Solo E600X-EQ Bluetooth Speaker is Taller Than You Think
3 foot tall cylindrical wireless speaker packs in 200-watts of amplification and a lot of tech
Studio 19 announced the release of the Solo E600X-EQ, a three-foot tall 360-degree portable and wireless speaker with 200-watts of peak power. The $600 precision-engineered speaker is designed to deliver an immersive auditory experience with an exceptionally detailed and nuanced sound quality throughout the room. It’s built using Advanced Wave Sound Method (AWSM) with Adaptive Intelligence Audio, patented Dual Pressure Air Compression (DPAC) super-bass technology and Enhanced 360° Optimized Sound.
Beautifully designed in powder-coated stainless steel (available in Space Grey, Gold or Charcoal Black colors), the Solo uses state-of-the-art speaker drivers with a maximum output up to 200 watts, so it’s loud enough to handle virtually any occasion with no compromise in quality.
The Solo is one of the world’s first “enhanced degree” patented 3D-effect portable Hi-Fi speakers. Unlike conventional 360° sound, the Solo’s Enhanced 360° Optimized Sound flows not only left to right but top to bottom. This creates an omni-directional spread with wide, directional waves that circulate throughout a room, giving the authentic impression of a multi-speaker environment from a single speaker.
The Solo features Studio 19’s proprietary Advanced Wave Sound Method (AWSM) with Adaptive Intelligence Audio. The company says it’s pronounced “awesome” … and claims it is. Further adding, it accomplishes what many audio engineers considered to be unachievable: It protects digital audio before compression, preventing it from being degraded during compression encoding, which can strip an audio file or stream of as much as 90% of its detail, depth and intricacy. It restores a sound file to its original pre-compression state after decoding. AWSM significantly improves the efficiency of audio processing in real time.
Unlike other codecs (even high-resolution ones), AWSM doesn’t have to be on both sides of the process to work. That means it’s backward compatible. It can improve the quality of existing third-party content as its coming out of the Solo speaker. At the same time, AWSM allows digital audio to be compressed up to 98 percent more, with no loss of fidelity.
The Solo incorporates Studio 19’s breakthrough, patented DPAC technology to create a bass sound that matches or surpasses a conventional subwoofer. The innovative driver configuration, combined with air pressure, delivers a full-range sound with deep low-end frequencies and astonishing clarity of sound in an ultra-compact size.
Cutting edge digital processing power means that the Solo heightens the essential characteristics of the audio you listen too, resulting in a rich, dynamic sound that brings your music to life.
The Solo EQ has a built-in professional EQ Graphic Equalizer, a digital sound enhancement not normally found in portable speakers, allowing you to fine tune your music even further. Add more bass, mid-range or treble to get exactly the sound you want.
With the Solo, connectivity and play is a breeze. Choose between Bluetooth, WiFi, Auxiliary, or HDMI modes and connect your audio source with ease. The WiFi with Multi-Room App allows you to connect more than one Solo for different rooms in your house … for a multi-room sound experience. Play different songs in different rooms, synch up audio in multiple rooms, or blast the same song throughout the entire house.
Ready to go anywhere you want, the Solo is powered by an 8,800mAh built-in battery lasting up to 8 hours, indoors or outdoors. When it does run out of power, simply recharge it with a powerbank or connect to the main power (via a type-C cable) for faster charging.
Features:
  • Bluetooth Connectivity options for versatile play
  • Wifi connectivity for multi room playback and control
  • HDMI port: Connect to an HDTV for an enhanced sound bar experience
  • Proprietary Advanced Wave Sound Method (AWSM) with Adaptive Intelligence Audio restores streamed, compressed sound to the original pre-compression studio-recorded state, allowing you to listen to sound the way it was meant to be heard.
  • Active 3-band Graphic EQ to tailor your sound
  • Enhanced 360° Optimized Sound for omni-directional audio
  • Advanced DSP for full dynamic range
  • Dual Pressure Air Compression Technology for a super bass experience
  • Movie/Music/Gaming modes to optimize the sound source
  • Available in space grey or gold
Specifications:
  • Working voltage: 7.4V
  • Charging voltage: DC 5V 3A
  • Max Output: 200W
  • Driver Unit: bass 3Ω, middle 4Ω*2, treble 4Ω*2
  • Driver Size: bass 5 inch, middle 2.5 inch, treble 1.5 inch
  • Frenquency:20Hz~18kHz
  • S/N: ≥100dB
  • Distortion: ≤0.5%
  • Bluetooth Version: 4.2 with TWS
  • Bluetooth distance: 10M
  • Battery Capacity: 8800 mAh
  • Size: 143mm x 143mm x 602mm
  • Weight: 3.2kg
Price and Availability
The Solo E600X-EQ will be available June 2018 for a retail price of $599. Pre-orders are now being accepted for $349 at Indiegogo.
Marantz AV 30 and AMP 30 Promo Shot
Marantz brings the cost of A/V separates down to a more affordable price point with the AV 30 preamp/processor and AMP 30 multi-channel power...
Eversolo SE100 Passive Bookshelf Speakers Lifestyle Eversolo SE100 Passive Bookshelf Speakers Lifestyle
Eversolo’s SE100 passive bookshelf speakers promise big sound from a compact cabinet for $399 a pair, designed for real rooms and modern hi-fi systems.
Edifier M90 Wireless Speakers Lifestyle Gaming in White Edifier M90 Wireless Speakers Lifestyle Gaming in White
Edifier’s M90 is a "cross-scenario, multi-purpose" active speaker, performing equally well in TV and home entertainment setups as well as in PC, desktop, and...
Sylvox Cinema Pro 110-inch Helio QLED Outdoor TV by pool Sylvox Cinema Pro 110-inch Helio QLED Outdoor TV by pool
Sylvox debuts the world’s first frameless outdoor TV at CES 2026, plus a 110-inch 4K QLED model built to survive sun, rain, sports nights,...
Brane Party Pro Portable Speaker at CES 2026 Brane Party Pro Portable Speaker at CES 2026
Brane Audio debuts RAD2 at CES 2026, previewing the Party Pro prototype and a radical new approach to deep bass that could reshape portable...
Audio-Technica AT-LP7X Turntable Audio-Technica AT-LP7X Turntable
Audio-Technica’s AT-LP7X is a $999 fully manual belt-drive turntable with precise speed control, adjustable tonearm geometry, and built-in MM/MC phono support.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
LG expands its xboom by will.i.am lineup with the Rock, Mini, Blast, and Stage 501—bringing AI sound, rugged designs, and party-ready power to CES...
Portable Bluetooth speakers are now a billion-dollar category. We break down what actually matters — sound, battery life, ruggedness, and the models worth buying.
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
The Edifier MR5 delivers impressive near neutral accuracy, deeper bass, LDAC support and true three-way power for $350, making it a top budget studio...
Sony's flagship soundbar system will add punch to your movie and TV viewing and music listening, but at a price.
Samsung today announced the LEVEL U Bluetooth stereo headset for listening to music or taking calls. The $70 headphones are ergonomically designed for long...
Bose expands its portable speaker lineup with the new SoundLink Plus and 2nd Gen Micro—Bluetooth 5.4, better battery life, improved sound, and rugged designs...
