279 price point. It can be purchased directly at Sonos.com or other authorized dealers.
Optional wall mount available for $39.00.
If you purchase a Sonos Ray Surround Set package that includes two Sonos One SLs the price is $677.
The Sonos Ray is also compatible with Sonos Subwoofers.
Sonance / James Loudspeaker SA68 Small Aperture Speaker Exploded
In-Wall Speakers
Earbuds & In-Ear Headphones
Home Video
Can a new video streamer save Sonos from a year of horrible missteps? Project Pinewood does not have us convinced - and now it...
Daily Deals
With the introduction of the Sonos ARC Ultra Soundbar - it is time to clear out the remaining stock of the original Sonos ARC
Experience the full impact of Super Bowl LIX in your living room with both a big picture and big sound.
Sonos ventures deeper into the business and commercial landscape with a variation of its ERA 100 wireless speakers with features specifically designed for that...
Eleven years after the first Sonos soundbar hit the market, Sonos just introduced a new flagship: the Sonos Arc Ultra.
While the Sonos Ace may not be the headphones Sonos users were expecting, that isn't necessarily a bad thing.
Months after unleashing a catastrophic app update to the Sonos mobile app, the CEO just made seven commitments to his customers. Will it be...
At $499, the Bose Smart Soundbar works with Bose Ultra Open Earbuds that function as rear speakers.
