Sonance Introduces Bandpass Subwoofer System
San Clemente, CA–September 5, 2007–The Sonance Architectural Series will introduce a new Bandpass Subwoofer System at the 2007 CEDIA Show which is sonically designed for use with the Sonance Architectural Series in-wall and in-ceiling loudspeaker systems.
The Sonance Architectural Series BPS-1 Bandpass Subwoofer System is designed to add deep, powerful bass impact while the enclosure remains completely hidden from view. It delivers its bass energy through a Sonance Architectural Series Finish Component that is a visually discrete complement to the surrounding architecture space.
The trimless and truly flush-mount installation mounts the plane of the subwoofer grille perfectly aligned with the plane of the wall or ceiling. Adaptor Baffles are available which allow the BPS-1 Subwoofer to be used with any size round or square Architectural Series Panel Bracket (even 4-inch) to match other AS speakers in the audio system and any separately available Architectural Series Finish Component: metal (with or without trim) or cloth (with or without trim).
Sonance recommends the use of the Sonamp A150 power amplifier which delivers 150 watts of power RMS and provides flexible connections.
Availability: January 2008
Manufacturers Retail Prices:
BPS-1 $1050.00
Sonamp A150 $550.00
Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
