Is the New Sonos Arc Ultra Soundbar Worth The Upgrade or Just More of the Same?
Eleven years after the first Sonos soundbar hit the market, Sonos just introduced a new flagship: the Sonos Arc Ultra.
Sonos Arc Ultra Soundbar White Lifestyle
It was 2013. Sonos invited us to their headquarters in Santa Barbara to check out the company’s first-ever home theater product: the Sonos PlayBar. The PlayBar was a sleek soundbar with a modern look and sound that could fill a living room. It elevated TV sound to the next level while also seamlessly integrating with the company’s wireless whole home music ecosystem. Over time, the company expanded its soundbar line-up with smaller low-cost options (Sonos Beam and Beam 2, Sonos Ray), and the novel PlayBase which actually sat underneath a TV. In 2020, the company launched a new flagship soundbar, the Sonos Arc (originally launched at $799, but now selling for $899).
Earlier this month, Sonos unveiled the successor to the Arc, the Sonos Arc Ultra ($999). The Arc Ultra offers a new sleeker industrial design, upgraded drivers and improved processing. But, at least on paper, (since we haven’t had a chance to check it out in person yet), it doesn’t seem like a radical departure from the current Arc soundbar. But maybe that’s the point? “If it ain’t broke…”
The Arc Ultra offers a single HDMI input (with ARC/eARC support), Dolby Atmos decoding (but no DTS:X) and integration with the Sonos whole home music ecosystem. It also supports expansion via an optional subwoofer (or two) and surround speakers for discrete immersive Dolby Atmos surround sound for music, TV shows and movies. If these specs seem familiar, it’s probably because the original Sonos Arc offered similar features and functionality.
Sonos Arc Ultra Soundbar White Rear Angle
Sonos Arc Ultra Soundbar has one rear HDMI port along with one Ethernet port.
The two upgrades we had been hoping for over the original Arc were a second HDMI port, for direct connection of a disc player, gaming console or streaming player, and DTS:X decoding. While it may be possible to add the latter in a software upgrade, hardware is hardware so that second HDMI input isn’t coming to the Arc Ultra… ever. Like the original ARC, the Arc Ultra specs say that it can decode standard (legacy) DTS Digital Surround but there is a footnote to that: “This is not an indication of a licensed decoder.” So how does one decode DTS without a licensed DTS decoder? An intriguing question. But one we cannot answer just yet.
The Arc Ultra is a bit more limited in which surround speakers can be used to augment the immersive effect with rear channels. The original Arc supported the following as rear channel speakers: Sonos One, One SL, Play:1, Play:3, Play:5, Five, Era 100, Era 300, Ikea Symfonisk lamp speaker, Symfonisk Gen 2, Sonos Connect:Amp and the Sonos Amp (with any speakers connected). For the Arc Ultra, the options are: Era 100, Era 300, Sonos One, One SL, Five, Symfonisk (Gen 2) or Sonos Amp. So basically the Arc Ultra discontinues support for the Play:1, Play:3 and Play:5 as well as the Connect:Amp and the original Ikea Symfonisk lamp speaker as surround options. That last one was a decidedly cool option if you liked your rear speakers to hide in plain sight. Sonos tells us that these earlier speakers like the Play:1 have “insufficient computational power to support being used as rears with Arc Ultra due to the performance required for modern home theater experiences.”
Symfonisk lamp speakers
As cool-looking as the Ikea Symfonisk lamp speakers are, they are not compatible with the new version of Sonos’ Arc soundbar (the Arc Ultra).
Does any of this matter to new Sonos customers? Probably not as these folks will likely buy the surround speakers with or after the Arc Ultra purchase and they won’t be pairing it with older Sonos products. But if you’re upgrading from an Arc to an Arc Ultra, you should aware that your current surround speakers may no longer be supported with the Arc Ultra. Similarly, if you want to use two subwoofers with the Arc Ultra for maximum bass performance, you’ll need to use either two sub 4s (the latest version), two subs (gen 3) or one of each. Earlier versions of the Sonos sub are compatible with the Arc Ultra in single subwoofer mode only. The Arc Ultra also supports pairing with a Sub mini for enhanced bass in smaller spaces.
Sonos recommends pairing the Arc Ultra with two Sub 4s ($799 each) and a pair of Era 300s ($449 each) in the rear for the most impactful and immersive surround sound experience. That’s a total system cost of $3,495, making this one of the priciest soundbar systems available. It’s right up there with the Nakamichi Dragon system and even more expensive than Sony’s Bravia Theatre Quad.
Sonos Arc Ultra Soundbar System white lifestyle couple
Sonos Arc Ultra Soundbar with two Sub 4 Subwoofers and two Era 300 rear speakers.
What’s Improved with the Sonos Arc Ultra vs. Sonos Arc?
Lest you get the impression that the Arc Ultra is a step down from the Arc, you should know that the company has made some significant improvements in the soundbar’s design. The main enhancement is something Sonos touts as “Sound Motion” technology which the company uses to enhance bass response without increasing the driver or cabinet size. Sound Motion uses four lightweight motors and two force-canceling membranes to unlock more extended, more powerful bass from a smaller form factor. Sound Motion reduces the size of transducers by as much as three times compared to a traditional driver design. With Sound Motion technology, Sonos says the Arc Ultra can produce up to twice the bass output compared to Arc (at 50 Hz). And by actually reducing the size of the bass driver, they’ve managed to squeeze in three new drivers on the Arc Ultra, bringing the total up to 14 transducers in the Arc Ultra vs. 11 in the original Arc.
Sonos Arc Ultra Soundbar Black Parts Exploded
Explosion diagram of the Sonos Arc Ultra shows drivers and components that make the magic happen. Don’t try exploding your Arc Ultra at home as this may void your warranty.
The Sonos Arc Ultra also features multiple midrange drivers, full-range drivers and tweeters with waveguide technology to direct sound in all directions for maximum immersion. The company claims a “9.1.4 channel spatial audio experience” but frankly there aren’t enough drivers for that many channels so they’ve got to be combining reflective sound with virtualization technology to expand the perceived number of channels. The system can be tuned using the Sonos app’s “Trueplay” feature to optimize performance in your specific room. The Trueplay feature, previously only on iOS is now available on both iOS and Android.
The center channel drivers on the Arc Ultra have been improved for enhanced dialog clarity and the Sonos app’s new Speech Enhancement feature lets you customize the level of dialog prominence in the mix.
Sonos Arc Ultra Soundbar with woman wearing Sonos Ace Wireless Headphone in white
Sonos Arc Ultra can switch sound over to Sonos Ace Headphones to continue that “home theater” listening experience in the privacy of your own head.
The Arc Ultra features a curved profile, matte finish, and a slimmer appearance than its predecessor. It can be either wall-mounted or placed on a credenza without blocking most TV’s screens or bezels. Its wrap-around grille extends around the back of the speaker so sound can be reflected in multiple directions to enhance the overall immersive effect.
In addition to the single HDMI input with ARC/eARC support, the Arc Ultra also supports Bluetooth connectivity to phones, computers or tablets and WiFi connectivity to the Sonos Ace headphones. It can be connected to your home network either via WiFi or a hard-wired ethernet connection. A network connection is essential for app control and integration with the Sonos ecosystem.
Sonos Arc Ultra Soundbar, Sub 4 Subwoofer and Era 300 Rear Speakers in Black
The Sonos Arc Ultra, Sub 4 and Era 300 are all available in white or black finish options.
The Bottom Line
Maybe our expectations for the new version of the Sonos Arc were too high. We had been hoping at least for DTS:X decoding and possibly an additional HDMI port as these features are now standard on most mid to high-end soundbar systems, even those at significantly lower price points. But with only a $100 premium over the current version of the Arc, perhaps the elevated performance and enhanced styling of the new Arc Ultra will be enough to rally the Sonos faithful to upgrade to the latest and greatest version. We shall see.
Price & Availability
The Sonos Arc Ultra and Sub 4 are available to pre-order now and will begin shipping October 29, 2024. The Era 300 is available now.
All products are also available for order direct from Sonos.
2 Comments
2 Comments
  1. Brady Totter
    November 1, 2024 at 3:53 am
    What’s the largest room that can be with these? It’s essential to know. Though convenient, these are limited by room size. I have a Sennheiser top-of-the-line soundbar (about $2800 four years ago). With an open-concept family room and kitchen, there isn’t enough reflection to surpass even a base surround sound receiver and medium-grade speakers with a small subwoofer.
    • Chris Boylan
      November 4, 2024 at 12:28 am
      Room size and layout is the big limiting factor with soundbars or really any immersive sound system that relies on reflections to recreate side, rear and height channels. Dolby officially states that ceilings can be between 7.5 and 14 feet when using height-reflecting speakers for Dolby Atmos. But physics matters. If you have 14 foot ceilings, you need to have enough distance between the soundbar and the listening position for the sound to bounce off the ceiling and into the listening position. So assuming the soundbar or up-firing speaker is 4 feet above the floor and projects the height speaker at 45 degrees, you’d actually need 20 feet from soundbar to listening position to get the height reflections with 14 foot ceilings. If the projection angle is steeper (like 70 degrees), you’d need much less distance between the up-firing speakers and listening position. Wall reflections and side-firing speakers work the same way. The walls need to be close enough to reflect those side surround channels back to the listening position. I don’t believe that Sonos publishes the precise angles of the top-firing and side-firing speakers on the Arc or Arc Ultra, but I’ve read that the top-firing ones are around 70 degrees. If it does project at 70 degrees, then you’d only need about 7 feet between the bar and listening spot to catch those height channels.
      If you have an open floorplan with long distances between the soundbar and side walls, angled ceilings, high ceilings or absorptive ceilings, you’d be much better off with ceiling mounted speakers for the height channels. Sonos does support the use of in-wall/in-ceiling speakers by using a Sonos Amp for the rear channels with the Arc Ultra, but I believe that only applies to the rear surround channels. I don’t believe Sonos Amp can be used with an Arc Ultra for rear height channels. Open floor plans work much better with receivers and dedicated speakers.
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Podcasts
In celebration of Shure's 100th Anniversary, company historian Michael Pettersen reveals how music, entertainment and culture have been shaped by Shure.
HDTV 4K & 8K TV
The well known TV reviewer and tech journalist extraordinaire has announced the launch of a new company, CD Creative Media LLC and a new...
On this episode Caleb Denison, formerly of Digital Trends, shares his thoughts on 2025 TVs along with the launch of his new YouTube channel,...
HDTV 4K & 8K TV
With a 120 Hz OLED panel, perfect blacks and an affordable price, LG's B4 may be the value pick for price-conscious TV buyers right...
Does it make sense to spend more than most audiophiles spend on their entire system on a little box that makes your power clean?
Podcasts
Nick Brown, SVS VP of Marketing reveals some surprising ways to get better sound from your hi-fi and home theater system, and gear you...
